**The Hi Lo Hustler** Dragster build
Discussion in 'The Hokey Ass Message Board' started by 51box, Dec 25, 2009.
  1. madmak95
    madmak95
    I second.....
  2. 51box
    51box
    from MA
    Ya it's a reversed corvair box. I really need a SBC blowshield uncut SFI, if you have one you want to sell PM me, thanks, Joe
  3. 51box
    51box
    from MA
    Some more pics for you guys, First we redid the hair pins. I didnt like how wide the opening was towards the back so cut about 1/4in off each tube and then slid the threaded sleeve back about 1/2in. no one will probably notice but it needed to be done.
    Then I smoothed out the top of the axle and for some reason the very end holes had bolts welded in them. So i ground out the welds and knocked them out. Smoothed out the line across the top and it is ready to go to the blaster. [​IMG]
    Next up we made a nice little pad to rest your left foot on. I figured id drill some holes in it, from now on the only holes a bracket will get is for mounting, took too long and didnt come out too straight, oh well its done.
    Thats it for this weekend, more to come soon, Thanks, Joe
  4. pompadour
    pompadour
    Holy moley... Get it... Haha.... Buy a truck
  5. 51box
    51box
    from MA
    I'm looking for a nice brown vertex mag cap if you have one you want to sell PM me, thanks, Joe
  6. good lookin coupler cover...that thing isgettin better and better...
    Lippy- thats exactly the style i was talkin of that we use...perfect...
    T.H.
  7. lippy
    lippy
    from Ks
    Joe, I may have a cap, let me check I'
    ll PM you. Lippy
  8. 51box
    51box
    from MA
    First Nostalgia day at New England is may 30th, Im shooting for the car to be done in time for that. After smoothing out the top of the axle I sent it over to be blasted, got it back the next day and scott threw some primer on it.
    Next up boxed in the back of the throttle mount and put a little side support to keep the ear from wanting to twist.
    Then moved over to the clutch side and made up a plate for the back and put in a support right under where the clutch linkage will connect to keep the mount from wanting to pull forward when depressed.
    Im waiting on a bearing for the steering shaft, should be here this week and I can get the drop/mount figured out and get the steering wheel mounted.
  9. 58fed
    58fed
    Looking great Joe, keep up the good work. I will see you guys down at Ray's Saturday????
  10. pompadour
    pompadour
    That pedal better be able to keep up with me when I shift that thing at half track and pull the wheels 5 feet in the air
  11. ol'skool29
    ol'skool29
  12. 51box
    51box
    from MA
    Thanks guys, ol'skool hows that buick coming along?
  13. 51box
    51box
    from MA
    Here we go again, made up a little plate to box the trans mount in.
    Then took some 1/4in aluminum plate and made up this column drop, this took up a good portion of the day but Im really happy with how it turned out.
    I bought a little 3/4 ID bearing for the shaft to ride in and setting it up to take a small SW temp and oil pressure guages.
    Thats it for now
  14. a coupe
    a coupe
    I have some nice white faced auto meter gaudges I bought at auto zone I'll trade for those old S*W's. Haha...
  15. Slick Willy
    Slick Willy
    I cant decide if that looks more like a mosquito or a gas mask!! Supercool none the less...I can smell spring time!!...Can you??
  16. pompadour
    pompadour
    Gas mask would be fitting...
  17. a coupe
    a coupe
    Let's see some new pics.... Kids slackin
  18. 58fed
    58fed
    Springs almost here, you going to be ready? Lets see some progress pics. Anything left you need my help with? Just let me know, we gotta get out there.
  19. ol'skool29
    ol'skool29
    coming along slow, my dad and i have had a few engine rebuilds to take care of over the winter, so all i was able to do was disconnect everything from the buick's engine to get it out of there. finishing up the last engine rebuild and install on a gmc pickup, then i'm pulling my nailhead.
    new updates look great!
  20. 51box
    51box
    from MA
    ok a few more updates
    Made up some throttle linkage
    made up a lil firewall and floor
    slide on in....
    Bought a sheet of aluminum and found a place with an 8ft power sheer and he let us cut out the panels for nothing, drew everything out copied the templates fitted them up.
    First time setting up those fasteners, so some areas are a little tight, needs some tweaking, but all in all came out nice. Im going to round the corners of the side panels and roll the top over the tube next.
    Once we get the cowl top figured out its going to be blown apart and finish welded, prime, paint and hopefully hit the track in the spring.
  21. pompadour
    pompadour
  22. 58fed
    58fed
    Joe,
    Its getn there. I'm loving it. I like the throttle linkage, simple but effective. Keep us in the loop with the progress.
    Brad
  23. 51box
    51box
    from MA
    Thanks brad, shes getting there, should be blowing it apart by the end of the week to finish up.
    My buddy rob came by last night and helped me get the cowl top bent up and fitted.
    Getting real excited now....
  24. pompadour
    pompadour
    Looks great you should polish the whole thing
  25. violet springs
    violet springs
  26. LeadSledMerc
    LeadSledMerc
    It's coming along great...thanks for the updates!:cool:
  27. looking cool! Great work.
  28. ol'skool29
    ol'skool29
    hell yeah man!! looks great
  29. voxnut
    voxnut
    from sacramento
    Totally *****in! Thanks for sharing!
  30. 51box
    51box
    from MA
    On the floor again....Also cut out the two vertical bars behind my head and Brad bent me up a hoop and we welded that in, I like it alot better. Couple more little things to ****on up before shes blown apart.
