Projects The Hitchhikers Guide Episode VI: Return of the Hitchhiker.... Hot Rod Model A banger
Discussion in 'Traditional Hot Rods' started by Hitchhiker, Feb 15, 2013.
  1. waxhead
    waxhead
    from West Oz
    Good luck with putting it all back together. Hopefully we get to see it running soon
  2. Hotrodmyk
    Hotrodmyk
    Any updates????
  3. gwhite
    gwhite
    SUPER MODERATOR
    Yeah!?! We need updates!
  4. grego31
    grego31
    from Sac, CA
    Nice read and lots of great info and ideas!
    As for the paint, if you paint the fenders gloss black, how about highlighting the welds with flat black patches? Similar to if it was a stock glossy paint job from back in the day and then when they fixed the fenders, they just slapped on a primer coat over the welds since it was "only a work truck" and it didnt need to be perfect?
  5. Hitchhiker
    Hitchhiker
    12-14 hour days have kept me real busy....I did get done early today, thinking I will head down to the garage after lunch this afternoon.
  6. Hitchhiker
    Hitchhiker
    Set her back on 4 wheels last night so I could push the truck outside and sweep under it. I've managed to make some good progress in the last week or so. I got the temporary stock engine in, along with the trans. I'm waiting on a new u joint and then I can put the rear end in for the final time and hook up the brakes. I got all the brake lines mounted and plumbed. I greased the wheel bearings and spent much of last night double checking that all the bolts are tight and started installing cotter pins. Anyways, hope to be finished with it soon....The one thing I do want to find is another high compression head to stick on this engine until the Winfield is done. so if you have one you want to get rid of....
    [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG]
  7. woodz
    woodz
    Looking good. Glad to see you back at it.
    Hitchhiker likes this.
  8. RainierHooker
    RainierHooker
    from Tacoma, WA
    Good to hear that your back on it. Hopefully our A's can get together for a play-date this year...
  9. Hotrodmyk
    Hotrodmyk
    Looking Good, Matt!
  10. mike bowling
    mike bowling
    boy, does that sit just right- and ya gotta love the Banger!
  11. Hitchhiker
    Hitchhiker
    Had to turn it around so I can fire it up with out filling the house with exhaust so snapped another picture. Got some good time in on it yesterday, I had a NOS Ford V8 u joint to install, and had a rough time getting it to fit on my 39 toploader output shaft. About 6 hours spent with small files taking down any high spots and it now fits like OJ's glove....The front, rearend and the trans are now all fully installed too, and everything tightened down. Everything is greased, or filled with the appropriate fluid.
    Besides a few minor engine bits to install, I need to make the custom tie rod bar, and go into the shop with the brake bits and finish weld them and install cottor pins everywhere.
  12. Awesome! Sooooo, what your saying is there should be a running
    driving video by next weekend?
    Hitchhiker and gwhite like this.
  13. waxhead
    waxhead
    from West Oz
    Love the stance. What Winfield head are you getting?? A new one from Tod?? I am waiting for the 7:1 cast iron crows foot.
  14. Hitchhiker
    Hitchhiker
    I already have a original cast iron Super Winfield 7:1 crows foot head. I'm just look for a temporary high compression head for the temp motor.
  15. Hitchhiker
    Hitchhiker
  16. Speedy Canuck
    Speedy Canuck
    I think you mean you want a permanent high compression head for your temp motor... :D
  17. Hotrodmyk
    Hotrodmyk
    Haven't seen anything in a while, how's the project coming along?
  18. Hitchhiker
    Hitchhiker
    I haven't been on the hamb in months....Honestly I miss the place, but I was spending to much time here, and need to focus on other things.
    and I haven't worked on the truck in months!
    luckily I just got done with 2 huge projects and tonight I just ordered the last little parts I need.
    I basically need to bleed the brakes, install a fuel line, grease everything, double check everything, and install a coil and plug wires.
    so hopefully I will get that done next week. Cross your fingers, but don't hold your breath.
  19. waxhead
    waxhead
    from West Oz
    Good luck. Will be good to see this pickup running.
  20. Fingers crossed, breathing. ;)
  21. TexasSpeed
    TexasSpeed
    from Texas
  22. Hitchhiker
    Hitchhiker
    So, the engine does run. Brakes are all hooked up. But I have been fighting a leaking residual pressure valve. looking at old threads, it seems that there is a fair amount of problems with the Wilwood aluminum ones and the br*** one from ECI are recommended.
  23. I'm using a 67 Mustang drum/drum master, I believe the same as you.
    I was told they have internal residual valves, so you should be able to eliminate the
    Wilwood ones.
  24. Chris
    Chris
    @Flowmeister I used that same MC on my A and could not figure out why I would loose brake pressure every time I applied the brakes. Ended up needing residual valves and it cured the problem. Those MC's are firewall mounted, so I do not know why they would have a back flow valve built into them
    Hotrodmyk likes this.
  25. joemac05
    joemac05
    Residual pressure valves are used with drum brakes for a number of good reasons no matter where they are mounted. They are not simply back flow valves at all. The original valves used in the master cylinders are very robust and reliable. However they are easily left out or disabled by the myriad of experts out there and a 1967 anything would be suspect. A kit is very simple to install and make sure everything is correct. I have pressure tested a number of the aftermarket in line valves over the years and found them very unreliable. Some do work but it is a **** shoot. They seem to be a little better over the last few years.
  26. brett4christ
    brett4christ
    Joemac05, can you elaborate? What are these "kits" you mention, and how do I determine if my M/C has the "kit" installed? I'm in the mock-up stage of exactly what Hitchiker has done and could use a little insight!
  27. Thanks @Chris I'll be bleeding mine in the next few days, it will be interesting to
    see what results I get.
  28. Hitchhiker
    Hitchhiker
    I just checked my 1968 Drum/Drum mustang master cylinder and there are no residual pressure valves...
  29. joemac05
    joemac05
    A master cylinder rebuild kit. It should come with new residual check valves. In a dual drum master cylinder there would be one in each brake line outlet port, (front and rear) often as part of the br*** seat the brake line flare seals to. In a single master cylinder they are most often mounted in front of the main piston return spring. Residual pressure for drum brakes is usually quite high.... 10 to 20 PSI range. This is balanced against the shoe return springs and keeps the cups sealed. If this amount of pressure was held against the larger pistons used in disc brakes a large amount of drag and heat would result.
    Disc brakes have no return springs and early versions actually had springs holding the pistons against the rotors. As fuel economy became an issue the opposite became the norm and the rubbers O rings were redesigned to grip the piston as it was pushed out and then pull the piston back slightly after the pressure was fully released. These were known as low drag disc brakes and resulted in many customer complaints of low brake pedal. Next thing was the development of the quick take up master cylinder which cured the low brake pedal problem very nicely. Some aftermarket setups try and use a normal master cylinder and compensate for the lower pedal on disk brakes with band aid low pressure residual check valves. These valves are a cludge at best and a **** shoot at the results they produce.
    brEad and bct like this.
