the idea thread. voice em and comment on em
Discussion in 'The Hokey Ass Message Board' started by Bloodandmotoroil, Aug 3, 2010.
  1. Bloodandmotoroil
    Bloodandmotoroil
    You know... I’ve always wanted to make a set of heads that have crank that powers a second piston for secondary cylinder with the plugs and intake on the inside side and exhaust on the outside so the combustion chamber is between the two pistons and the secondary crank on top it chain driven by the bottom main crank.
    Kinda like bolting on another engine...
    Any clue if it would be a worthwhile idea?
  2. Unkl Ian
    Unkl Ian
  3. Bloodandmotoroil
    Bloodandmotoroil
    Any recommendations? Should I from scratch it or hack the top off a matching engine and build the rest?
  4. r8odecay
    r8odecay
    you mean like this?
    http://www.motorauthority.com/blog/1034049_former-vw-powertrain-chief-builds-super-efficient-engine
  5. freakboy
    freakboy
  6. CShroom
    CShroom
  7. Aaron871
    Aaron871
    I'd install a supercharger to help with the intake and exhaust flow.:D
  8. rocknrollratfink
    rocknrollratfink
    from LA
    :eek: You just blew my mind man
  9. Bloodandmotoroil
    Bloodandmotoroil
    sonofa*****.. seems it HAS been done before.. but not on a hotrod ... yet.
    i'll start with a straight 4 or 6cyl after that i'll give it a whack with a flatty 8.
    this will take some time, but i think it's worth it ... sides.. i want to hear how it sounds!... ought be odd and mean.
  10. treb11
    treb11
    yeah, thermal and mechanical innefficiencies will render is useless
  11. CShroom
    CShroom
    You know, it might be easier to use something like a lawnmower engine for testing. They are cheap, you can cut them up, and their simplicity means you might not have to work quite to hard to get a prototype together.
  12. Bloodandmotoroil
    Bloodandmotoroil
    you know, i should have thought of that first..
    thanks man, you might have just helped me a **** load.
    flyin' by the seat of your pants aint' easy.
  13. Bloodandmotoroil
    Bloodandmotoroil
    Well I have found that aluminum lawn mower engines explode real ****in pretty when you have too much compression. But it did work for about 2 seconds.
    Time for try #2, this time with pics and a vid so people know how I died. lol. Oh and I ought to check the piston clearance and compression... might keep my legs from catching any more shrap.
  14. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Bloodandmotoroil thanks for that idea on a caffeine high. I mean if it wasn't for the link to that sight I would still be trying to figure this out. Killer concept A+ to you.
  15. Never2low
    Never2low
    "You're crazy man. I like you, but you're crazy....":D:eek:
  16. BOWTIE BROWN
    BOWTIE BROWN
    make it run on moonshine , when it blows the colors are prettier
  17. Look up the Commer "knocker" engine. It's a diesel version of what your talking about. My local speedway has one as a water track, it's the loudest thing in the world you can hear it from miles away.
    Hayden
  18. Ruiner
    Ruiner
    And here all I want is a hemispherical combustion chamber with tri-oval shaped valves that contour to the chamber walls...the result would be larger valves while retaining a smaller high compression hemi chamber and with tri-oval shaped ports it would breathe nice and smooth instead of slamming air from round to square and back to round shapes...
  19. So, like a Fairbanks-Morse opposed piston Diesel, only run on Gas?
    Two stroke, of course.
  20. CShroom
    CShroom
    :eek:
    I bet that made your heart jump. I can't wait to see a video of v2.0. Just keep that compression a bit lower. ;)
  21. Bloodandmotoroil
    Bloodandmotoroil
    make it.
  22. Bloodandmotoroil
    Bloodandmotoroil
    I was thinking of using propane at first with the opposed cylinder mill.
    hey, any of you ever thought to add an expansion chamber to your exhaust and have a spark plug in it so instead of a normal flame throwing set up you get a mini pulse jet... would be... interesting.
  23. There was a car built in the teens that had this set up. It didn't work as well as expected but they also didn't have the higher technology back then.
  24. Rickybop
    Rickybop
    Whew...I thought this was gonna be another "inline six again" thread.
  25. Bloodandmotoroil
    Bloodandmotoroil
    exactly
  26. Bloodandmotoroil
    Bloodandmotoroil
    im thinking of dual exaust ports at he bottom of the cylinder and intake at where the chamber is, course i might be polocking it that way, lol.
    and the mind boggles at what would happen if i had the pistons timed wrong... hmm..
    should be simple to get right and i KNOW it's disastrious if i get it wrong.. or odd at the very least
  27. Bloodandmotoroil
    Bloodandmotoroil
    got a link to it?
  28. Ruiner
    Ruiner
    I don't have the resources to cast or machine something as complex as the tri-oval valved hemi...the valves themselves would be domes as well, essentially making themselves into 2/3's of the combustion chamber...lots of multi-axis CNC machining and grinding involved there, not to mention insanely expensive to produce on a m*** scale, which renders the concept moot...but still fun to think about...
