Hot Rods THE INDUCTION THREAD
Discussion in 'The Hokey Ass Message Board' started by mad mikey, Dec 9, 2016.
  1. de717f3b72768d5d400649114900ccf5--the-definition-of-toms.jpg Tom McMullen's famous roadster as he was installing a blown, and Scott injected 427FordFE . Wow.
    Stebo27, 1947knuck, enloe and 9 others like this.
  2. DDDenny
    Spike
    You (and others) don't need to be informed of this fact but for those that don't know it, many of the show cars of that era had what at the time was called "phony blowers", whether one, two, or six.
    mad mikey likes this.
  3. loudbang
  4. loudbang
  5. XXL__
    XXL__
    Fins and more fins...
    Stebo27, 1947knuck, enloe and 8 others like this.
  6. DDD, You are absolutely correct about the phony blower thing. I guess you may be referring to my mini-rant about the triple blower deal on that Barris monstrosity. No real attempt to even conceal the fact that it all is bogus, is the thing that chafes me so. At least, for a while there in the 70s-80s, there was a fad for wild street machines to have a 6-71 and injection poking thru the hood with a 4 barrel carb inside, and, the blower belt was hooked up to the crank, spinning the blower, if only spinning the front timing gears in the empty blower. These "street freeks", as they were called, at very minimum, LOOKED like they were working, even with the hood opened. Hiding a carb within the blower case is easily done. In the case of the Garlits Bugcatcher, you can even hide a carb within that injector hat. Phony or not, an attempt to make it appear functional, goes a long way to keep things interesting to me. Some show cars are never run, but at least they LOOK like they could, and that's the point.
    j-jock, mad mikey and loudbang like this.
  7. loveoftiki
    loveoftiki
    from Livonia,Mi
  8. 15e0d879c541fd0697e0e65fd200faf2.jpg What fun! Looks like a hot 4-banger, overhead valve conversion(?) with a v-8 converted distributor and dual strombergs. Very cool.....
    1947knuck, enloe, Jet96 and 7 others like this.
  9. 69396696.jpg IMG_3419.JPG Top photo is Ferrari Testa Rossa ( Red Head )SOHC with 6-two throat webers...lower photo here I am finishing up a 250 Same type of engine , SOHC, with 3-twos.
  10. img412.jpg SK-45 - Vic Edelbrock -Bobby Meeks - Don Towle.JPG I posted a snippet of this boat/engine previously, but here's the deal. The first photo shows Vic Jr standing at the Edelbrock dyno pointing to the very healthy, 12 or 13 to 1 compressioned 392 Hemi based powerplant.. In fact this engine held the record for a few years in it's cl*** ( SK ), fed by those eight 94s. The lower photo shows, left to right, Vic Edelbrock, Edelbrock's engine and Dyno man Bobby Meeks, and Edelbrock employee, boat owner, and hero driver Don Towle. I'm not sure I've ever seen an Edelbrock 8 carb Ram-Log manifold in person....perhaps this is a custom one-off fabrication done in house there.
    Stebo27, 1947knuck, enloe and 7 others like this.
  11. '51 Norm
    '51 Norm
    from colorado
    I am fascinated that Ferrari stuck the oil filter upside down on the top of the engine.
    Is there a check valve to keep the oil from draining out when the engine is shut off?
    How does one change the oil filter without dumping oil all over everything?
    The only one that I have seen in person was a 365 GT4 and that filter was upside down in the valley between the cylinder banks; to me a really poor place to put it. At least in the pictures of the 250 the filter is in a slightly better location.
    Deuces, j hansen and loudbang like this.
  12. loudbang
  13. loudbang
  14. 64 DODGE 440
    64 DODGE 440
    from so cal
    From the size of the lines and the routing of the line into the sump from the filter mount on the 250, is that a byp*** type filter as opposed to full flow?
  15. bchctybob
    bchctybob
    Thanks for the eye candy Loudbang. Except for the AN plumbing, that Studebaker flathead is niiice. Hell, they’re all nice! Even in B&W.
    loudbang, mad mikey and Deuces like this.
  16. silent rick
    silent rick
    you guys got anything filthy and grimy?
    my eyes are going chrome blind
    loudbang, '51 Norm and mad mikey like this.
  17. Deuces
    Deuces
    I'm sorry.... I was checking out the center p***enger...... :);):)
    loudbang and mad mikey like this.
  18. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    Who is this woman?
    Stebo27, 1947knuck, enloe and 4 others like this.
  19. seb fontana
    seb fontana
    from ct
    [​IMG]I notice two starter motors; could probably use them for p***ing gear in my Crosley!
  20. mad mikey
    mad mikey
    Large pop off valve also.
  21. There are a good number of filters designed with a membrane, that functions like a flapper, that allows oil to flow into the input side of the filter, and yet prevents the oil from draining back. It is designed this way, so that oil won't have to prime the filter on every start.
    Within a couple of minutes of stopping the engine for an oil change, most of the available oil from the outlet (center tube) will have drained, and there will be a minimum of mess.
    Here is an excellent link, with more information that you might care to know about filters.
    https://www.synlube.com/oilfilters.htm
    I use Amsoil filters, and one of the designs for inverted use, is the EaO37.
    Bob
  22. mad mikey
    mad mikey
  23. mad mikey
    mad mikey
  24. '51 Norm
    '51 Norm
    from colorado
    Thank you for the information. I guess that I am just used to seeing the oil filter on the bottom of an engine.
    enloe and loudbang like this.
  25. You are soo lucky! I just made the mistake of buying an O/T for a daily driver, that is fitted with a horizontally mounted filter on the bottom side of the engine.
    Just to do a filter change, is just about enough to drive an experienced mechanic nuts.
    My son's O/T supercharged truck, has the oil filter mounted upside down at the top of the engine. It has a little catch pad surrounding the base, and changing the oil and filter is a clean and easy project.
    A little good engineering goes a long way.
    Bob
  26. DDDenny
    By the looks of those hoses you have a squirrel problem too Mike.
    I just bought a braided stainless bbq hose, those little f#$kers won't chew through that one.
  27. Yeah, she is a cutie isn't she? You'll note the guy in, what I believe is a '36 Ford Cabriolet, behind these kids ,ALSO has his best girl next to him. I'm old enough to remember bench seats, and the thrill of crusin' around sitting next to your sweetie. I see too many guys today crusing with other guys. C'mon guys, get your girlfriend or wife and take them out for an ice cream......you'll be a hero to the guys who are just trying to impress other guys!
  28. 64 DODGE 440
    64 DODGE 440
    from so cal
    Amen Spike, the first thing I did to my '64 Dodge after I got it was replace the Mickey Mouse Nissan bucket seats the previous owner had put in it with a bench. The wife and I will have been married 53 years in January and we still like riding side by side and holding hands when we walk
  29. mad mikey
    mad mikey
