Hot Rods THE INDUCTION THREAD
Discussion in 'The Hokey Ass Message Board' started by mad mikey, Dec 9, 2016.
  1. saltflats
    saltflats
    from Missouri
    No just some I seen on Facebook for sale.
    mad mikey, Deuces and rod1 like this.
  2. saltflats
    saltflats
    from Missouri
    What's up with the fuel inlet on these AFBs never seen this before.
    Deuces, mad mikey and loudbang like this.
  3. wrenchbender
    wrenchbender
    not sure James but I can tell you that they are on a FE ford intake they seem do everything a bit different and probly will fail as FE stands for failure every time lmao
  4. saltflats
    saltflats
    from Missouri
    Your not giving Nathan much hope.
  5. saltflats
    saltflats
    from Missouri
  6. Jalopy Joker
    Jalopy Joker
  7. wrenchbender
    wrenchbender
    @saltflats that enderle barn door for a 4-71 is a rare piece I’ve only seen one in the last 30 years unlike the 6-71 style I’ve seen hundreds to run one of those units you needed one helluva engine under it the amount of airflow is almost too much even the hilborn units are a lot but manageable and all of the new EFI stuff can’t sustain that much airflow they have smaller ****erflies and throttle bores even though they are awesome and I would love to have one I could never afford and engine that could use that much airflow lol
  8. swade41
    swade41
    from Buffalo,NY
  9. saltflats
    saltflats
    from Missouri
  10. saltflats
    saltflats
    from Missouri
  11. seb fontana
    seb fontana
    from ct
    enloe and mad mikey like this.
  12. patsurf
    patsurf
  13. Fordors
    Fordors
    I think that is a Wico that was modified and adapted to the flathead by George Pounden. Pounden used Wicos magnetos and later produced his own too.
    enloe, Deuces, KiWinUS and 4 others like this.
  14. patsurf
    patsurf
    thank you!!--was thinking it was,cuz of the cap and that high tension wire..-about the only things not blurred out
    mad mikey likes this.
  15. DDDenny
  16. 55 gasser pickup
    55 gasser pickup
    from utah
  17. Jalopy Joker
    Jalopy Joker
  18. Paul
    Paul
    Editor
  19. saltflats
    saltflats
    from Missouri
  20. saltflats
    saltflats
    from Missouri
  21. patsurf
    patsurf
  22. saltflats
    saltflats
    from Missouri
    Doesn't look well thought out.
  23. saltflats
    saltflats
    from Missouri
    I put a little thought into mine. I ran this on my 360 inch small block Chevy in my 65 Chevelle. I sold it later at a swap meet and maybe a year or so later I seen it on this truck in a car show.
    KiWinUS, Kelly Burns, enloe and 3 others like this.
  24. seb fontana
    seb fontana
    from ct
    Doesn't look the same.:confused: My bad different direction....
  25. Paul
    Paul
    Editor
    looks the same to me
    it'd be easier to compare if both views were of the same end
    Hollywood-East and seb fontana like this.
  26. saltflats
    saltflats
    from Missouri
    It for sure is the same one. That project was my first time running a vertical mill and tig welding aluminum. It was built using a crossfire lower intake. I collected over 25 carburetors to come up with 4 the same.
    enloe, mad mikey, seb fontana and 2 others like this.
  27. saltflats
    saltflats
    from Missouri
  28. saltflats
    saltflats
    from Missouri
  29. Adriatic Machine
    Adriatic Machine
    That sounds like a Rockabilly band!
    “The *****in Bellcranks”
    enloe likes this.
  30. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    Yes they are, anyone have info on where a guy might get some? I'd have to throw my fabricated ones in the junk!
    Denny, do you think someone may have cut those out of plate and made them look like castings?
