Technical THE INFAMOUS X-SHIFT TRANSMISSION
Discussion in 'The Hokey Ass Message Board' started by Frames, Jan 14, 2024.
  1. Frames
    Frames
    Uses Saganaw 3 speed gears and reverse. I think the case was manufactured by Offenhauser. Uses a 38 Chevy cover. I have one in my #45 supermodified. Milled off the rear housing and used a doubled sheild bearing. Shortened the tail shaft to use a Ford 42-47 P U rear end yoke and 42 and later 3/4 ton Ford open driveshaft. 2014-12-07 09.54.54.jpg 2014-12-07 09.55.30.jpg 2015-01-20 13.58.36.jpg 2019-10-26 15.35.51-3.jpg I used a large tube for a safety shield. The next vintage race car I build build will have a closed drive line. Sprint car style made with early Chevy parts and a Ford splined U-joint.
    Carter, vtx1800, LOU WELLS and 5 others like this.
  2. squirrel
  3. Rickybop
    Rickybop
    Man. You guys with machine tools. You don't have to be nearly as concerned with what fits/works as the rest of us do. You just make it fit/work.
  4. Infamous transmission ehh? Must be the gear ratio. Hehe.
    ProtoTypeDesignFlauz likes this.
  5. Frames
    Frames
  6. Frames
    Frames
    AndersF, VANDENPLAS and lumpy 63 like this.
  7. Frames
    Frames
  8. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    That was going to be my question as I looked at your pics. Having experienced a driveshaft explosion I was happy my shield held together.
    GuyW likes this.
  9. willymakeit
    willymakeit
    Whats worse is having a mill ,lathe combo and not knowing how to use it. At least I look impressive when in shop.
