The lets getting it running Thread!
Discussion in 'The Hokey Ass Message Board' started by lx450landcruiser, Apr 10, 2012.
  1. lx450landcruiser
    lx450landcruiser
    from wa
    Ok consider me a newbie, esspecially with the older cars.
    What I have here is a 29 model a briggs all stock. Motor hasnt run in a long time.
    Turns over freely good compression, cleaned it all up and changed the oil. Installed new plugs, plug wires, cap, rotor, modern style points, and a new coil with the internal ballast resistor. New wiring as well running on 12 volts. I pulled apart the carb and sand blasted the housing and cleaned all internal parts.
    Now She turns over great and I have an excellent spark on all 4 cylinders yet the motor still doesn't seem to want to fire. I suspect something with the carb as the motor never even fires once and it appears the carb leaks a bit of fuel.
    Maybe too much fuel? Doesn't seem like too much to go wrong with the Zenith 1 carb but again I'm new to it so is there something I could be missing?
    Any tips would be great
    Cheers
    Mike
  2. Check for vacuum leak, timing off, bad fuel mixture .
  3. outlaw256
    outlaw256
    look for sand in there!! is it flooding or starving for gas?are the plugs wet. tell us more.
  4. lx450landcruiser
    lx450landcruiser
    from wa
    I pulled the carb again blew everything out. Looks clean. I beleive its flooding the motor but Im not sure whats causing the issue.
