Jive-Bomber submitted a new blog post: The Lincoln 337 c.i. "FAThead" Continue reading the Original Blog Post
Great Story. I didn’t realize they weighed 800 lbs. and I thought Hemis were heavy. I never new they existed until I saw this in a coupe at TROG a few years back. I had to ask the same question “what the hell is that” and the owner gave me a quick lesson. And now I want one
Sorta like a down tempo regular flatty, but with a bit more b***...? Now it begs the question supported by "no replacement for displacemnt" of how big can a regular ol flatty go and still live? I think I've seen 286 (?) bored and stroked. Is that it? I'd also think that even though the no replacement theory above is in play that big heavy m*** floppin around in that block likely stops aspirations of a high zoot 337. Enter the Caddy and Olds OHVs, then of course hotrodding's most hated. Still, kool stuff...
Several years ago a customer brought me one of those motors backed up by a 3 speed OD trans to put in a 32 ch***is he was wanting for a deuce 3 window he had found in Mexico. I fabbed the ch***is and when we went to lift the motor into the ch***is for a fitting we had to hang a couple 125 lb tractor weights on the lift for balance. I got the job done and waved goodby and he finished the car. About a year ago the ch***is showed up here on the HAMB with the motor included. It was yellow and the motor had the rare finned heads and a multi carb intake. I've been curious as to where it ended up?
With the advent of stroker cranks for **** and the like, 304's are about the limit these days, although I have heard of bigger ones; ya gotta be brave, though.
In other news, when the failure rate of the 12s 48 and older was getting common postwar the 337 was one of the recommended fixes along with the Caddy or Olds OHVs. Some even used early Hemis later on but a Caddy converted Zephyr or Continental isn't unusual.
That's how George Hurst made money before floor shift conversions. All of the dead V12 Lincolns were his inspiration for making mounts for engine swaps.
Bruce Wanta's "Reimangined" 1934 Edsel Model 40 Speedster ... built by @hhrTroy Ladd & his team (including @******) at Hollywood Hot Rods: ... features a 337ci Lincoln Flathead (with AUSTIN heads) ... built by H&H Flatheads {Mike @Capitan Insano Herman}:
I'm wondering why someone would remove the ch***is and sell it. Why they didn't just drive it and have some fun.
The buyer of the yellow Lincoln powered 3 window contacted me to see if I had any interest in the ch***is. Apparently he bought the car just for the sheet metal? The original builder called me once to tell me how much he enjoyed the car and how much conversation the motor caused.
Seems to be a thing for some people. There was that build on here where a guy bought a real nice restored deuce coupe and only used the body.
It's ironic that both the Lincoin V8 and the V12 both come out to 337 C.I. Does anybody by chance know the bore and stroke of each engine? I would think the V8 had bigger cylinders since there's four less of them.
The 'Lincoln Zephyr V12 was a 75° V 12 cylinder engine introduced by Ford Motor Company's Lincoln division for the Lincoln-Zephyr in 1932. Originally displacing 267 cubic inches, it was also manufactured in 292 cubic inches and 306 cubic inches displacements between 1940 and 1948 ... but never in 337 cubic inches. The largest displacement version (at 337 cubic inches) of the production Ford flathead V8 engine was designed for large truck service. When Lincoln could not produce the V12 engine it wanted for the 1949 model year, the 337 engine was adapted for p***enger car use. The 337 features a 3.5 inch bore and a 4.375 inch stroke. It was introduced in the 1948 two and a half ton and three ton Ford trucks and the 1949 Lincoln p***enger cars. It was produced through the 1951 model year.
I remember the first time i saw an av8 with a cad flatty, you could see from 60 yds away that it wasnt your average flathead. Then when i discovered the 337 i knew that was what i wanted to run in my roadster, too wicked
To be honest, so did I ... but then I Googled it ... and a (sometimes reliable) website told me otherwise
@2muchstuff owned that car for a while. I know he took it to the Hot Rod Hillclimb one year. Maybe 2014? Such a neat car!
I own it now, got it a few months ago. Getting ready to tear it down for a repaint to get rid of the yellow. Got a steel roadster body for it. Would like to talk to you about the ch***is.
