The Low Buck Bagged Binder
Discussion in 'The Hokey Ass Message Board' started by C4 Metal Werks, Jun 30, 2008.
  1. C4 Metal Werks
    C4 Metal Werks
    That's the wifes hand.
  2. C4 Metal Werks
    C4 Metal Werks
    No. But I think it will be fun.
  3. C4 Metal Werks
    C4 Metal Werks
    Finally got a chance to work on the truck this week. I got the engine moved back 4"(no pictures yet) and got the rear frame rails cut off and one of the new ones made. I also got the cab mounted and the steering column loosely installed.
  4. 46binder
    46binder
    from Kenosha,Wi
    Thats the original ignition key, don't know why they were made by Briggs and Stratton though, its just like mine.
  5. C4 Metal Werks
    C4 Metal Werks
    Very cool. Thanks for the info.
  6. C4 Metal Werks
    C4 Metal Werks
    We learned tonight that it is the original key.
  7. C4 Metal Werks
    C4 Metal Werks
  8. quandel_garage
    quandel_garage
    looks cool I like it
  9. hillbilly
    hillbilly
    I've driven several RHD vehicles when I was an intern mechanic at a local Dodge dealership...couldn't figure out why people didn't like driving them? It took a bit of getting used to, but wasn't bad...
    except at drive-thru windows...
    ...and police roadblocks.
    The project is coming along nicely :D
    Good Job
    Mark
  10. C4 Metal Werks
    C4 Metal Werks
    Thanks!!!:D
  11. C4 Metal Werks
    C4 Metal Werks
    Got the rear frame welded on today.
    And here is a picture of the front cab mount.
  12. Kona Cruisers
    Kona Cruisers
    you run radir Vw rims. in the photo shop. and RHD you have to come from the VW world yes?
  13. OshkoshRob
    OshkoshRob
    from Oshkosh
    I was thinking the same thing.
  14. thirty7slammed
    thirty7slammed
    from earth
  15. I think that head stamp on there is from a 305. 327's are great engines though.
    Tough as nails just like a 283.
  16. Casting #3782870 crosses over to '62-'65 327 with 250-375 horses. The head marking is the good old "power pack", which would possibly be the originals, but would make it the lower horse version, as anything else would have camel humps.
  17. Dyce51
    Dyce51
    from Ohio
    that rear frame section is killer!!! nice work!!!
  18. C4 Metal Werks
    C4 Metal Werks
    Thanks for the compliments and the engine info. I got some more work done this weekend. The steering mount/frame rail is tacked in place, got the grill and right front fender lined up and I found a seat at the junk yard out of a mid 80's Ford Ranger.
  19. C4 Metal Werks
    C4 Metal Werks
  20. thirty7slammed
    thirty7slammed
    from earth
    Hey C4 very cool build, Im interested in the frame mod's at the steering box, Im pretty sure that's for radiator clearence, are you going to lengthen the drag length?
  21. C4 Metal Werks
    C4 Metal Werks
    Thanks! The steering box is out of a late 80's Toyota truck. In going right hand drive I had a choice of 2 boxes. This one or a Chevy C10. The C10 is about 2" longer and space was a problem. I cut the frame completely of forward of the cross member so I could get the steering box to clear the upper control arm and the exhaust manifold. I will use a 64-66 V8 Mustang radiator or an after market 4 core I found that is 13.5 tall and 21" wide. It will fit perfect above the steering box. It came off of a 4X4 with a small block Ford. I will use a GM metric ch***is center link which is a bit longer than the S10.
    Quote: "Hey C4 very cool build, Im interested in the frame mod's at the steering box, Im pretty sure that's for radiator clearence, are you going to lengthen the drag length?"
  22. C4 Metal Werks
    C4 Metal Werks
  23. C4 Metal Werks
    C4 Metal Werks
    Right hand drive steering is done, Finished the column mount.
    Started building my own Ansel style pedals.
    Using an early 60"s Chevy truck dual cylinder for brake and clutch pedal.
  24. Chuckles Garage
    Chuckles Garage
    Alliance Vendor
  25. C4 Metal Werks
    C4 Metal Werks
    Worked on the pedal ***y. some more today,
  26. C4 Metal Werks
    C4 Metal Werks
    More work done on the pedals. Pivots machined and bronze bushings installed.
  27. C4 Metal Werks
    C4 Metal Werks
    Ya. I've been building VW's for many years. I'm enjoying the American stuff a lot more.
  28. pinstripebob
    pinstripebob
    from Carmel, IN
    Oh so that VW is yours? Someone I know is building a Bonneville racer out of a Bug, and he had some pics of that thing on his blog once as inspiration. That thing is sick!
  29. Look'en cool so far, keep up the work and post updates.
    Cooter
