Projects The Magneto Resurrection
Discussion in 'Traditional Hot Rods' started by Ryan, Aug 28, 2025.
  1. Ryan
    Ryan
    ADMINISTRATOR
    Ryan submitted a new blog post:
    warbird1, slim38, Sharpone and 6 others like this.
  2. Outback
    Outback
    from NE Vic, Oz
    Thanks for your work around here, so glad this mag is moving forward looks great polished!
    Sharpone, 41 GMC K-18 and porkshop like this.
  3. 48-760
    48-760
    from OH
    Believe the drive may have been repoped but about $350.
    Sharpone and porkshop like this.
  4. Ryan
    Ryan
    ADMINISTRATOR
    I know. Speedway. Does that price not seem crazy? I think it seems crazy.
  5. patsurf
    patsurf
  6. 5window
    5window
    Great post. You should write under a short deadline more often. :)
  7. 41 GMC K-18
    41 GMC K-18
    No doubt, that polished case will exude some positive energy!
    But as usual, the tiny details of what goes on inside of that case, can be complicated, but then again you are fully aware of that!
    Be safe out there as you fly through the sky!
  8. Tim
    Tim
    from KCMO
    That’s gorgeous, hopefully a drive pops up or at least one to borrow and have one machined.
    41 GMC K-18, porkshop and Sharpone like this.
  9. Sharpone
    Sharpone
    That price is crazy! IMO However having a machine shop make one would be costly also, maybe cheaper but not a lot I’ll bet.
    Dan
  10. Tim
    Tim
    from KCMO
    I think in my head the options for machine shop are less commercial shop and more one of my dozen friends who have a lathe and a mill. Or the extreme opposite, you make it a file and send it to send cut send and you’ll have one in moments with the capability to have a dozen more if needed.
    they (send cut send) are also setting up a marketplace so if you make a little bracket or part and want to offer it for sale the public can then order it and they make and send it. Very similar to print on demand publishing
    Outback, 41 GMC K-18 and Sharpone like this.
  11. Fordors
    Fordors
    Will Send Cut Send have a dividing head, correct cutter and a mill to cut the splines on the OD of the drive spud and a broach to spline the ID of that collar? Is that drive also heat treated? It’s a small part but not every back yard machinist has what’s needed to produce it.
  12. patsurf
    patsurf
    does anyone have the spline count and diameter handy?
    Sharpone and 41 GMC K-18 like this.
  13. Tim
    Tim
    from KCMO
    Good catch on the splines! I clearly didn’t look close enough. But yes I think they may actually offer all of that.
    I think hunting an original is probably the most cost effective route, but most will probably just **** it up and pay speedway.
    Thinking about all the heat treat etc I bet the machine shop in Kansas City that we stopped at the last time you were in town @Ryan could knock it out. They do gears/ splines etc all day
    Outback, Ryan, Sharpone and 1 other person like this.
  14. Jack Rice
    Jack Rice
    What a nice piece of jewelry. That polish job is impressive. Best of luck finding a mag drive.
    Outback, Sharpone and 41 GMC K-18 like this.
  15. Kevin Lee
    Kevin Lee
    Super Moderator
    Looking objectively at the whole scene… what that thing actually is, the number of operations needed to make it correctly, and the extremely low demand for such a part I’d say you’re lucky to find *anyone* producing them. And even more lucky to only be paying 300 and change for one. But that’s only my mood this moment—could change within hours
    Xman, Fordors, 41 GMC K-18 and 2 others like this.
  16. Clydesdale
    Clydesdale
    Gotta agree, that’s a very complex part with a bunch of processes for a very very niche market.
    I guess sometimes you just gotta **** it up unless you want to invest in a batch run and recoup your costs by selling the rest.
    Outback and Sharpone like this.
  17. alchemy
    alchemy
    Are the splines a standard size? Would the collar be readily available, maybe longer needing cut to length? The external splines are much easier for a regular guy to cut on his mill. Then weld the head on it and mill the offset tangs. See? A backyard guy could have it done before lunch.
  18. patsurf
    patsurf
    i have asked exactly that-is there splined matl. that could match-pump shaft,etc..
