Projects The "Matt's 27 T Modified" Build Thread
Discussion in 'The Hokey Ass Message Board' started by mattblack52, Sep 12, 2010.
  1. mattblack52
    mattblack52
    from Ohio
    I sleeved the bones in that area. Not sure of the material thickness but it was pretty damn thick tubing. Should be fine, lots of people do this. It's sleeved all the way through the bones and welded on both sides.
  2. nightperson
    nightperson
    how do you mount the radiator on a set up like that? i like how the frame is behind the shell.
    seems you would have to make mounts that go from the radiator back to the crossmember?
  3. Boones
    Boones
    from Kent, Wa
    I am ending up with about 17.5 inches wide at the radiator on my modified, a little wider would not have been bad. I am going to narrow a 28/29 shell
    I am curious on how you plan to mount the radiator and shell on yours
  4. spot on stance, dude. dont change a ****in' thing!!!!...well, maybe clean er up some...
  5. nightperson
    nightperson
    i am curious about mounting the rad and shell as well
  6. falcongeorge
    falcongeorge
    from BC
    Really looks good. The only way I would use a deuce shell on it, is if you are gonna do a full hood.
  7. Nice lookin build, any updates
  8. Harrison
    Harrison
    Great looking little car.
    I like the jack stand gas tank mounts especially. ;)
  9. 40coupefan
    40coupefan
    from Trumann,AR
    Harrison, I think your sister is cute!
  10. grits
    grits
    Thats a nice looking T you got there bub.
  11. Will Kimble
    Will Kimble
    Looks killer!! I know you didn't ask but my vote is for a T radiator / grille shell. I gotta stop by and see these things in person!
    Will Kimble
  12. mattblack52
    mattblack52
    from Ohio
    Yeah the radiator will sort of float. I will build tabs off the front of the frame to mount it to.
  13. mattblack52
    mattblack52
    from Ohio
    Thanks for noticing...it spent some time in a warehouse after I built it and I haven't gotten around to sanding it down again.
  14. mattblack52
    mattblack52
    from Ohio
    Thanks Will, I think I'm stickin with the A grille tho. I'm close to starting the flatty up for the first time. Hoping everything goes smooth.
    UPDATE:
    I got the factory aluminum heads back from the machine shop. Had 'em milled down a bit. I have to repair my intake manifold, the bolts ripped out at one time. I'll prolly fill 'em back up with the TIG and retap.
    Cleaned up the dizzy and set the points according to Van Pelt's web site. Not too hard, everything inside looked good.
    I've also been cutting a lot out of the body. A lot of the subframe was rotted and I needed to lower the seat pan. I also need a cage system up under the cowl to mount my steering to. Stay tuned, I have a plan for that...
  15. mattblack52
    mattblack52
    from Ohio
    More has come apart on the body than has gone together. But I hear her take a sigh of relief every time some crusty piece gets cut off.
  16. Minewithnoshine
    Minewithnoshine
    Hopefully the body starts going back together tomorrow! It looks MUCH better now that it's all DA'd.
    For anyone wondering where there aren't any braces in the body, it was hit at one point so re***embly will be realigning many of the panels to fit right. Don't worry, this one will be getting a nice black lacquer job on it.
  17. Malcolm
    Malcolm
    from Nebraska
    Great build!.. I really like the direction of this one -- keep it up!
    Malcolm
  18. Will Kimble
    Will Kimble
    Looking GREAT, lemme know if you need somebody to stand around, heckle and drink beer when you start it!!! LOL.
    Will
  19. tjm73
    tjm73
    Kick ***! Love T's. Keep the pics coming.
  20. Minewithnoshine
    Minewithnoshine
    Hey Will, stop on over any time you want, we're always there!
  21. mattblack52
    mattblack52
    from Ohio
    After 3PM if u expect to run into Brian LOL
  22. daddio211
    daddio211
    Time for an update Matt!!! Don't leave us hangin' bro!
  23. mattblack52
    mattblack52
    from Ohio
    More is coming soon. Lost my day job and just got back on my feet. Updates soon.
  24. El Hueso
    El Hueso
    We are patiently waiting. Nice work. Now I have to rethink some things on my '27. Keep it up!
  25. mattblack52
    mattblack52
    from Ohio
    Alright got some stuff done on the T. Got the frame all cleaned up (needed a lot more than I thought.) Mounted all the shocks. Running Houdaille (I think that is correct?) shocks in the rear and friction shocks up front. I'm still waiting for a few parts to be lasered out for the front shocks but they are pretty much done.
    Bought a new firewall. The old one was hit at some time and twisted the whole front of the car. A new firewall should do the trick.
  26. mattblack52
    mattblack52
    from Ohio
  27. mattblack52
    mattblack52
    from Ohio
    New firewall and radiator came in the other day so steering will be getting done real soon and hopefully start putting some panels back on that body...looks like **** right now.
  28. murpa
    murpa
    from .
    sweet! im in the middle of building one my self i love what you have done.
    not alot of room in side inside is there.
  29. mattblack52
    mattblack52
    from Ohio
    No not much room to work with. Working on the clutch, pedals, and steering hoop now. I think I've come up with a way to maximize space.
    I'm average height (5'10") and if I don't sit with my back all the way against the back of the body the pedals would be sticking out of the firewall.
    I'm also setting the seat all the way down almost even with the floor. Otherwise you sit so damn high in those things people driving behind you can see what brand of jeans you've got on.
  30. Boones
    Boones
    from Kent, Wa
    you are right not much room in them. not made for riding in as much as riding on..
