Hot Rods The (mis) Adventures of a Compulsive Tinkerer
Discussion in 'The Hokey Ass Message Board' started by bchctybob, Apr 13, 2024.
  1. bchctybob
    bchctybob
    With the holiday and family in town shop time was limited but yesterday I made an executive decision to install the Chrysler and build front motor mounts for it based on the old Hurst mounts. The Buick mounts will be built to sit on the same pads as the Chrysler. I removed the transmission mount from the tube crossmember so it’s just a blank. My shop is sorta crowded so I rearranged everything so I can lift the Hemi and install the transmission adapter and trans.
    I need to weld nuts on the inside of the boxing plates for the new crossmember and I need to get the engine where I want it so I know where the crossmember goes. I’ll finish fitting the other boxing plate and tack them in place. It’s like dominos, one thing after another, and I find that it’s easy to get ahead of myself.
    That thing’s a monster, but it looks like it will fit fine. (Not sure about the 3” blower drive though) Lol
    Outback, choptop4, Deutscher and 10 others like this.
  2. bchctybob
    bchctybob
    I cut and fit the Trans-Dapt crossmember to fit where my measurements told me it needed to go. But there’s a little problem….
    Yeah, if I use a Vega box, with the crossmember in the right place the steering box is 1” farther back than it needs to be to have the drag link and tie rod parallel. This is all by my dubious calculations, so it could be better or it could be worse. I have a pitman arm coming so I can figure more accurately. Nothing like having the parts in your hand so you know for sure what you can do with them.
    I could always go the full old school Hurst method. I have that option…..
    But I like to use a bolt in crossmember when I can because it leaves you with a clean slate if you decide to swap engines in the future. (In this case the Pontiac would get a new crossmember farther back and this one would be removed) And no unused protruding brackets to deal with.
    I guess I could also contact the gentleman who rebuilds early Ford steering boxes and see what he recommends for a standard drag link steering box for a ‘33-‘34 ch***is. I’m not married to the Vega steering, it’s just usually easier and works good.
  3. bchctybob
    bchctybob
    I’m waiting for some stuff to be delivered so I decided to not be lazy and mock stuff up just to be sure. I got the adapter and my TH400 case bolted to the back of the Hemi.
    9DD2CD6D-36F6-4A57-936D-903153455352.jpeg 06FFF87D-8D51-4B7D-BA14-8C840D74C471.jpeg
    Then I dropped it in for a sanity check. Turns out my measurements were right on the money. Right in the middle of the slot, only the height was in question.
    With that behemoth sitting in there, it’s hard to think of using anything but the Hemi…..
    I’ll have to dig up a couple extra leafs to add to the front spring. Lol
    Outback, mad mikey, mohr hp and 12 others like this.
  4. Budget36
    Budget36
    Damned Bob, I was out back pulling a fence down while you were in the shop. My feet and hands are still numb.
    Tell the truth now, your area is heated?
    If not, I’m going into hiding until April;)
    Outback and porkshop like this.
  5. Jacksmith
    Jacksmith
    from Aridzona
    That is a handsome mill!
    Outback, porkshop and Budget36 like this.
  6. bchctybob
    bchctybob
    Budget36: Yeah, I’ve got two mini-splits, one at each end of the shop. In spite of the tall roof, in 15 minutes I have to turn one off or it gets too warm. It was 44 degrees out when I finally got out to the shop.
    Jack; the Donovan valve covers give it a no nonsense, hard core look. I’ve got chrome FirePower valve covers too. I’ve got an as cast Mooneyham 6-71 for it but I told myself no more blowers on my street driven cars. I have a nice polished Weiand 2x4 intake that I’ll probably use but it’s nowhere near as impressive looking.
    I dunno, in for a penny, in for a pound. Right?
    Outback, Thor1, Deutscher and 7 others like this.
  7. Jacksmith
    Jacksmith
    from Aridzona
    Well, Bob, I believe that in some cases restraint is the threshold of cl***. I'm growing out of the shock of extreme phase and easing into the beauty of subtlety.
  8. bchctybob
    bchctybob
    Yeah, I thought I was too, then I set that thing in there. Funny thing though, it’s got a mild cam and it was pretty docile until you jumped on it. It was a great ski boat motor. I made an adapter and put a Powerglide behind it in the boat so I had two speeds but more importantly, I had a soft Neutral without crashing the V-drive gears in and out. In the transmission neutral there was enough parasitic drag that the boat would still creep forward at a No Wake speed. Then I could set the idle a little higher to get the off idle response a little smoother.
    Outback, SS327, Thor1 and 4 others like this.
  9. bchctybob
    bchctybob
    Santa arrived a little early this year.
    I got my brand new 9” housing and axles delivered yesterday. I need to install the axles and measure to be sure that they sent me the right width. I think I’ve got brakes for it but I’ve got to find a 31 spline third member or rebuild the one I have.
    I also got my BBC to 392 water pump adapters. They are from Stanke, nice pieces. I just had to put them on and see if I could possibly use my old Nicson front cover. Nope. Even cutting off the water pump boss and some of the fins it’s too thick. I could machine both sides and maybe get there but, nah. I ordered one from Hot Heads. Also a new damper.
    I’m still up in the air about the steering box. I dug out an old F1 box that I had but I need to remove the boxing plate to get it into the right position to see how it fits.
    It’s been a busy few days and it looks like my shop time will be limited this weekend too. Appointments Thursday and Friday and a family affair on Sunday. Sheesh….
  10. bchctybob
    bchctybob
    I like how the F1 box fits and leaves the motor mount area vacant. I also like the traditional look better than the more modern Vega. However, I honestly don’t remember what it’s like to drive with the F1 steering. My ‘55 F100 had stock steering when I first got it but the box was pretty thrashed and I went with Toyota power steering. Thinking back, my hot rods have all had Vega or Mustang steering boxes, even back to the ‘32 I built in the 70s. My T coupe had an F100 box but I never drove it.
    So I’m looking for impressions, how does driving with the F1 box compare with the Vega or Mustang boxes? Anyone?
    Thor1 and porkshop like this.
  11. SPEC
    SPEC
    I would install the Radiator to see if you have room for a Fan!!
    porkshop and bchctybob like this.
  12. bchctybob
    bchctybob
    It should be fine according to my measurements but just to be sure, I have a timing chain cover and a damper coming from Hot Heads to mock everything up together.
    On the ‘33-‘34, the radiator sits completely in front of the crossmember on brackets yet to be made. Since the cab is channeled 2 1/2” the radiator and grille shell will also be lower, so I didn’t leave the stock radiator mounts in place.
    Outback, Thor1 and porkshop like this.
  13. Greg Rogers
    Greg Rogers
    Go Man,Go!!!
    bchctybob likes this.
  14. bchctybob
    bchctybob
    So, back to the Pontiac for a bit. (Waiting on a couple Hemi parts) A while back I ran up to Sacramento to pick up an Edelbrock EP4B and the guy had an oil filter adapter too so I bought it. He said that it came from a ‘64-65 GTO. I cleaned it up and installed it. The other day I got a filter for it so I decided to put some oil in the engine and prime the oil system. I poured some oil in the filter and tried to screw it on. Nope?? The body of the filter hit the gusset cast into my ‘62 block.
    I marked the interference and thought about grinding away the marked area, but nah….
    I did a little experiment with some washers to see how big of a spacer I would need to make the filter clear. Then I made a spacer from 3/8” aluminum plate. I no longer have a mill so I used my Sawzall, drill press and a few files. I also made thicker gaskets.
    It came out pretty good. It’s close to the adapter but it clears….. The reality is, it won’t fit in the Stude pickup like this, it needs a remote oil filter so this is just so I can run it on the stand.
    So now I just need to find my oil pump primer shaft and see how the oil flows. Then get the flex plate and starter to play together so I can crank it over to be sure the lifters spin like they should.
  15. bchctybob
    bchctybob
    The next hurdle….
    The beautiful grade 8 bolts that came in the kit with the adapter are about 1/4” too long. They go through flexplate, crank adapter and the crank flange and hit the block. I’m glad they are obviously too long (the washers never clamped up). If they had clamped the washers and hit the block it might not have been noticeable until I tried to crank it over. I’ll cut em down and torque em up.
    I’m also going to fit-check the torque converter. I’ve had to thin the bolt heads before due to interference. Nothing is easy….
    Thor1, Outback, guthriesmith and 6 others like this.
  16. bchctybob
    bchctybob
    Not everything has been a pain in the a$$. I found this beautiful Offenhauser 5162 dual quad manifold on eBay, I couldn’t resist. No wallowed out bolt holes, no amateur porting, no corrosion, perfect.
    It was missing the two carburetor adapter plates but I have several Offy manifolds with the plates (and they are still available) so I used the missing plates as a a bargaining point and got a significant discount. I have an Offy 2x4 that I set up for the earlier ‘55-‘60 heads already with two fresh AFBs and linkage. I can use those carbs.
    I will still probably break it in with an Edelbrock EP4B and a stock carburetor just to avoid any tuning problems during the cam break-in period. I sure like having choices though - 1x4, 3x2 and now 2x4.
    I’ve blown my allowance lately, I gotta dig up some stuff to sell….
  17. Jacksmith
    Jacksmith
    from Aridzona
    Another terrible idea... love it! That manifold is pure art and looks *****IN'!
    Outback, bchctybob and porkshop like this.
  18. bchctybob
    bchctybob
    Thanks. I’m used to buying stuff on the cheap and doing some repair, this one is pristine but missing a couple pieces. I still have to build up a couple secondary carburetors for my 3x2 setup so it will be complete. It’s nice to have them cleaned, serviced and bagged up, ready for action when the urge strikes.
    Outback, rod1, SS327 and 2 others like this.
  19. Jacksmith
    Jacksmith
    from Aridzona
    I hear ya... when I scored my N.O.S. 2x3 manifold for the Olds, I had Thumper foot 'til I could get it up & runnin'... nuthin like new cast aluminum to wipe yer blues away! Offenhauser 3 Stromberg Manifold.jpg
    porkshop, Thor1, Outback and 7 others like this.
  20. choptop40
    choptop40
    Homina Homina Hemina Hemina..great thread..
    porkshop, Outback, bchctybob and 2 others like this.
  21. bchctybob
    bchctybob
    Thanks, working on the cars is fun but taking pictures and posting adds another dimension, not to mention some much needed motivation. Lol
    Yeah, I’ve always been a big fan of aluminum castings. That Olds manifold looks perfect, so it’s NOS? Hasn’t Offy made a run of new ones in the last few years?
    porkshop and Outback like this.
  22. bchctybob
    bchctybob
    I shortened the flywheel bolts for the Pontiac by 3/16” and they work fine now. I’ll get the starter swapped out and I’m another step closer to firing it up.
    I made the executive decision to go with the old style Hurst frame mounts instead of the crossmember mounts. My new biscuits came today from Roadster Supply. So I did some measuring and trimmed the frame mounts to fit. They make the whole installation simpler and there’s no issue with either steering box.
    That’s the new Hot Heads timing chain cover. I’m still waiting for the new damper to arrive so I can finalize the engine position.
  23. Jacksmith
    Jacksmith
    from Aridzona
    Not sure if Offy ran a new batch of old castings or what... The add said N.O.S., so it must be true, right? Ha-ha, but it's just what the doctor ordered and made the engine in my eyes. B.T.W., those mounts are great!
  24. bchctybob
    bchctybob
    Thanks Jack. I don’t remember where I got them but they were bigger and of thicker material than most I had seen. I cut 2” off of the frame side, they were pretty big.
    That intake looks great with the Oldsmobile green and the clean, natural carburetors.
    porkshop, Outback and Jacksmith like this.
  25. ekimneirbo
    ekimneirbo
    from Brooks Ky
    I was looking at your fender picture again. A while back, @krylon32 gave me a tip for my 32 to raise the "duckbill" at the rear of the fender. I was going to cut it off and weld it on shorter so it paralled the frame somewhat and didn't stick back as far. He said that people cut the front of the fender and rotate it and get the same result. Thought I might mention it to you as some "food for thought". :)
  26. Outback
    Outback
    from NE Vic
    Great thread, thanks for keeping us in the loop!
  27. bchctybob
    bchctybob
    I’ll look at rotating the rear fenders like you suggested. Since everything else has been modified it might look better with the back of the fenders cleaned up. One rear fender is really nice and the other is a little rough, I’d like to get another pair and keep two stock. Even fibergl*** is ok with me.
    Outback, porkshop and Algoma56 like this.
  28. bchctybob
    bchctybob
    I got my new Hot Heads damper today, nice piece. So I made sure the crank shout was clean and de-burred and oiled everything lightly. I had to push it on with my damper tool. I didn’t buy their bottom pulley - it’s billet aluminum and I’m cheap so I went upstairs to see what I had in my pulleys and accessory drive box. I got down several candidates (all Chevrolet) and tried them against the damper. Most had too many holes and in all the wrong places but one looked encouraging. Before messing it up I decided to look it up on the internet to make sure I wasn’t ruining a super rare pulley from some limited edition high performance Corvette or something. It’s just a garden variety big block Chevy bottom pulley, average price $35-65 on eBay. Ok. But I do have a 375 hp 396 under the bench, should I save it for that? Nah….
    I ground the index register off of the backside so it could sit flat on the Mopar damper. I enlarged the center hole about 0.030 to fit the male register on the damper and elongated three holes for the bolts. The Chrysler damper has six bolts and I’ll drill the remaining three when I pull the damper to finalize the timing chain cover installation. Everything is in place and everything clears nicely.
    They don’t align perfectly but I can make adjustments when it goes together for real. There’s just enough room to fit a 2” blower pulley in there too.
    So with things fitting together well I can commit to actually welding some stuff in. I’m going to note some final measurements and take some pictures. I don’t want to get ahead of myself and weld stuff only to find that I shoulda done this or that first. Progress!!
    brad2v, Thor1, Moriarity and 9 others like this.
  29. Moriarity
    Moriarity
    SUPER MODERATOR
    Thanks for not using a billet alum pulley. I see way too many of those on here the way it is.... Good job man, carry on
  30. bchctybob
    bchctybob
    Ha, ha, ha….yeah I looked at their pulley when I was looking at the dampers. Thought, nah, I’ve gotta have something in the box upstairs that will work. I would rather have had a single pulley but this one worked out fine. I love it when I can use up some of this junk I’ve been tripping over all these years.
