Projects The Model A Flathead truck build...
Discussion in 'Traditional Hot Rods' started by OoltewahSpeedShop, Nov 24, 2013.
  1. OoltewahSpeedShop
    OoltewahSpeedShop
    This is a project we've been collecting parts for a few years on.... So here it goes.
    The plan is to use as many old parts as possible. The only concessions will be reliability.
    Early '31 truck, full hood, fenderless, Merc flathead, 3-speed, banjo, 4" chop, dropped/drilled axle, '40 wheels, Coker tires, juice brakes, & shiny paint. You get the picture...
    The updates will come at random as I can load pics...
  2. OoltewahSpeedShop
    OoltewahSpeedShop
    I'm using a '40-'48 rearend, so obviously the rear spring behind the axle is in the wrong location to line up with the Model A rear crossmember. My plan was to extend the frame so everything lines up. I have another project underway that is going to have a shortened frame, so.... Took the two frames and made the truck frame a little longer.
  3. OoltewahSpeedShop
    OoltewahSpeedShop
    The body was a stack of parts for years.... We bought the bed from our "Ole Buddy" Chad Tompkins to really get this thing headed in the right direction.
    Things started actually looking like a truck after that.
  4. Hurley50
    Hurley50
    from NC
    Looks like fun! I'll be watching the progress!
  5. OoltewahSpeedShop
    OoltewahSpeedShop
    Finally found a p***engers side door.... Model A hinge pins must be made out of the hardest steel on the planet! Got'em out though and the hinges lined up like a champ. Movin' on...
  6. Another truck build!
    I'm in!
  7. flatheadz-forever
    flatheadz-forever
    from new jersey
    sweet cant wait to follow along ..... check my build out
  8. Looking good man!
  9. drmrman
    drmrman
    from new Jersey
    Subscribed. Looks like a good one
  10. fastmike
    fastmike
    from Mesa AZ
    Nice! Im building a 31 as well! Looking good so far man
  11. hotrodA
    hotrodA
    Subscribed!!!
    I like the frame extension; did you reinforce the **** welded area?
  12. F-6Garagerat
    F-6Garagerat
    31 trucks are cool. Looks good. Got the floor apart on mine. Here's a pic, late 31 solid top, 5" chop. It was an old hotrod I found.
  13. flatheadz-forever
    flatheadz-forever
    from new jersey
    any updates anxious to see progress on this build ?!!
  14. 392modela
    392modela
    I'm signed up . Hope updates are coming soon
  15. sdroadster
    sdroadster
    I am really glad to see your post. I have a 1929 Model A Roadster, and am in process of lengthing the frame to install a 40 rear end with a model A spring behind the axle. With the car a ride height the axle is about 2 fingers away from bottoming/hitting the frame. I jumped up and down on the ch***is today, and there was contact between the two as the rear spring flexed. I am considering stepping or the frame 2 inches, then shimming between the spring and crossmember to bring the ride height back to the measurement it currently is. Do you have this potential interferiance and what do you see as a resoulation? Thanks!
  16. 31ster
    31ster
    Not to high jack the thread but I made new rear frame rails out of box tubing to lengthen my frame and ran into the same problem. I lowered the center of the rear crossmember and it worked out pretty well
  17. waxhead
    waxhead
    from West Oz
  18. Darkwing23
    Darkwing23
    subscribed. Lot of truck builds these days, this should be a good one
  19. 3wLarry
    3wLarry
    from Owasso, Ok
    where'd he go
    kidcampbell71 likes this.
  20. OoltewahSpeedShop
    OoltewahSpeedShop
    I'm still here guys.... I've been working a crazy 7-12's night shift gig for the last few months, and haven't been able to get anything done except work and sleep. What I have been doing though, is collecting parts with the extra overtime coin. The updates are coming, just gotta get off 84 hrs a week at my "Real Job" so I can get back in the garage.
    sdroadster: I have a C-notch planned to gain some clearance over the axle. I'll keep the updates coming asap.
  21. Tricky53
    Tricky53
    from Bend, OR
    Love what you have planned for this truck. I'll be watchung for sure!
  22. sdroadster
    sdroadster
    Subscribed. Looking forward to the info on the C notch for rear end clearance. Thanks
  23. enloe
    enloe
    from east , tn.
    Subscribed, If you need some help I have a strong back and a weak mind. Give me a call and my son and I will ride down.
  24. OoltewahSpeedShop
    OoltewahSpeedShop
    I'll take you up on that, you know I will. ;)
  25. enloe
    enloe
    from east , tn.
    Looking foward to it.
  26. 3wLarry
    3wLarry
    from Owasso, Ok
    another hamb build bites the dust due to Instagram...:D
  27. 3wLarry
    3wLarry
    from Owasso, Ok
    anybody home? update time :)
  28. Coming along, lets see more!
