Art & Inspiration The Mother Of All Exhaust Threads!!!
Discussion in 'The Hokey Ass Message Board' started by JeffreyJames, Jan 16, 2009.
  1. Ratherman
    Ratherman
    from WI
    Here are some that my dad welded up out of stainless pieces...
    ...for thoese who have heard it run, know how well it sounds!!
  2. Hanksville Hot Rods
    Hanksville Hot Rods
    Alliance Vendor
    from Denver-ish
    We finished custom-mandrel-bending this exhaust yesterday. It's made with MIG-welded 2.5" aluminized tube and uses stainless steel Magnaflow 4" round mufflers. The customer chose to have us route the header extensions under the front of the X-member, then they turn up and through the center crossmember. We used flex couplers to allow the header extensions to move with the engine, then the rest of the exhaust is firmly mounted using high-temp grommets.
  3. Hanksville Hot Rods
    Hanksville Hot Rods
    Alliance Vendor
    from Denver-ish
    And this is probably my favorite one that I've done recently. It's a '37 Packard powered by a modern Hemi and uses a Corvette rear end. The exhaust is made from 409 stainless and is fully TIG-welded. We custom-bent alot of mandrel bends for this one! The exhaust is routed under the X-member because the master cylinder is on the driver-side and the battery/wiring box is on the p***enger-side. So, we went under the X-member and then went back up between the framerails to tuck the mufflers up as far as possible. Then we went back down and under the differential since there was no room above the half-shafts.
  4. What's wrong with this picture?? How bad would this engine shake without
    A balencer??? Thanks, Mike :eek::eek:
  5. BAILEIGH INC
    BAILEIGH INC
    Alliance Vendor
    Very nice exhaust!
  6. JeffreyJames
    JeffreyJames
    from SUGAR CITY
    More exhausts please!
  7. hrm2k
    hrm2k
  8. river1
    river1
    nice!!!
  9. lakeroadster
    lakeroadster
    from *
    Store bought block huggers with home made collector & header dumps.
  10. JeffreyJames
    JeffreyJames
    from SUGAR CITY
    I need more examples!
  11. 29Jay
    29Jay
    from Ft Worth
  12. 29Jay
    29Jay
    from Ft Worth
    This is my very 1st set... I'm still learning from y'all...
  13. Truckedup
    Truckedup
    Yeah more please.
    I like the looks of an exhaust system after a long time of heavy running. Blued from the port to the tip of the outlet.Cast iron manifolds pure white from heat Maybe even a touch of black from burned on oil to say it's a machine and not an electric blender.
  14. BAILEIGH INC
    BAILEIGH INC
    Alliance Vendor
    More pics please!
  15. chaddilac
    chaddilac
    Finished mine this weekend!
  16. BAILEIGH INC
    BAILEIGH INC
    Alliance Vendor
    Some slip roll action there huh?
  17. LowKat
    LowKat
    Here's a Buick straight 8 with some outstanding work
  18. ALCAN AV8
    ALCAN AV8
  19. Here is the set that I made for my sedan recently. I couldn't find any I liked, so I decided to make them. I cut up a pair to use the collectors, and ordered some random bends.
  20. alfin32
    alfin32
    from Essex, Ma.
    Built by Ron Gagnon for my 331" Hemi.
  21. chaddilac
    chaddilac
    Nope a rubber mallet and a large Vise... Seriously!:D
  22. BAILEIGH INC
    BAILEIGH INC
    Alliance Vendor
    :eek:
  23. BAILEIGH INC
    BAILEIGH INC
    Alliance Vendor
  24. whers the pics of the ones steve sellers did? i was gonna post those but he took em off his site.
  25. Mark Hinds
    Mark Hinds
    from pomona ca
    You don't always have use ALL the bends and tube that come in the kit :confused:
  26. LowKat
    LowKat
    1957 Ted Cooper
    351 Lincoln
    How about some 180* headers
  27. rallisracing
    rallisracing
    yeah, and how bad would it leak?
  28. Hanksville Hot Rods
    Hanksville Hot Rods
    Alliance Vendor
    from Denver-ish
    Here's a stainless steel '55 Chevy exhaust that we custom mandrel-bent and TIG-welded. While most of our exhausts have several bends on a long continuous stretch of tube, this one required cutting and welding because of the short distances between the bends required to clear the ch***is crossmembers. The tailpipe sections are continuous though.
    There are very close clearances between the ch***is and body so we used flex couplers and hung the exhaust very securely using custom hanger tabs and high-temp exhaust grommets. We used Aero Turbine mufflers because of their size and quality. The car has a 572 in it; can't wait to hear it run when it's finished.
  29. BAILEIGH INC
    BAILEIGH INC
    Alliance Vendor
    Did you do these on our machine?
