Hot Rods The need to breath
Discussion in 'The Hokey Ass Message Board' started by sprint57id, Jan 16, 2017.
  1. sprint57id
    sprint57id
    Hey, I'm building a hot rod, a 1937 Ford pickup. It now has a 69, 327 chevy power plant. Problem is no room for inside the frame headers and exhaust with all the cross-members and steering linkage in the way. So, I've been thinking fenderwell headers would really be *****'in with some short tubing under the running boards. Anyone know were I could go to find a pair of fenderwell sbc headers that would fit around the (pinto ?)a-arm suspension that was welded in before I got my greasy hands on it and miss the firewall ?
  2. hotroddon
    hotroddon
    These might work for you, Patriot H8033-1.
  3. manyolcars
    manyolcars
    Language is important. If its a chair and you call it a table, we are not communicating. You are not restoring it, you are traditionally hot rodding it. The definition of Restore--repair a vehicle, so as to return it to its original condition. Its not original with a chevy engine. :)
  4. stillrunners
    stillrunners
    from dallas
    what ^^^ ???? see if some one has an OLD set of 55-57 Chevy fender well headers....used is a key word - for a try and fit....my two sense....
  5. mgtstumpy
    mgtstumpy
    Local car running pipes
  6. Stogy
    Stogy
    If you want to run fenderwell headers with exhaust tapped into it you might emphasize it with a period look like this pic shows. Don't know what they are perhaps others may know.
    Greenblade likes this.
  7. X38
    X38
    I need a picture. Out of all the 37 pickups (and 35's, 6's, 8's etc.)with SBC engines, there must be something going on that prevents headers inside the ch***is.
    Having said that, not everything is going to fall off the shelf and fit perfectly in a modified car. Sometimes you have to actually make things.
