Features The official 1935-1936 Ford (3w- 5w) Coupes thread !
Discussion in 'The Hokey Ass Message Board' started by rob-redm, Dec 17, 2011.
  1. Dooley
    Dooley
    from Buffalo NY
    CE Engine mounts on top of frame
  2. Dooley
    Dooley
    from Buffalo NY
    Shroud would help. I have an electric fan in front with a thermostat in the intake that comes on at a light and kicks off when moving. Spal has what you need
    rob-redm likes this.
  3. rob-redm
    rob-redm
    I was looking at those .. do you know what model Spal you bought ?.. how does it sense your at a stop light and runs then kicks off once under way.. what are you running for engine ? I see were some guys have them wired up to switch under the dash so you can flip it on and off at any time.. @Dooley Thank you !
  4. Just.dale
    Just.dale
    Put mine on top.
  5. Flatheadjohn47
    Flatheadjohn47
    from Lewes, DE
    My 36 five window 150 hp flathead(dyno proven) 5 spd, 66 ford truck 9 in—3:00 gear, 65 mustang parallel leaf springs,Harley mufflers, rear wheels 7 in chev with ford centers(homemade 5 in backspace) to get tires inside fenders. Sold my Halibrands because too wide front and rear—-rubbed everywhere !! This 36 rides markedly better than my 32 cabriolet—heavier car longer wheelbase. 93AEC5D7-2CE5-44BC-A3C6-CCCAE6561FB9.jpeg 2939F357-8DFE-4577-AD28-818CE8910C39.jpeg B3D0D6C6-428C-44A9-B83D-4EA012811C44.jpeg 43D49AAB-D6CA-4C7B-A527-4E3974A1F3AB.jpeg 113DCEB2-A6FC-42C9-A164-56BD58AE9308.jpeg 60EDBFB6-4F84-4BA2-B963-770FDC275AFC.jpeg
  6. Dooley
    Dooley
    from Buffalo NY
    The switch runs off a thermostat kicks on at 200 and off at 180, I also have a manual switch
  7. rob-redm
    rob-redm
    thank you.. happen to know what model fan set up you
    purchased? I think going this route.. summer cruising and watching the temp
    gauge climb is getting old...
    @Dooley
  8. Dooley
    Dooley
    from Buffalo NY
    Bought mine at a swap meet but summit racing sells them and accessories
  9. ssffnomad
    ssffnomad
    Thanks guy for CE mount question.
    Mounts on top of frame I will try.
    Getting to the wheel , tire , axle conversation. Looking at a stock 40’ 16”x 4 1/2” on front.
    Rear 16 x 6” with a 56” wide axle .
    Does that seem correct to you guys ?
    Stretch
  10. Atwater Mike
    Atwater Mike
  11. rob-redm
    rob-redm
    huh ?
  12. roadsterlines
    roadsterlines
  13. roadsterlines
    roadsterlines
    I posted this one previously on the Sitting and Rotting thread 020.JPG 024.JPG 028.JPG
  14. rob-redm likes this.
  15. lamaison
    lamaison
    from Canada
  16. roadsterlines
    roadsterlines
    Unlike the V8 models, no 3 window versions were made.
    (The 1935 C and the 1936 CX were also available as roadsters in Oz. The UK did not have C/CX coupes or roadsters.)
  17. Just.dale
    Just.dale
    Any pictures of how you did the anti chatter rods? Great idea.
  18. mvee33
    mvee33
    Hi Nomad, my CE mounts are on top as mentioned above.
    Dale, Thanks, I made the rods as shown below, from original anti chatter rods welded to surplus spring plates suitably drilled and cut. They mount to the original chatter rod ch***is location and each side of the gearbox, in this case an M20.
    In this pic also is the clutch pull chain ***embly with a teflon lined guide plate from the modified 39 pedal ***embly to the shortened (for pedal clearance) Chev clutch arm.
    Just.dale likes this.
  19. Just.dale
    Just.dale
    Awesome!!! Thank you.
  20. rob-redm
    rob-redm
    pint size Ford's I like them... the headlights are cool
  21. jnaki
    jnaki
    Hello,
    Now being close to 80, seeing our 60 year high school reunion come and go was just a part of life, today. In our own family, we never saw an older person than 50. Most of the “old” relatives did not live near us and we only saw them in B/W photos. How could we get so old? We were lively teens, super active 20s, with a ton of stuff to get done and have fun doing them. “Time has come, today…” But, look at us now… ha!
    The history of Ed Pink is well do***ented. Ed Pink Engines and history in drag racing came in the early So Cal hot rod scene. The builds are ***ociated with a lot of the top racing teams and individuals across the country.
    Jnaki
    The 36 Fords have their own look and style. It was getting away from the boxy Model T-A styling. The new look in 33-34 started the more streamlined look, rather than a moving box with doors. But, this new era was a part of the 30s Art Deco mode.
    Most swoopy styles were priced out of range for the everyday families and individuals. But for the normal working folk, the factories designed their own swoopy looking coupes and other models. A new look from the USA factories started the style that is still popular, today.
    Ed Pink 1936 Ford Customcar Chronicles
    A stylish 36 Ford Coupe with a nice Tahitian Red Color to show the cool lines of the build from Ed Pink.
    upload_2023-3-7_3-59-3.png Tribute to his dad’s Paint shop from the early days.
    upload_2023-3-7_4-0-34.png old history
    The total rebuild and present day version:
  22. rob-redm
    rob-redm
    Thank you for sharing that with us... one cool 36 !
    jnaki likes this.
  23. ssffnomad
    ssffnomad
    35’ / 36’ P***anger Car Steering
    Who has used a 39’ Steering Column and 39’ Steering Box in a 35/36 ?
    Previous owner already switched out to frame bracket to accept the 39’ .
    But it looks as if I may have to move the upper mount to line up with 36’ dash
    Stretch
  24. ssffnomad
    ssffnomad
    Very much appreciate any info , good or bad .
    T/Y
    Stretch
  25. rob-redm
    rob-redm
    may want to put a want add up here in cl***ifies ... have better luck since not everyone will looks at this thread.... also check Ford Barn... had some good luck
  26. ssffnomad
    ssffnomad
    rob t/y.
    But , believe I am a member of good standing on the FB.
    Prob, last thing I want to do over there is ,
    start a discussion about a 1939 part in a 1936 car .
    Stretch
  27. 50DropTop
    50DropTop
    Stretch,
    I used a '37 box in my '36 that I posed photos of in this thread. I did not swap out the steering box frame mount for the later '37-'39, the individual who built my box modified the '37 box to fit the '36 frame mount. I also did not have to change the steering shaft or the steering tube; all of that is still '36. I did have to send my box for retrofitting where the original '36 steering shaft was modified to accept the '37 worm gear and work with the '37 and later box. The column lock, column support and light switch are still '36 and original to the car. Not sure how much trouble it would be to go back with the '36 frame mount, but this could be an option. Otherwise, with the '37 frame mount, I would expect you would need a '37 column drop (and maybe some shims) to get the column support aligned with the later frame mount.
    Now, I will say the '37-'39 boxes are SO MUCH smoother than the '36 boxes. Now that I've had the car on the road a couple of years, I was looking to further change the steering. My next project is to use a '37-'39 box with a '49-51 steering shaft and still retain the '36 column lock. I will then move the light switch from the steering wheel to a bracket just under the dash, much like how I mounted my starter switch. The dimmer switch will then go into the hole where the original '36 starter switch was mounted.
    If you're looking for someone to build a box to suit your needs, send me a message and I can provide contact info.
  28. rob-redm
    rob-redm
    Let's see more 35-35 Ford Coupes... the tread has gotten a bit off track with tech related questions ( not that it is a bad thing)
  30. rob-redm
    rob-redm
    Nice ride !
    1935streetrod likes this.
