Event Coverage The Official 2014 Meltdown Drags #5 thread, vintage drag meet, July 18,19&20 Byron IL
Discussion in 'The Hokey Ass Message Board' started by David Doo, Jan 3, 2014.
  1. speedwise
    speedwise
    You know what you must do...awesomely sick...I hear injection is in this year...
  2. saltflats
    saltflats
    from Missouri
    Skot yours has valve covers there just not made out of tin.
  3. ..,ole water boilers!
  4. saltflats
    saltflats
    from Missouri
    Damn man your tough on him.
    I remember in tech school helping with the ***embling a ford flat head V8 getting the valve keepers in was a challenge for us punks took two nights to get it.
  5. Anybody making after market flat head blocks yet? Never could understand why Dart, or World Products etc. ,wouldn't do this. Seems to me, they would sell a bunch of them.
  6. saltflats
    saltflats
    from Missouri
    That would be kool with some of them wide heads with valve covers.
  7. wrenchbender
    wrenchbender
    They make them they are called ardun lol
    Chrome don't get ya home
  8. saltflats
    saltflats
    from Missouri
    That's what I am talking about. Would love to have me one of them in a digger.
  9. II FUNNY
    II FUNNY
    4.25" stroke 4.35" bore.
    Meltdown Drags
    July 18-20 2014
  10. Skotz
    Skotz
    Son of a gun...you know the secret....the "intake" is called the valve cover....shhhhh, don't let anyone know, or they will think I've gone over to the "dark side":rolleyes:
  11. Ok, an old school 505! When I worked with **** Gazan ('84-'94) that and the 511 (4.375 bore)was our favorite combo. -2 Brodix's that flowed 365-380cfm (big #'s back then), 14.0 compression, 272/280 @ .050 x .740/.700 Engle roller w/Rev kit, Isky rockers, a Milodon gear drive, and a kickout pan, Victor 454R, and a single 1050 Dominator, would make 870-880HP, and 680-700 lb.ft.
    What's the rest of your recipe, or you gonna hold your cards a little longer?
  12. Skotz
    Skotz
    I got rid of that pesky water stuff on this engine....just filled that ****er with hard block......fixed that boiling over water problem:rolleyes:...hahaha
    I, also am surprised at the aftermarket group.....Motorcity made a few cast ones, on
    Only some of the whiz bang hi-buck builders seemed to be able to get them....there seems to be a bit of a market for them....I've got a pile of stock ones, but would sure like to build a "light" one.....anybody listening, Dart folks
  13. Skotz
    Skotz
    Hey....I've got that stroke....but the pistons are an inch smaller....dang it.
  14. saltflats
    saltflats
    from Missouri
    Damn 4.25 stroke in a flathead cant wait to hear this one.
  15. When I worked @ Ross Pistons (1994-2001), someone sent us a pristine Forged True Flatty piston. We copied it all except a little larger interior radius's for strength, and put em on the shelf with old 3/32 Grant "tractor" Rings, and they sold like hot cakes. We started selling them to Mike Tatom, @ Tatom Custom Engines in Washington state. One day he asked if there was any modern remedy for the flatties oil consumption? I told him I believed that modern metric rings with there narrower face, and lighter tension would actually have better conformability to the flatties distortion prone cyl walls. He agreed to try it, so we used 1.5 (.059 thick instead of .093)x 1.5 x 3mm(.117 instead of .156 or .188 oil rings). These metric rings also had a 1/3 less radial thickness (front to back, this cut the ring drag dramatically (which reduces friction/water & oil temp), and reduced the flatties oil appe***e by 50%! Mike then had Crower grind modern dual pattern cams, and had modern type step tube headers with venturi collectors made, and whammo, almost overnight, his flatties started gett'n real happy!
  16. Skotz
    Skotz
    I had Ross build the pistons in the new engine with the metric rings, as well. I had them drop the rings way down, put more meat between the compression rings, anodize and Teflon coat them....I was trying out some off the wall relief ideas that I wanted to try, that "some folks said wouldn't work"...never was too good at listening....and son of a gun, it's working anyway....haha
    A person has to be a bit off, or some sort of a masochist to run these ol pieces of iron:rolleyes:.....but there are still a few of us at it...at least 3 showing up....anybody else reading out there?
  17. wrenchbender
    wrenchbender
    Skotz, pannenton They are in the final stages of making a all aluminum aftermarket flathead I think it's the guys that make the 27 roadster bodies can't think of the name of the company off hand my brother checked on one the other day for a 37 ford build but nothing off an original will fit but they are damn nice and have had lots of improvements not that I could afford one supposed to be in the 15-20k range anyhow what I really was here to say my caddy flathead has a 4 1/2" stroke but just a 3 3/8" bore the connecting rods are 8 1/2" long it's a beast but its also very heavy compared to a ford flattie
  18. II FUNNY
    II FUNNY
    Nope...not a sleeper:D
    10.369:1 comp.(pump gas) Out of the box AFR 325 with CNC comb. chambers. A Howards mechanical roller 257/263 .725/.725 110/106.
    Liberty upgraded TKO 600, Dana 60 4:10.
    Meltdown Drags
    July 18-20 2014
  19. Uncledirty616
    Uncledirty616
    What is this combo in???
  20. II FUNNY
    II FUNNY
    Meltdown Drags
    July 18-20 2014
  21. Uncledirty616
    Uncledirty616
    Kip?
  22. II FUNNY
    II FUNNY
    Yes sir.:D
    Meltdown Drags
    July 18-20 2014
  23. She ought to make 750+ HP, and 700+ for grunt.
  24. II FUNNY
    II FUNNY
    I hope so.lol
    The driver(me) definitely needs some stick shift seat time.
    Meltdown Drags
    July 18-20 2014
  25. Is that running gear going in that Ford sedan, or an AWB car?
  26. II FUNNY
    II FUNNY
    It's for my Vicky...and believe it or not it's a 1931 Chevrolet five p***enger coupe, but everyone calls them Vicky's.
    Meltdown Drags
    July 18-20 2014
  27. II FUNNY
    II FUNNY
    The AWB Chevy II was sold twice and now is owned by Speedwise, and he is bringing it back to the Meltdown this year.
    Meltdown Drags
    July 18-20 2014
  28. OH MAN! Your gonna be wearing a Cheshire Cat smile when cut that ****er loose! You better put a name on that girl so you can call her back if she gets outa shape! I vote for "Whoa Nellie"
  29. Skotz
    Skotz
    Those kind of prices is a good reason that my engine is a home shop build....got more time than money at this stage, and well, .....there is a lot of satisfaction when I do it, myself:D
    4 1/2 stroke.....334 cu in....."our kind of Big Block".... I almost went that big with mine....just sounds like a good number. Heard that they were heavy, like the Lincoln 334''
    What's your name....since we are both in the Obsolete Engine Club, we have to stick together while a**** "all these tin valve cover guys":eek:
  30. Skotz
    Skotz
    Now that is a Cool, rare ....non-Ford.....bet you have to wear a bullet proof vest when "Restorers" are around....haha....that ****er just looks "right"
