Features The Official 60-66 C-10 Chevy Truck Picture Thread
Discussion in 'The Hokey Ass Message Board' started by TexasHardcore, May 8, 2006.
  1. duffy.
    duffy.
    are those centerline smoothie's?
  2. Mine, not complete just working out the bugs.
  3. jchav62
    jchav62
  4. Payaso
    Payaso
    Here's my 'Revenge'....
  5. kingofknights
    kingofknights
    anyone know of any good conversion kits for a 60 c-10? i want to get rid of the torsion bars and run coils
  6. Payaso
    Payaso
    In Tucson (PHX Native) ...I'd rock a fan shroud my man...You can get a real nice black composite (lightweight) for about $100.00 online...LMC wants way too much though. Look around...you'll be doing that motor, fan, radiator, yourself...a solid.
    MONDO
  7. Payaso
    Payaso
    Fan shroud on my 'Heavy'...
    Makes a Big difference under our hoods...
  8. Brad54
    Brad54
    from Atl Ga
    I agree with the fan shroud being a huge help.
    I don't have my factory shroud mounted yet, though.
    I've got an 18-inch 7-blade OE steel clutch fan, and even though it's set back three feet from the radiator, that fan will pull a sheet of paper tight to the radiator at idle, and keeps things cool pretty well.
    I expect it'll pull small birds out of the air once I get the shroud on.
    -Brad
  9. Strodder
    Strodder
    Why not go with an electric fan?
  10. Brad54
    Brad54
    from Atl Ga
    Because if an electric fan dies, it's dead. It not only stops cooling, but now it becomes an air-blocker to restrict whatever flow you can get through the radiator.
    When is the last time you heard of a mechanical fan failing?
    -Brad
  11. Delmo
    Delmo
    from Burbank
    Yep, 22X9
  12. Strodder
    Strodder
    The fan Clutch fails quite often. Mechanical fans cause water pump bushings to wear and leak, plus used up HP. There is pros and cons with both. The fans seem to be pretty reliable if wired correctly with a relay and the right size gauge wire. Just wondering.
  13. busch
    busch
    The makings of a great rod
  14. duffy.
    duffy.
    whats the deal with the hubcap tabs?
  15. jchav62
    jchav62
    73-87 Chevy truck front suspension.
  16. Danger
    Danger
    Just a few more things and it will be on the road.[​IMG][​IMG]
  17. wildearp
    wildearp
    from tucson, az
    It was over 100 when I picked it up. It stayed at 180 all the way home, but stoplights are what gets you....... The 3 row radiator appears to be in good shape. It has more issues than just cooling, but it is rare for me to be able to actually drive a new project home. I got rid of that heater hose and cleaned it up a bit. It has power steering too!!! (not the ram but a box)
    I think running mechanical and electrical fans is probably best. That is what my '47 has.
    This truck will probably end up with an LS motor and a 5 speed manual, but I will probably change my mind 10 times before I get to it. This will probably be a winter project.
  18. markeb01
    markeb01
    from Washington
  19. Payaso
    Payaso
    Yes, it has all the stock dimensions...all the way down to the lower radiator hose surround...
    Fits perfect...predrilled holes...no modification needed...
  20. If you ask a repair tech, you will find that a good quality fan clutch will outlast an aftermarket electric fan that costs twice as much by several times. And a flex fan will last pretty much forever (those are the ons that simply never fail).
    If you ask an engineer, you will find that for the volume of air moved, a mechanical fan draws less engine power than an electric fan, on a vehicle with an engine driven charging system.
    Plus, electric fans are kinda ugly.
  21. jonzcustomshop
    jonzcustomshop
    these are photo chopped a little..but I like the idea..
      38.2 KB
      31.5 KB
      42.8 KB
  22. I just cut and installed a windshield in this one. it had about 3 1/2 inches off the top
  23. Strodder
    Strodder
    I am a repair tech, and I asked myself. :D Electric fan and a flex fan worked great for me for over 15 years on the same 56 Belair.I lived in Vegas, and High Desert California. Never over heated even in the Vegas traffic.
  24. ray
    ray
    from colorado
    here's a peek at my new beater i'm just finishing up throwing together.
    here's what it started as, a pretty sweet mullet-mover:
    it was a legit 2x4 custom cab bbw shortbed w/chrome. some jagoff took off all the trim and dropped it on a late model 4x4 frame.
    two months of weekends and playing hooky from work:
    back to what it should be! it'll get bodywork later. for now i did spray some flake on the roof and dash.
    dig the duct tape windshield seal. the result of watching three glass guys try for three hours to install a windshield with the stainless trim, then without the trim, still failing, and these guys specialize in antique auto glass! he says bring it by his house on sunday, i call and he blows me off again, so i finally did it myself after these pics. i didn't do too bad, only broke it once.
  25. jonzcustomshop
    jonzcustomshop
    right on ray! that truck looks great, I like the wires. what kind of buckets are those?
  26. ray
    ray
    from colorado
    thanks jon.
    i've been diggin on your stuff too, what i've been seeing here and the c-10 board. seems our tastes are a bit similar.
    the seats are late 60's t-bird, i was gonna run impala buckets but they just took up too much leg room.
  27. EL SOLDADO
    EL SOLDADO
    You saved it!!! Looks Good Man. Really dig the wheels ese.
  28. Deadbird
    Deadbird
    Got any interior pics? I think that I'm now int the market for late 60's t-bird seats! :p
    Truck looks much better now. I love that shade of red. :rolleyes:
    Already posted, but here's mine:
      76.9 KB
  29. CenValyCali
    CenValyCali
    from Hanford
    So does anyone have a link to the drop coil springs made for jeeps? TJ springs?
  30. 63c10
    63c10
    from kentucky
    Check out post #699 on page 35 of this thread. Then go to a junkyard or ebay. I bought mine on ebay for $30 shipped.
