Features The Official [Ed] Winfield Speed Equipment Thread!
Discussion in 'Traditional Hot Rods' started by gwhite, Jul 3, 2013.
  1. I have owned 2 Winfield "Crowsfoot" heads both were stamped 7 on the pad, anyway first number was 7 on each. Both heads were milled, the first, which the owner stated was "cherry" turned out to have been milled .200 was ***** punched. Seller stated that he had run 114 in 1940 as I remember I also bought 3 Winfield SR. BB's for $100, 1 complete 2 missing linkage and chokes. My current Winfield "Crowsfoot" has been milled .060 and filled . Both heads had been identically relieved in valve area. I think I might be able to clear 2" intakes if I wanted to. The web or gasket area between valve pockets is/was .190 to .200 so I have to use a solid copper gasket. The current head calculates to approx 9.5 to 1 on the stroker and leaks compression at thinner sealing area's on 2 and 3. Head flexes it is not warped block is flat.
    Outback likes this.
  2. Jeremy Shay
    Jeremy Shay
    from Las Vegas
    These showed up at sunday show not so long ago
    Lil'Alb likes this.
  3. Received my latest issue of FAST and they are starting a series on Ed Winfield, the only thing wrong is the magazine comes out quarterly, long wait !
    Outback likes this.
  4. image.jpg image.jpg Very excited - here's a Winfield V series carb I picked up - it's spec is noted by a 4V means it has a 1" bore and a barrel throttle vs ****erfly.
    Destined for my period mid 20s T speedster.
    Outback and gwhite like this.
  5. 25mercury
    25mercury
    Here is a Winfield 5H on my Mercury Speedster. The H series is the same as the V series. V is vertical (updraft) and H is horizontal (sidedraft). DSC04924_2.jpg
    Showrail, falcongeorge, Jet96 and 2 others like this.
  6. 4-port Riley
    4-port Riley
    25 Mercury, Very nice! including the DSM coil.
  7. 25mercury
    25mercury
    Thanks Jim. Will you be at Auburn ? There is a very slim chance I might get the Mercury up 431563_3724654318545_1963857773_n.jpg to the Auburn hillclimb, otherwise I'll drag out the A pickup again (Winfield head and carbs of course). Hope to see you there. Mike
    Outback likes this.
  8. 4-port Riley
    4-port Riley
    Probably not, I don't travel well yet.
  9. gnrs.jpg pair of Winfield BB S's on Riley 2 port with Riley manifold
    Outback, Showrail and kadillackid like this.
  10. 62pan
    62pan
    George Wight intake for CC Winfields. Ports are huge on this. 1 7/8" opening. george wight intake 3.jpg george wight intake 1.jpg george wight intake 2.jpg
    Lil'Alb, Carter and gwhite like this.
  11. image.jpg Well my speedster will be cooking now!
    Scored a second Winfield Model 4V barrel throttle carb to mske a set for a proper twin carb setup on the T engine.
    Now all I have to do is find a period intske or fab one up!
    Anyone have any plans for a T dual updraft intake?
    Outback likes this.
  12. waxhead
    waxhead
    from West Oz
    I have the Winfield manifold in the attached pics (sorry about the pic quality). It has S66 cast into the bottom of it, with a B stamped into the manifold just below the S66. Which Winfield carbs suit, and what else can you tell me about it?? Thanks
  13. That is a intake to use with an S or SR model B they stamped intakes to correspond to carbs.
    Winfield was very good in stamping if #s to show carb size, type of carb or bowl, updraft = U, downdraft =D etc
  14. waxhead
    waxhead
    from West Oz
    Thanks for the response, appreciate it.
  15. gwhite
    gwhite
    SUPER MODERATOR
    I could be mistaken, but I think the 'intermediate' sized carbs (AA, BB, CC, etc.) had matched intakes as well. Pretty sure @Carter has a BB on his roadster.
    Technically, that's a downdraft intake for an S or SR (size B). Could probably be used an a updraft but the carb mounting pad angle would be off & it wouldn't bolt to the exhaust manifold. With a BB or larger carb, the intake would likely create a bottleneck due to its smaller size.
    Outback likes this.
  16. 62pan
    62pan
    gwhite is correct. If it is stamped B then that is what carb to use. A BB carb can be used with an adapter. There are BB intakes and they are stamped BB. I think this was one of Winfields biggest faults in that you needed the correct intake for the carb you were using. Might be why a lot of guys went to Stromberg. As far as updraft Winfield intakes not sure I ever saw one. Most updraft carbs use adapters to existing stock intakes.
  17. Winfield literature had a drawing showing basic design of adapters that might be needed to use larger size carburetor. The only Winfield manifolds I have seen have been for B or BB not saying other sizes didn't exist but if they do I haven't seen one in many years of swap meets.
  18. pumpman
    pumpman
    I recently picked this up, and don't know too much about. I thought with all of clean and shiny winfield stuff here that my dirty old carb would set the tone of "as found". And yes, I intend to clean her up. The throttle flap is stuck, and suggestion on the best and safest way to free her up?
  19. I have found that sometimes the throttle shaft is frozen or stuck in the bearings and have had success freeing the shaft up by tapping the shaft lightly back and forth with a piece of br*** plus the use of a light oil or wd40 . DO NOT use anything other than your fingers or some other soft material on the ****erfly especially on the thinner edge. The late Mike Hart suggested carefully using a propane torch to lightly heat the casting but I have had better luck tapping on the shaft. The shaft is usually pressing the ****erfly against the side of the throttle bore.
  20. pumpman
    pumpman
    Thanks Bill, I actually did what you suggested and it worked. Now my mornings will be moving back and forth the linkage arm for a couple of minutes. I used a little PB blaster and everything is moving very well considering it's been sitting for God knows how long.
  21. Hi, use this and you will never use anything else again! (except a little heat) Please forgive the overworked hand with Zinc Chromate over spray on nails!:eek:
  22. Carter
    Carter
    Wow, that is fantastic! Yours?
    That is correct, Gary. I have both B and BB intakes, and they are the only two intake sizes I've seen.
    41FordSuperDeluxe likes this.
  23. RussTee
    RussTee
    Does anyone make new choke tubes for winfield would love to get two for my SR downdrafts
  24. image.jpg Here's a gem I came across from the Speedster Ralley - T speedster with Rajo and four Winfield Model H carbs - she's a real looker
  25. Carter
    Carter
    More stuff, first picture is what I believe to be the original yellow, that was under many layers of paint, on a 6:1 head. 20150719_135838.jpg
    M foundry mark...
    1406 serial number, 18mm plugs.
    gwhite likes this.
  26. Carter
    Carter
    Dual Winfield intake of unknown origin.
    S66 cast number and stamped B on Winfield intake in first picture
    gwhite likes this.
  27. Carter
    Carter
    D next to an A to show size difference between Winfield's largest and smallest S/SR type carburetors.
    gwhite and waxhead like this.
  28. 28downunder
    28downunder
    Here's my Winfield s66 intake, I'm looking for a S B or SR B downdraft carburetor to suit it ImageUploadedByH.A.M.B.1438494895.517731.jpg
    Outback, Lil'Alb and waxhead like this.
  29. 62pan
    62pan
    winfield knob 2.jpg Not sure how fast this will make my roadster go but it is the first and only one I've ever seen. Winfield shifter knob, bakelite with a br*** insert.
    Outback and brjnelson like this.
  30. pumpman
    pumpman
    Now THAT is definitely cool!
