The Official English Wheel Thread
Discussion in 'The Hokey Ass Message Board' started by BAILEIGH INC, Jun 2, 2011.
  1. Crafty
    Crafty
    from UK
    Clive Lamb and mgermca like this.
  2. COCONUTS
    COCONUTS
    I wish that the manufactures would offer a 3 to 5 day course on working the equipment that they are selling. This course would be free to anyone buying the equipment and a fee charge to those who build their own. I think that this would increase sells.
    alanp561 and VANDENPLAS like this.
  3. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    I have found that my kick wheel with numbered legs is very handy to adjust and to return to a previous setting. These guys should incorporate something similar.
    osage orange likes this.
  4. stormyt
    stormyt
    anyone ever seen this unit. home built or production?
    came from a shop at one point from the 40s or 50s..
    hydraulic ram not acme tread and wheel.
    used in a bently and royce repair shop.
    want to restore for use.
    so thats was the back story.
    front end... bought for about s**** price. less tan harbor freight wholesale price. but the back story is priceless. there is some machine work done to this that is impressive.
    anyone have info? seen one? want to pay me for the back story and restore. 8 g. lol
    want yoder and we are ready to learn ow to use them all and teach troubled youth 20220307_083302.jpg a skill.
  5. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    A possible problem I see with hydraulic pressure is repeatability of applied pressure when the job has to be removed repeatedly, which occurs often. I think a pressure gauge on the cylinder would be an absolute must at a minimum.
  6. Stueeee
    Stueeee
    from Kent, UK
    Interesting to see a 'Lambco' English Wheel turn up on here. Earlier this year, I bought one of these from Clive, the chap who makes them, I've known Clive for quite a few years, everything he makes is absolutely A1 quality. I was intending to fabricate my own wheel and buy some anvils, but then decided I have more than enough projects already, and need to actually get on with some car bodywork rather than having to make the tool first.
    GuyW, rod1, Clive Lamb and 3 others like this.
  7. 48stude
    48stude
  8. stuart in mn
    stuart in mn
    It's worth checking out his channel, he has several more videos up for the R****ah. He's had a new one cast, has done the necessary machining, and has a set of rollers. https://www.youtube.com/c/DominicChineas/videos
  9. Clive Lamb
    Clive Lamb
    Lovely idea but who’s covering costs if it’s a one man shop like me, I’d have to figure in another weeks labour to cover expenses in the purchase cost
  10. Clive Lamb
    Clive Lamb
    Was just googling myself and found this thread, thanks for the compliment stu!
    Stueeee likes this.
  11. Kiwi 4d
    Kiwi 4d
    This was delivered to my shop yesterday to use as long as I need. The bottom wheel screw jack doesnt seem to want to budge. Though you can see from picture 3 there is no paint on a small portion of the mast. Are the two bolts in the bottom stem relavent to the screw jack operation? Yes I know it’s missing the arm on the bottom wheel. A good picture of the arm would be appreciated.
    .Everything else spins nice and free , plus it has other wheels .
    VANDENPLAS, Gofannon and alanp561 like this.
  12. mgermca
    mgermca
    That's a lovely looking Edwards. Probably clean the paint off of the shaft and get 'er operational pretty easily!
    alanp561 likes this.
  13. Kiwi 4d
    Kiwi 4d
    so we got the top mast cap off clean the paint from the key way and freed that up. Undid the two vertical mast retainer bolts. And it was a little sticky but went up and down. As soon as the mast cap is bolted back up it locks up again. A 5’ long pipe and 2x1/2” steel plate on the end just bent the steel plate. Every thing else has been put together some time ago and thankfully anti seize is on every bolt. So it’s been done with care. But the main bottom anvil is frozen.
    VANDENPLAS likes this.
  14. Kiwi 4d
    Kiwi 4d
    Hoping some one on here has experience with this model and how to dis***emble the screw on the bottom anvil. It sure is frozen solid.
    Marty S likes this.
  15. patsurf
    patsurf
    have you put a rosebud on it yet?
  16. Kiwi 4d
    Kiwi 4d
    I need to figure out how to dismantle the thing first before any heat goes on . I don’t think it’s possible to heat the screw jack inside a 5” housing. So how does the bottom kick wheel come off?
  17. patsurf
    patsurf
    heat the outer tube... that 5" hsg
  18. K13
    K13
    I would be very careful with heat. Some English wheels used babbitt to mount components.
  19. stillrunners
    stillrunners
    from dallas
    Could there be a manual for one of those on-line somewhere for sale ? Would try a Ebay search.....pretty much by one for things I'm working on if I can find one. Ytube maybe.....?
  20. Kiwi 4d
    Kiwi 4d
    IMG_1553.jpeg Yeah have been hunting for information . The screw jack works when the top cap is unbolted. I am missing seeing something. Are there two shafts that slide internally?? I cautiously nervously laid the wheel it on its sides so i could better see how it may function , for the life of I cannot see how the bottom kick wheel attaches. And of course cant get it out the bottom as at some point the screw jack stops when it runs out of thread . ATTACH=full]5795253[/ATTACH]
  21. alanp561
    alanp561
    Just a thought. Matt at Iron Trap Garage has an Edwards in his shop as well as a video of how he got it and how it works. It has what appears to be the same wheel on the bottom of his. Someone else to check out is Richard Mullin at rmullincoach@comcast.net. He has an Edwards in his shop that was used at the Cunningham factory in Rochester, NY prior to 1932.
  22. Nominal
    Nominal
    There is a fair bit of english wheel knowledge on https://www.allmetalshaping.com/.
    Might be worth a post there, or send me some pics and I'll post them there.
  23. Kiwi 4d
    Kiwi 4d
    IMG_1594.jpeg IMG_1497.png Thanks @alanp561 . I did see Matt from Iron traps cool story earlier this week , he got his as a functioning machine from Gene. Richard Mullins one , the grey one is different also, the red one is similar but the anvil holder is different to ours , how did the guy get the kick wheel off? IMG_1497.png
  24. Kiwi 4d
    Kiwi 4d
    Ok a follow up on My Edwards wheel . My son and his BIL called in yesterday, all discussed how the wheel was actually would have been made and ***embled. Discovered a grub screw in the base of the kick wheel , I know there is a name for these screws?? A knowledgeable buddy calls them a Dutchman pin .So the kick wheel and the shaft have half a thread each . And the bronze bushing is also held in the internal mast at the bottom the same way by two grub screws. Lots of cleaning and we could see a separation line on the shaft where it goes into the male thread. Gingerly put it in the press and success we could see a minute amount of movement. The press was on 20T so the shafts were surely rusted together. All cleaned up and lubed now and working perfectly. …. and a know all well meaning posted on here “ clean the paint off and use it!!!Absoluterly no way in heck any amount of heat would have helped.[/ATTACH] IMG_1657.jpeg IMG_1664.jpeg IMG_1659.jpeg IMG_1658.jpeg IMG_1663.jpeg IMG_1660.jpeg IMG_1661.jpeg
    Cooon, alanp561, MP&C and 1 other person like this.
  25. Clive Lamb
    Clive Lamb
    I’ve started making the patterns for a improved edwards type e style machine with more lower arm sweep and wider spine to overcome the ********** problem
    Kiwi 4d, Ziggster, Stueeee and 3 others like this.
  26. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
  27. Clive Lamb
    Clive Lamb
    My 42”
    Improved edwards type e inspired pattern is nearly finished IMG_2834.jpeg IMG_2833.jpeg
    GuyW, Stueeee, osage orange and 3 others like this.
  28. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    Again, "Oh, My!!!!"
    Clive Lamb likes this.
  29. alanp561
    alanp561
    Clive, it's said that a picture is worth a thousand words. I looked at your post count. Only four posts and five pictures. You've managed to say more in those four posts than many who have written much more than you. That's a beautiful job.
  30. Clive Lamb
    Clive Lamb
    Thankyou
    I only make this stufff as it seems the right thing to do in respect to the giants that came before us . It certainly isn’t for financial gain!
    Ziggster, alanp561 and mgermca like this.
