The Official English Wheel Thread
Discussion in 'The Hokey Ass Message Board' started by BAILEIGH INC, Jun 2, 2011.
  1. Clive Lamb
    Clive Lamb
    Pattern for top wheel yoke done . There was no way I was fabricating that from steel plate
    HiSpoke, rod1, stillrunners and 3 others like this.
  2. Clive Lamb
    Clive Lamb
    Cowling wheel I made for a customer in California
    Column is 3” en24 /4340 and out rigger arm is 2” 4340
    It gets 16 swg steel going without flex as high strength steel will
    rod1, stillrunners and GuyW like this.
  3. Clive Lamb
    Clive Lamb
    Successful casting was produced from patterns I posted earlier
    Made pressure screw today for the big machine , found nice old hand wheel on eBay
    rod1 and stillrunners like this.
  4. bulletfab
    bulletfab
    from gardena
    Beautiful machine Mr. Lamb. Recently been looking for a quality wheel here in CA.
    There was a gentlemen by the name of Ed Howarth (Excel Wheels) local to me who produced a wheel.
    Not sure of the grade of iron he used but his wheels are considered to be of great quality and feel.
    I am considering my own wheel design and read in a previous post you selected a grade 40 iron. If you would not mind sharing I would be curious as to your choice of iron. I am welder and machinist by trade with limited metallurgy knowledge.
    As I understand cl*** 40 has different dampening characteristics than lets say a 20 series as well
    as modulus of elasticity. Maybe I am just over engineering this but any input or feedback would be appreciated.
    Regards,
    Mike Settele
  5. Clive Lamb
    Clive Lamb
    Progress
    Ps 40 series as that’s the foundries preferred grade and strength. Modulus is pleasing for a wheel as well
    mgermca, rod1 and Jeff34 like this.
  6. bulletfab
    bulletfab
    from gardena
    Thanks for the reply. Looks reminiscent Of the Excel wheel. I was drawn to this design just for the mere fact that the upper and lower wheel bosses could be drilled in one operation with precise alignment. Well done.
    stillrunners and mgermca like this.
  7. Clive Lamb
    Clive Lamb
    Actually the 1940’s edwards d type was the inspiration!
    Anyway I finally cast my 40” planishing hammer . Posted for interest as I made it strong enough to have a wheeling attachment and Louvre press
    stillrunners, rod1, mgermca and 2 others like this.
  8. Clive Lamb
    Clive Lamb
    Danish customer sent me pictures of the big wheel I made for him
  9. mgermca
    mgermca
    Beautiful work Clive, thanks for posting 'em!
    Clive Lamb likes this.
  10. Clive Lamb
    Clive Lamb
    Another wheel , this one went to California
    GuyW and rod1 like this.
  11. rod1
    rod1
    What a work of art Clive . Thank you for sharing ,and caring.
  12. PWMetalcraft
    PWMetalcraft
    Wheeling machines look fantastic.
    I've got a couple of 42" Edwards that I'm trying to find lower anvils for. I have a good original set but need another set for the second machine that don't have sharp edges where the flat transitions to the radius. Do your anvils have flats or are they full radius?
  13. Sandcrab
    Sandcrab
    I built a small English Wheel from High Desert plans to shape my Avatar but needed a larger unit to do the infill for the Ruby. This Yates scroll saw frame showed up on C List so I brought it home and fabricated a lower adjuster with an Acme screw and a 2:1 bevel gear set because that was the only way I could get access to the lower adjustment. The Anvils are Chinese but they worked just fine as far as concentricity and finish were concerned.
    The All Metal Shaper crowd gave me some grief over the small handwheel and I have since upgraded to an 8" but even with the small wheel I could put 400lbs of pressure with one hand although that was never needed. .
    My helper let her end down so I had to shrink a couple of spots.
    rod1 and GuyW like this.
