the old granada spindle trick.
Discussion in 'The Hokey Ass Message Board' started by bluegrassboogie, Oct 22, 2003.
  1. im going this weekend to get some 1977 granada spindles to put discs on my wagon.its been a while since i found the car.an i thought i remembered it being like a strut setup.anybody pulled any of these spindles?is the spring and strut self contained ?does it stay together?all i have to do is jack it up by the frame,and bust the ball joints loose,right?im a little spooked about springs since a friend got badly hurt by one.any info will be appreciated.thanks in advance!
  2. Fraz
    Fraz
    from Dixon, MO
    From what I remember when I was working on the brakes after I got it, my 79 Grenade's spindles are held via 2 balljoints and the tie rod. No strut rods or nothin. Been a while, I haven't looked under that car in over 2 years.
  3. dixiedog
    dixiedog
    Pretty sure theyre coil spring with A arms - Mustang II style? The strut was a pinto thing?
  4. Fat Hack
    Fat Hack
    from Detroit
    No struts. Granadas use a shock tower in the body much like early Mustangs, Falcons, Torinos, Fairlanes, etc. The spindle is mounted with ball joints to the control arms. The shock is inside of the spring, and the spring goes up into that shock tower in the body.
    No different from removing a spindle from a typical 60s Mustang, really.
  5. [ QUOTE ]
    [/ QUOTE ]
    Hey, Lemme know how this goes. I've considered doing the swap w/ my Vic.
  6. disc brakes? what? hahahaha! seems that thing stopped plenty well enough last time i drove it.
  7. i talked to someone with a mustang.he said to take the3 shock tower bolts loose on top.then the the spring bracket that holds the spring to the upper control arm and it should just push out of the way.then go about your business of taking the spindles off.sound right?
  8. hey irritant.it stopped good for you cause you drive like a grandma.i , on the other hand ,am a proffesional $1200 go kart racer.hahaha
  9. heaths not messing with me anymore because he knows i have a pic of his rugrat thats on the way:
  10. Randy D
    Randy D
    Don't you have to make it GO, first? [​IMG]
  11. Randy D
    Randy D
  12. what the hell do you mean ?im driving it daily! [​IMG]
  13. [ QUOTE ]
    [/ QUOTE ]
    hey! that's me driving it!
  14. [ QUOTE ]
    [/ QUOTE ]
    hahahahahaha!!!! i love that pic!
    when are you and Erin going to reproduce? what's the story with your brothers car? has he done anything with it yet?
  15. tommy
    tommy
    Granadas went to struts in 1981. pre 1981 is what you want. I put them on my Ranchero.
  16. a/fxcomet
    a/fxcomet
    from Eugene, OR
