THE oldsmobile rocket 303 324 371 394 post to end all other posts, (lasalle related )
Discussion in 'The Hokey Ass Message Board' started by RocketDaemon, Dec 19, 2006.
  1. vtwhead
    vtwhead
    Well, you have done a great job saving another Olds Jimm. . That one sure looks pretty. Now about the oil filter adapter.......is that off of a 394 engine??? Seems I remember someone saying that you could use them but can't remember exactly.
  2. Paul
    Paul
    Editor
    Looks like maybe an adapter under it to go from four bolt to three?
    Also looks like an easy way to get a spin on filter.
  3. nochop
    nochop
    from norcal
    Looks like it might, I’m planning on using Noxious block hugger headers, how much for your spare adapter? BTW, where did you tie in the road draft to? Neat job all the way around!
  4. flatheadtommy
    flatheadtommy
    This is my Friend Ritchie from years ago with his Olds in his 47 coupe. IMG_1250.jpg
    gonzo and jakespeed63 like this.
  5. nochop
    nochop
    from norcal
    Saw this also....http://webpages.charter.net/dhomstad/
  6. jjjmm56
    jjjmm56
    from FL.
    Nochop I'll look tomorrow to see if I can find the other one and I'll take some better pics. The road draft adaptor I made it still uses the can in the lifter valley [​IMG][​IMG][​IMG][​IMG][​IMG]i had to throw some more of the 303.
    mario711, kiwiandy, gonzo and 3 others like this.
  7. nochop
    nochop
    from norcal
    No worries , no hurry as I’m a ways away from tearing down a running coupe but it’s going to happen
  8. Duke
    Duke
    Will all the parts from a 1951 303 fit on a 324 short block, including the stick flywheel? 40 over should still have one more bore on a 324?
    Thanks
  9. ROADSTER1927
    ROADSTER1927
    As long as it is not a 1956 324 it will fit. There is a cam size difference in 56.
  10. Duke
    Duke
    Is the stamp the only way to tell the year? The casting number is 54 to 56? The is also a 4 by the casting number.
    Thanks
  11. vtwhead
    vtwhead
    under the edge of the head on one side of the block (ds?)there should be a small tab near the center with a cast number that will give you a much better idea. Back in this thread there is a list of the numbers. I will see if I can find it and repost it for you.
  12. vtwhead
    vtwhead
    here ya go:
    1949--8A1001 TO 8A193864 H PREFIX=HYDRA MATIC
    1950--8A194001 TO 8A568689 H PREFIX= HYDRA MATIC
    1951--8C1001 TO 8C287312 B PREFIX= SYNCHROMESH
    1952--8R1001 TO 8R214478
    1953--R215001 TO R549482
    1954--V1001 TO V355083
    1955--V400001 TO V983275
    1956--A001001 TO A385513
    Head numbers that I know of:
    #2 1952
    #3 1953
    #7 1954
    #8 1955
    #10 1956
    number appears on DS
    Paul likes this.
  13. Duke
    Duke
  14. 36 ROKIT
    36 ROKIT
    Yes; up to '56. These early, high nickel blocks will take a large over-bore. Mine is .125 over; some guys have taken
    them to .250, but that would be pushing your luck!
  15. Duke
    Duke
  16. vtwhead
    vtwhead
    My 54 324 is punched out and uses later 371 pistons. Runs well and does not overheat.
    Fortyfordcmm and gonzo like this.
  17. jakespeed63
    jakespeed63
    Jeff, that motor looks bad ***, in black n gold
    Can’t wait to see the whole truck put together
    Folks, wait till you see what he’s got up his sleeve
    [emoji41]
    nochop likes this.
  18. vtwhead
    vtwhead
    Can't wait! c'mon Jimm give it up :D:D
  19. jjjmm56
    jjjmm56
    from FL.
    [​IMG][​IMG][​IMG] How do you like my tool ? I know it's been done before, but I think I'm happier knowing I didn't need to cut up good parts to make a priming tool. Looking to get the engine primed this weekend[emoji12]
    36 ROKIT, gonzo and nochop like this.
  20. nochop
    nochop
    from norcal
    I’m wondering if you could make ( not you jjj) a “socket” to fit a distributor rotor to prime? Hmmmm....... I don’t have a distributor to waste
  21. jjjmm56
    jjjmm56
    from FL.
    nochop likes this.
  22. jjjmm56
    jjjmm56
    from FL.
    Were it engages in on the pump shaft I drilled a .500 hole then adjusted the set screw to fit the flat part of the pump shaft.
  23. Paul
    Paul
    Editor
    I carved down a spare distributor housing and took the teeth off both a hex drive and D drive gear so I can prime any early Olds engine.
    I would not have sacrificed a distributor if it were my only one and they were hard to come by
    I still have a few spares.. more around here somewhere..
  24. jjjmm56
    jjjmm56
    from FL.
    Yea Paul, my only other one is for my 55 and I'll need that one later on.
  25. jjjmm56
    jjjmm56
    from FL.
  26. nochop
    nochop
    from norcal
    I see the error in my idea....
  27. Fortyfordcmm
    Fortyfordcmm
  28. Duke
    Duke
    Got a chance to go pickup the short block I was asking about. It is a 55 324. Only other parts it came with was the lower bell and a distributor. It is 40 over. Packed full of grease in the cylinders. Not sure if it is a good find yet? Should I be able to turn it over? 64AE438C-8E4B-4843-8FB6-76A30AC52CF5.jpeg 63176055-1AE9-45C3-BE60-4749513040A5.jpeg C1593A75-437F-403E-93BB-05C40C126605.jpeg
    gonzo likes this.
  29. ROADSTER1927
    ROADSTER1927
    I see no reason why you can't! Looks good, go for it!
  30. Duke
    Duke
