You dont get a second Stance to make a first impression... So, with that being said, who's ready for a Steadfast 1932 Ford highboy chassis??! We decided to tool up and build a simplified version of our high-end 1932 Ford highboy chassis. Same Stance, Ride Quality, and Parts. The 3/4 front wheelbase stretch and pinched rails will make everything look sexy around the grille shell! We left the motor/trans and pedal assembly mounts out so you can run any combo! All parts are Steadfast, Shadow rods, Pete and Jake's, So-cal/ Roadster supply. We built 4 frames and have only 2 left. One coilover and one buggy sprung. What you see is what you get. $12,500 Shadow rods frame rails with Steadfast Cross Members Steadfast Parts: rearend brackets rear pan hard front pan hard steering box mount thru frame bungs misc tabs Roadster Supply: 5" dropped axle hairpins GT2 shackles GT2 pitman Borgeson Vega Box Tie rod Kit drag link kit adjustable perches steering arms king pin kit 9" rear with axles Pete and Jakes: rear ladder bar kit rear spring Durant: Super low spring
Give yourself the gift that will keep on giving! Call today (419-632-3315) or email (steadfastmfg@gmail.com).
