  1. LN7 NUT
    LN7 NUT
    I wouldn't change that woodgrain, it's too cool IMHO, awesome Falcon!
    Love Radirs, fixed the dents and marks, shaved the handles, touched it inappropriately, chopped the top, lowered it, I would do this to one if i had one that wasn't the stretched one I have...
    I have a suggestion for this type of GM truck, I wanted to do this to my 55 Panel before I sold it, and I can't do it to my stretch because I am keeping the body stock... But if you graft the rear part of a pick-up cab where it juts out onto the rear fenders of one of these it will make it look a lot more finished, and just plain cool!
  2. LN7 NUT
    LN7 NUT
    I have a smart phone too... what a POS...
    I can do some of what you want, but I need more detail because my brain is running on half capacity today (migraine still) how do you want the labeling? A, B, C etc with A2, B2, C2, Etc. on the opposite part? Did you want a grid, or outline of the pieces to make them more defined, or some flashy 1980's Maxheadroom style grids that follow the lines of the parts (hard to do because it's guesswork) or do you want me to add rainbows and unicorns?
    Do you need text on the various components?
  3. woodywagon1965r
    woodywagon1965r
    Thanks for kudos LNZ but car has looked like this for now on 10 years wanting to clean it up again an redo maybe a little differant doing a lot more at the strip
  4. LN7 NUT
    LN7 NUT
  5. ShortyLaVen
    ShortyLaVen
    Any takers on this one? The Crown Vic part isn't necessary, as we cut the roof off today, but if somebody still wants to take a crack at it the guys in shop cl*** would get a real kick out of it. Thanks again guys!
  6. Nothing fancy, ABC thru XYZ continued thru both pics. Start with A on first finish with close to Z on second.
    Nice bright dimension lines for hole centers , material thickness, off sets diameters. Scale drawing is not important only a clearly marked reference.
    There's no need to do both pieces just the piece on the right in both pics . That's top and side view. Unless it becomes DIFFICULT AND CLUTTERD FOR YOU, that would be the only reason to do the left side of the photos.
    I don't think that there would be more than 12 dimensions in each pic.
    Text if you want 1947-48 p***enger car lower shock mounts.
    Thanks man and again nothing fancy.
  7. LN7 NUT
    LN7 NUT
    You want 26 lettered points? I'm guessing they would be spaced evenly... but wow, I was figuring a lot less then that...
  8. RI5KY
    RI5KY
    Thanks Russian,
    Here is my car just after we pushed it out of the booth
  9. Thanks for thinking about it. I must be having a hard time explaining What I need.
    if I thought pencil lines would show up I do like that. Evenly spaced lines would not be dimension lines. Dimension lines in the context of blueprints are a universal method used to tell the viewer what's being measured. Scale, and proportion proportion is not important.
    You guys are amazing artists with this photo shop and eyes for proportions. My project is more mechanical and not artsy in any way. If your not familiar with fabrication or blueprints or napkin sketches that maybe that's why it's difficult to understand the simplicity of what I need , how it should be done or why I need it.
    Thanks again and hope your headache goes away
  10. mason71
    mason71
    from Edmond, OK
    Awesome thanks!
  11. LowerthanLife
    LowerthanLife
    thanks pro1street ,she cleaned up nice, got her on the cover now.
    i think that two tone scheme was an original style paint; i seen a pic of a 4 door with it; liked it then , like it now. tasteful.
  12. Russian
    Russian
    the color is great! good luck with ***embly :)
  13. '54Caddy
    '54Caddy
    here ya go lowerthanlife. Dropped and chopped. Its a quick one and far from perfect but you get the idea. Anyone else who wants to build off it feel free.
  14. James D
    James D
    Is this something like it?
  15. ShortyLaVen
    ShortyLaVen
    That's so bad ***!!! Thats like exactly what I had in my head. Especially the one with the scallops. Chop is rad, too!!! I like the C pillars you used. Any chance you could make the roof green on the scalloped one?
    Again, that just looks too kool, man. Thanks!!!!!!!!!
  16. James D
    James D
  17. LowerthanLife
    LowerthanLife
    wow, 54 caddy, that looks great, its amazing how much more streamline it looks. its a stubby car, ya know.
    how much of a chop would you say that is?
  18. '54Caddy
    '54Caddy
    I'd say its about 3-4" front 5-6" rear. I think by moving the rear of the roof foward and making the trunk longer really helps make the car look longer. I agree how its a totally new look to the car and I think a little work could really pay off building it!
  19. zombiesarebad
    zombiesarebad
    from Maine
    would anyone be willing to stick some fadeaway fenders on my 41?
  20. LowerthanLife
    LowerthanLife
    i didnt even notice till you pointed it out, and i couldent agree with you more...when you cut the roof and leaned the rear down is that where it ended up naturally? it looks really slick...
    then you fill the deck in between,nice.
    im just wondering about the gl*** situation(s). the rear winsheild for example, is there another cars rear gl*** that would accomidate?
    and then the front? what are the options? plexi?
    the sides also, i guess the rear gl*** wouldent have to roll down , but the front doors would. Hmmmm? is plexigl*** typical to use or is custom gl*** the way to go???? these are just general questions, not targeted at anyone in particular, just throwing them out to ponder. what are your thoughts?
  21. James D
    James D
    Here you go. I tried full fade aways and... well.... it looked disgusting!
    Something like this may be your best bet.
  22. James D
    James D
    Plexi is supposed to be terrible. I´m not speaking from experience, but enough people have said it on here.
  23. KrisKustomPaint
    KrisKustomPaint
    The side gl*** should all be flat laminated plate gl***. No big deal to get it cut or cut it yourself if your that kind of guy.
    Rear window is probably tempered. Can't be cut in any sort of feasible sense. either lay it down or find another gl*** that is close and m***age the metal to fit the gl***.
  24. KrisKustomPaint
    KrisKustomPaint
    I'm a huge fan of fadeaways, but I couldn't get it too look right either.
  25. zombiesarebad
    zombiesarebad
    from Maine
    yeah, it does look pretty odd... but this is why I love photoshop. I might have actually done it! Thanks again JD.
  26. '54Caddy
    '54Caddy
    Where I cut it and moved it down is where the roof ended up. I slanted the B pillar as well. As for the gl***, Ive heard the same thing as James D about the plexi, although I have not tried it myself either. KrisKustomPaint is right about the side gl*** being able to be cut and the front and rear being tempered and very dificult to cut. Like he said either find a similar gl***, or you can hire a gl*** company to cut yours but most of them will not be responsible for broken gl***. Another option is get custom gl*** made(very, very pricey) or you can keep the stock gl*** and sink it down into the cowl.
  27. LowerthanLife
    LowerthanLife
    well, i know that tempered gl*** cant be cut.
    is gl*** from these years tempered?
    the side gl*** IS flat, so if it can be cut that would be the way to go, ideally.
    ive seen the oddball customs video on you tube , hes forming a sunroof for one of his cars 'in house' , i was impressed. maybe the 'new' plexi is better? what do you guys think? like acryic or something...
    and the whole sink the gl*** in the cowl thing, i suspected thats what some builders did but never actually seen how they did it, know of any threads or links on that?
    thanks guys.
  28. KrisKustomPaint
    KrisKustomPaint
    The Front windshield is normally laminated safety gl*** which can be cut but its tricky. Some back gl*** was laminated safety gl*** that could be cut but I can't think of any particular model off the top of my head. Mostly its just back gl*** that is tempered. Unless you're talking late model stuff. If the side gl*** is curved Its tempered.
    Just look real close at the edge of the gl*** you can see the laminate if its safety gl***.
  29. Bigcheese327
    Bigcheese327
    Please excuse the OT car, but I’ve always wondered what you fellows might do with one of these:
    Bellflower style? Redlines and 5-spokes? Moonshiner? Moon discs?
    I’ve always thought the XJ6 had pretty cl***ic lines, and might blend well with the earlier styles. My wife has recently expressed an interest in picking up one and stuffing our extra 327 into it.
    Thanks in advance,
    Dave
  30. HIVOLTJ
    HIVOLTJ
    Hey guys, could you 'shop this truck for me? I know it's not your usual request, but a color change of the truck and wheels is what I'm after.
    Much appreciated!
    I'd like the truck main color in the teal, and the roof top and back of the cab white, and the wheels silver, chrome, gray, just not that green!
    Josh
    The truck:
    (not our truck, a pic I found on here...)
    Main body color :
    roof cap color pearl white :
