  1. klazurfer
    klazurfer
    More stuff from the past ..
    Klaz:)
  2. VONRUBEN65
    VONRUBEN65
    from LOMITA
    Any help??
  3. MoparBruce
    MoparBruce
    Let me add my name to the ever growing list as well. Here's some old pics of an "A" sedan I'm working on. I'd like to do this in Texas Longhorn colors - Orange and White, but am unsure of where to cut up the colors. Open to any and all ideas.
    Bruce
  4. twochops
    twochops
    Lstude-------------------Lowered and cab extend.
    TwoChops
    OR with a bigger rear window
  5. chromepig13
    chromepig13
    Any chance someone could throw a little color to this one....got her all ready to paint and am swayin in the wind!!!...how bout suede black bottom and a gold flake roof? Or whatever at this point...THANKS!
  6. nailhead_brent
    nailhead_brent
    Anyone want to give this truck some color. I am working on it wit hmy dad and we will be getting it ready for paint soon, so Ideas are welcome! looking for older ford Grey, light greys and such!
    Thanks
  7. Lstude
    Lstude
    Looks good. Thanks!
  8. ClayMart
    ClayMart
    Finally got to tinker around on this Falcon a bit. It's a bit rough so don't look too close, and think of the paint job as "suede".
    I know I went a little nuts with the doors and I have a temporary fixation with Sunliner roofs but that will p*** soon enough. That style of mag wheel looks pretty good on it though.
    For those of you just getting started with PhotoShop, these might save you some time and frustration. If you want to undo your last action, try Ctrl+Z on your keyboard. It's quicker than dragging the cursor up to the tool bar. Undo multiple actions with Ctrl+Alt+Z. Want to quickly change the size of the eraser, airbrush or some other tool? Use the open bracket ([) key to go smaller or the close bracket (]) for larger. After a while you'll get hooked using some of these keyboard shortcuts.
  9. Claymart, thanks man that looks great, really appreciate the effort.Bit more wild than I was thinkin but, I love it
  10. James D
    James D
    You want a photoshop to see how this will look in light grey? Oooookkaaayyyy.
  11. twochops
    twochops
    lot of work for three words
  12. James D
    James D
    I know how you feel - TBH I would just do the ones you feel like doing, and do them because you have fun doing them. If it becomes "work", then leave it for someone else.
  13. James D
    James D
    This is awesome! Really trippy duuuude!
  14. James D
    James D
    "The angriest truck IN THE WORLD". Fact.
  15. nailhead_brent
    nailhead_brent
    Well I meant like ford grey or dove grey. and more of a gloss finnish, since it is only in primer now!
  16. mikes51
    mikes51
    Here are a few moldy oldies I did.
    scavenger pipes rule!
  17. twochops
    twochops
    James D ---- the beautiful photoshop you did on converting a
    4 door woody wagon onto a convertible would be next to impossible
    to improve on. But the 4 door had room for improvement.
    Twochops
  18. evilgenius
    evilgenius
    A few tips for a really good photochop:
    1 - be careful not to oversaturate color changes. if the color looks too disney and the rest of the photo doesn't match, it doesn't look real. and vice versa. control the saturation by playing with the middle saturation bar which comes up when you press CMD (Ctrl) + U.
    2 - same with the type of light. if the light is too contrasty in relation to everything else in the picture, it won't look right either. use Levels (CMD + L) or Curves (CMD + M) to fine tune your layers.
    3 - to make pinstripes actually look like pinstripes, knock down the opacity of the layer until it looks right.
  19. American Hellbilly
    American Hellbilly
    from Seymour,IN
    This is my first try at photoshopping. Its not my car, but it is the same as mine. I wanted to see how it would look lowered.
  20. yule16met
    yule16met
    from Hudson, WI
    I want to build a hood for the modified! same color as the cowl and grill shell. loose the scoop, keep the pipes.
    And do whatever else you think I could actually do to improve the look. I would like to do frame covers along the side to elongate the look of the lower part of the body.
    I didnt know which picture would be better
  21. BAD ROD
    BAD ROD
    Looks cool! But, that is a Starliner roof, not Sunliner! :)
  22. James D
    James D
    I think you are on the right track with a hood and sides. Maybe a belly pan would be a good way to get some depth into the body. I did wonder about black steel wheels and caps for a more od timey look, but I kind of like what you have actually. I might look out for a Model T fuel tank to replace that aluminium one though. Great little car!
  23. yule16met
    yule16met
    from Hudson, WI
    that looks awesome. Feel free to play around with it as much as you like. I like the belly pan but the grill shell sits between the frame rails so It couldnt turn out that smooth. I think I would have to make a speed bubble or scoop in the side pan to let the pan out with style.
  24. Equipped28
    Equipped28
    could some one put a tail dragger stance on this pic off my morris minor perhaps recolour it black with some gold steel wheels and whitewalls and put some spotlights on the cowl oh and could you try to remove the tail lights
    thanks in advance
  25. ClayMart
    ClayMart
    D'OH!!! Boy, is my face red! If I wanted a Sunliner roof I'd of just cut it off and got rid of it! Maybe I'm getting over my Starliner fixation already. :confused::confused:
  26. hkestes
    hkestes
    Rickster,
    Thanks! I do like them both especially the second one, but I know I don't have the skills to pull that one off and doubt I have the bucks to pay someone to do it. I do like the shiney paint and the reference to semi-gloss or flat was more as an interem step as the paint on the car is pretty much dead now and does not look nearly as good as the picture. Still working on the mechanicals so not ready to do all the needed body work to replace the rockers etc but since it is a daily, I need to do something with the paint before winter gets here to keep it from getting worse than it already is.
  27. James D
    James D
    Probably an immense amount of work to cut up a unibody Morris Minor to the point where it drags *** - which may be why I´ve never seen it done - but this would look pretty good if you if you could do it right. I´d leave the top stock height, simply because it looks so ridiculously tall!
  28. cleatus
    cleatus
    from Sacramento
    Nice job man, that is beautiful!
  29. Horsepower67
    Horsepower67
    This is *****in, please build it.
    To really go for the kill, I'd chop it 2-1/2 inches and re-shape the rear of the roof.
    Hey Rikster, any ideas?
  30. James D
    James D
    There have been a lot of these chopped and often very successfully. Its all the rest of the mods that are a real challenge. There is realistically no way you´d get one that low without building a ch***is and starting over.
