  1. swade41
    swade41
    from Buffalo,NY
    Could I get the license plate removed on the Willys please, thank you
  2. Squablow
    Squablow
  3. themoose
    themoose
  4. swade41
    swade41
    from Buffalo,NY
    Thanks guys, my friend is weird about that
  5. justabeater37
    justabeater37
    Can someone do a slant vs straight B pillar comparison with all of the pieces obviously in the right places. Hopefully get everything fit tonight and finish welding it all tomorrow and build a new catwalk. The rear spring is on backorder so this is close to the stance. Lowering it 3” in front 5-6”in the rear. The tsildragger rake should be close with the front wheels on the skates. A2284C7F-F962-42FB-8E26-6E4B54CBDAC1.jpeg 6D839792-84C3-46C6-A48C-E766A5F2753F.jpeg
    kidcampbell71 and loudbang like this.
  6. James D
    James D
    6D839792-84C3-46C6-A48C-E766A5F2753F.jpeg I like it. Its pretty subtle.
  7. buick bill
    buick bill
    from yreka;ca
    im not sure what goes on over here . be gentle its my first time . im just trying to see if someone can alter my pix to show what my 41 will look like dropped 3 or 4 inches and maybe chopped the same . its all above my pay grade . so if you could it would be grt.!! DSCF5602.JPG DSCF5604.JPG
    54delray and Peanut 1959 like this.
  8. Unclebrad
    Unclebrad
    Looks to me like 3/4" doesn't make a lot of difference. but...
    Peanut 1959 likes this.
  9. Dick Stevens
    Dick Stevens
    I suspect he meant 3" to 4", not 3/4"
    Peanut 1959 and lurker mick like this.
  10. 1946caddy
    1946caddy
    from washington
    Would look better if the rear wheel was centered in the rear fender.
  11. buick bill
    buick bill
    from yreka;ca
    sorry for the confusion . 3 to 4 inches . is what i meant . my wife and i have had similar miss communication . several times ! and i will never understand why the wheels werent centered as built . but i guarantee when i lower it i will fix that . if nothing else
  12. buick bill
    buick bill
    from yreka;ca
    how about a straight b pillar , never saw that in a cheby coupe ! and maybe sme un hamb 20 inch steelies with knock offs ?
  13. southerncad
    southerncad
    No, no, no.....
    bobbytnm and 54delray like this.
  14. buick bill
    buick bill
    from yreka;ca
    no to which ? or all the above ? the only thing likely to materialize is 3 inch drop . but some type of 5 soke wheels will probably come and go . depending on my mood . once im rid of 4.11s my wheel tire options are wide open . well not to wide . tubs are not in the mix !! but shorter tires with thinner w/w might give a totaly different look . right or wrong !
  15. gatz
    gatz
    The rear axle of a '40 Chevy Coupe that I owned at one time had been replaced with one from a '57 Dodge.
    The holes in the perches to align to the springs of the Chevy and Dodge rear-ends were not the same, and it caused the rear-end to be forward too far; just like the pic above.
    I can't remember which was off-center, but one was, and one was on-center.
    Seems like it was only about 3/4" or maybe 1" at most......enough to make a difference.
    54delray likes this.
  16. buick bill
    buick bill
    from yreka;ca
    maybe , but these chevys were built with the rear ends off cntr. . my best bet is it was because the rear w/torque tube moved back under compression . but im sure the engineers new more than i will ever figure out ! i think all gm cars had the same location in these years ?
  17. Unclebrad
    Unclebrad
    Someone else is going to have to do the wheels (I have to do some other things today) but here is a chop and drop. I can go farther if you like. DSCF5602b.jpg
  18. buick bill
    buick bill
    from yreka;ca
    thnx , thats where im heading . the chop will probably .never happen . i did sit and dream about the first cut . but i did the gl*** and headliner to put it out of my mind . still i could get a wild hair . the al***ude is in the very near future . if my shop wasnt such a mess id start today . could set my goals a little lower and clean the shop .?? what the hell . im pretty good at stepping over **** . havnt had a real bad tripping incident . yet !
  19. buick bill
    buick bill
    from yreka;ca
    thats just bad *** !!!
  20. Squablow
    Squablow
    A straight pillar chop would be tough to pull off in real life, you'd probably have to source some 2 door sedan doors and pillars to make it work. That said, I don't hate the look, it's actually much nicer than I would have thought.
    No ****ing way am I adding 20" wheels to this picture though.
  21. buick bill
    buick bill
    from yreka;ca
    it was really a joke pertaining to the 46? ford coupe chop above . but it does give it a unique AND cool look ! if it was only that easy in real life . as to the low hanging fruit . it ****s that i am getting to where i dont want to cut something that is original and in decent condition . but the beauty of a 41 sd coupe is it seems like there are more around now than were built . so not rare . id hate to guess how many chopped are around .and throw in the 46/48 and im sure i cant count that high. if your real good a 3 inch chop on a ford will almost make it look like a stock chevy ! dont ask how i know !!
  22. Stan Back
    Stan Back
    Make a hardtop out of it and don't worry about the center post. And if you drive it seldomly, screw the side gl***es for style.
    54delray and buick bill like this.
  23. themoose
    themoose
    @buick bill
    OK...Get out the torches , body hammers and lead.:D
  24. buick bill
    buick bill
    from yreka;ca
    thats what im talking about . i never even dreamed that approach . the hard top would be so cool as well . im not sure where you would start . hammer , chisel ? .......hacksaw ? those wheels really work to ! id really hate to replace my rambler wheel covers , but at least they were cheap !! im really wanting to see the stock roof line in silver or silver metallic !
  25. 1946caddy
    1946caddy
    from washington
  26. quick85
    quick85
    While not wanting to step on the toes of 7berkmerc and Moose, they both did
    a great job eliminating the newer vehicle, I wanted to take the pic a step
    further. Not knowing what the lettering on the radiator shell signified, I removed
    it. I had to wait as the street sweeper rolled through and cleaned up the leaves,
    then tried out the black & white look. Now it looks like it could be on Ricky Nelson's
    block. Cropped as a 5x7.
    I don't have Photoshop so I'm pretty much limited to simple "repairs", but I have to say
    that you fellows on this thread sure know your stuff.
    7berkmerc, themoose and loudbang like this.
  27. quick85
    quick85
    Good change, but I wouldn't mind having the Camaro, with the 200s'.
  28. buick bill
    buick bill
    from yreka;ca
    are those wheels sabre . i thought they were spokes ? whatever they are they work. if i had that drop with those whees and a silver top , i think id be good ! would be interesting to see the hard top treament though . i dont think ive seen it on a 41 . YET......................
  29. themoose
    themoose
    Lowered with no chop....
  30. 1946caddy
    1946caddy
    from washington
    They make reproduction sabre wheels for between $1500 -$2500 each. I've got a set of originals that cost me $1000 and they wanted $1000 each to restore when I checked about 5 years ago.
