  1. Equipped28
    Equipped28
    thanks for the photoshopped pic
    it looks so dam cool ive got 3 years till im legal to drive here in the uk so ive got enough time to build my minor how i want it i was thinking about leaving the front stock height and just throwing some 2 to 3 inch lowering blocks on the rear axle to get her low enough so to speak but as you say no real way of slamming it straight on the floor without at least a ch***is
  2. James D
    James D
    I don´t want to be the one to set you on a course that will end in the total destruction of your car.....
    ......but I wonder if you could cut the whole floorpan out and channel the body down lower? The front is easy to lower on torsion bars, the back on blocks.... could work......maybe!
    (Disclaimer - The author has no f§?king idea what he is talking about!:D)
  3. cleatus
    cleatus
    from Sacramento
    Here is a photoshop that Scott at Blue Collar Custom had me do to help them determine the paint layout for Poppahet's 56 pu.
    Original photo.
  4. cleatus
    cleatus
    from Sacramento
    And the photoshop
  5. Equipped28
    Equipped28
    yeh i can see what you mean about channeling the floor
    as lowering the front is allready low as its prob had 40 years of some fat *** S.O.B sitting in it every day :D
  6. cleatus
    cleatus
    from Sacramento
    If you look at the photo of the truck in the recent Rodder's Journal, the final paint layout is almost a dead on match to the photoshop.
  7. James D
    James D
    Be fair now, they´ve had to support the weight of that colossal motor all these years.:D:p
  8. James D
    James D
    Very nice. Any pics of the finished truck?
  9. cleatus
    cleatus
    from Sacramento
    Here's a before & after concept photo illustration that I did for one of Roseville Rod & Custom's projects. The finished car is nearly identical to the photoshop.
  10. Equipped28
    Equipped28
    now thats true all 48 hp and 1098cc of the little 4 cylinder haha:D
  11. leachafreak
    leachafreak
    from dayton,oh
    i dont know what color i want my car.help me!i have had my car photoshoped before an the only one i liked is black on black but i want something different.the only thing i know i want is fat white walls, the frame inside the body and he body dropped to the floor.but what colors(flat and/or gloss) would look good on body an wheels?
  12. mikes51
    mikes51
  13. Equipped28
    Equipped28
    now that is just plain kool!!!!
  14. mrbthebarber
    mrbthebarber
    That's some cool s!!t going on there guys keep it up!
  15. leachafreak
    leachafreak
    from dayton,oh
    you must be rich i gota dig deep to get my chevelle out running turbo blue
  16. ClayMart
    ClayMart
    Thanx for adding to the PS tips. I hadn't really thought about how to add the pinstriping to one of these jobs, but you got me to thinking. This seems like a job for the Pen tool and then stroke the selection with a 1 or 2 pixel brush. Or layout a color panel with the Pen tool, convert the path to a selection and fill with color. Then double click the layer for the Layer Effects dialog and add a 1 or 2 pixel Stroke of color around the panel. Or if there's an easier way, please add it here.
  17. NotNuRodz
    NotNuRodz
    I dont want to nag guys but, i'm about to take the body off and get some paint and i still have no idea on colors, I was thinking black with green firewall and motor but i'm open to anything, I know its not that easy (and thats why i havnt done it myself) I really admire a lot of your work and would greatly appreciate the help so here is the picture again.
    (I know this picture is really bad quality, but i have a lot better picture just with out the wheels and tires it has now so if you need it let me know)
  18. glendale
    glendale
    i have been thinking about picking one of thes up as a commuter now i have to luck harder.
  19. zodc
    zodc
    Or channeled into the fenders!
  20. James D
    James D
    I use "Illustrator". The new versions have a transparency setting so you can layer stuff up nicely and it does nice clean line thicknesses. Perfect for those Watsonesque panel paint jobs.
  21. James D
    James D
    There´d be nowhere left to sit!:D
  22. evilgenius
    evilgenius
    that's more or less how i do it.
    whenever i do scallops, i want to make sure i'm not subtracting detail from the original paint job, if you just make a selection and fill it with a color you lose all sorts of goodies like reflections, gradations that imply body shapes, etc. i take the pen tool and i create my shape, turn the path into a selection, and then copy an area of the body into a new layer, and then change the color either thru the hue/saturation panel (cmd U) or curves (cmd m).
    after i get the scallop the color i want it, i hold down CMD (or CTRL on a pc), and it creates a selection out of the scallop layer's outlines, and on a new layer above that (cmd c, cmd v), i fill it with a color, select > modify > contract 1 pixel, and cut that out (cmd x).
    then i start knocking back the opacity of the layer until it visually looks correct. basically the smaller the picture, the most translucent it has to be, and the larger, just the opposite. it's just good to have a small bit of transparency in there to kinda play off the light that's happening on the paint.
  23. James D
    James D
    Mid metallic blue with gold motor? (This is a bit too much of a vivid blue, but hopefully you get the idea)
  24. Rikster
    Rikster
    My version.. based on James D... I think its a bit to low, but I had no time to adjust that.
    I chopped the top, but more in the back. And I also added material to the side windows to make the lower edge more in line with the windshield. This way the windshield doe snot look over chopped as is the case in many of these chops.. And some more other subtile things.
    jimcolwell likes this.
  25. bobj49f2
    bobj49f2
    This turned out to be an great thread. If I wasn't loaded with work, working long days, both at my business and on the farm, and in the middle of moving my business I'd be on the thread.
    A lot of great work. Keep 'em coming.
  26. Equipped28
    Equipped28
    that chop looks *****in there's some nice subtle touches like the grill surround and hood badge
  27. Equipped28
    Equipped28
    i allways fancied seeing what flipper style hubcaps would look like on a morris minor
  28. kaspar
    kaspar
    Gloss chocolate brown and khaki/beige. Gold (which is a p.i.t.a. to fake in Photoshop) engine and striping.
    [​IMG][​IMG]
  29. Rikster
    Rikster
    Posting this Hudson for JackShaft
    JackShaft modified a 1949 Lincoln Cosmopolitan Town Sedan (4 door, fastback roofline) Which he made into a 2 door sedan retaining the roof line.
  30. James D
    James D
