  1. bbdiamond
    bbdiamond
    from ROY, Utah
  2. fine29
    fine29
    from Des Moines
    Can I get some colors like maybe a candy purple put on this car? open to other colors as well... thank you in advance.
  3. skoh73
    skoh73
    The photo looks a little blurry- It'll probably get done quickly with a better photo. :)
  4. fine29
    fine29
    from Des Moines
    okay Ill try to get one only had my cell phone.
  5. HotRodNisse
    HotRodNisse
    ZIL 111 A ЗИЛ 111 A :cool:
  6. DrivenDead
    DrivenDead
    Anyone want to take a stab at this? I want to color it the same as the green stripe sitting there with black scallops, maybe white pinstriping separating them. I also have lake pipes for it. I would love to skirt her and sit her in the gr***.
  7. BUDDY HOLLY
    BUDDY HOLLY
    can someone photo shop my car and put white wall cheaters on back with one fifty hubcps and raise the front like a straight axle. please
  8. RichG
    RichG
    okay.
  9. Any grill shell ideas? Maybe 39 ford truck?? Thanks Kelly R.
  10. skoh73
    skoh73
    Here's one- not sure if it's along the lines of what you're thinking, but it's a start...
  11. Coke-bottle
    Coke-bottle
    Wow, nice. That's exhactly what I need, thank you al lot Straight8!
  12. HotRodNisse
    HotRodNisse
    GAZ 24 Volga :cool:
  13. Javier
    Javier
    now could you add wide whites and full moons please
  14. chrisclarkcustoms
    chrisclarkcustoms
    from las vegas
    I realy like the red trim... hows this?
  15. Javier
    Javier
    awesome!!thanks:)
  16. RichG
    RichG
    that looks SHARP! Nice!:D
  17. HotRodNisse
    HotRodNisse
  18. 57FORDF100
    57FORDF100
    from bell
    hey guys can some one scallop the car for me the same green as the top please
  19. Man you guys are good !!!
    Thanks in advance for your help on this one
    I have been doing some pencil mock ups and have narrowed it down to several ideas. I would like to see a photo before I start cutting. I will be running a 31" rear tire lined up in the 34" opening, and a PO 2-1/2" chop, Dont want to run the fenders.
    problem to solve .... is that the bottom body line will be 18" off the ground and sitting on a 6" frame giving me the 12" of ground clearance, typical "Highboy" I want it about 3" lower, but lowering the wheel arch body line past the top of rear tire is not an option for me.
    I would like to see the rear wheel well moved up or sectioned about 3" or an amount that looks good and proportionate to you.
    next i would like to see the rear wheel arch left alone but 3" added above the lower body line, lowering that area between the rear wheel opening and cowl closer to the ground by 3" and the 6'' of frame 3" lower. I'm sure this will be easier to pull off in real life but I'm a bit worried it may look kinda funny.
    Stock body photos and drawing in the thumbs.
    and a hamb pic of one sitting up on a ch***is thanks drgrcr50
  20. RichG
    RichG
    I THINK I understood what you are after...I channeled the body roughly 3" over the frame, keeping the rear wheel reveal in the same place. I also ended up dropping the radiator about 6-8" as it looked way too high from this angle...is this right?:D
  21. 57FORDF100
    57FORDF100
    from bell
    not really what i was looking for any one else wanna take a stab at it
  22. skoh73
    skoh73
  23. classic1952
    classic1952
    from pacoima ca
    can anyone chop my chevy and lower it all around on the ground, flat black the body and to a lime green on the top and match the top color with the rims????? please!!! im trying to see what im goin to do with it...
  24. Merry Christmas electrodude!
    sorry the change is so sublte I cant tell
    option #1 the roof line would also be closer to the ground , the wheel arch would be moved vertically closer to the rear1/4 window
    and option #2 the roof line would be the same distance from the ground, the arch stays factory but 3'' added above the bottom or lowest body line making the door, cowl and only the small front most part of rear1/4 3'' taller but lower to the ground
    sounds like you took a stab at #1
  25. RichG
    RichG
    The pics are pretty close, that's why I put both the original and the photochop together, that way you can click "next" and flip between them. I think if you notice the frame reveal that it shows the greatest difference:D
    I started to screw around with idea #2, but to be honest it started looking like a real turd:( Adding that much to the car seriously screws with the proportions...
    If you can, find a straight on side view, that might give a better representation of the change.
  26. here ya go , Better ?
    They are kinda hard to find I had to borrow this one
    Thanks Druss32 for the pic
  27. pro1street
    pro1street
    I couldn't really do much of anything with the supplied photo so I found another picture to work with.
    Personally I prefer the lighter color over the black,just my opinion.
  28. RichG
    RichG
    Alright, stab #2 :D
    first pic: stock photo
    second pic: body channeled 3" over frame with stock rear wheel reveal
    third pic: same as second but with the wheel reveal raised back to where it would have been with the body unchanneled
    (I painted on the body just to remove some of the distraction:D)
  29. HotRodNisse
    HotRodNisse
    :cool:
  30. Equipped28
    Equipped28
    i got photoshop for xmas so been messing around with it
