Projects The ROG "T" build.
Discussion in 'Traditional Hot Rods' started by Pete, May 22, 2014.
  1. Pete
    Pete
    I bought this really cool GEMMER F1 style box a few years back, its from a Correct Craft boat. Its perfect for the T because the column is just the right length and it has a 360dg rotational flange....so you can mount it anywhere, unfortunately it rotates in the opposite direction because it controls a rudder which is in the rear of a boat. SO i mounted underneath the frame and pointed the pitman arm up....problem solved.
    Stogy and volvobrynk like this.
  2. Pete
    Pete
    Ill just have to remove the interfering bracket.
    Stogy and sko_ford like this.
  3. Pete
    Pete
    I started playing with pedals and clutch rods, this saturday will be the big day in the shop.
    sko_ford likes this.
  4. thunderbirdesq
    thunderbirdesq
    I've got a steering box just like that that came out of a forklift. Lookin sharp Pete!
  5. jugheadjones
    jugheadjones
    Cool project. Looking forward to seeing more!
  6. Pete
    Pete
    Pushed the T in the shop tonight....tomorrow its go time!
  7. Pete
    Pete
    Made some good progress today. I had a plan,,,,the plan was to repurpose everything I removed from the ch***is...
    The first thing I tackled was the motor mounts, I repurposed the rear crossmember ends that were cut off when the frame was pinched. They had the correct shape and just needed a little messaging.
    I think the hardest part was separating the damn gussets from the pieces I needed,
    Stogy likes this.
  8. Pete
    Pete
    Second was the transmission crossmember. I repurposed the mechanical brake equalizer cross shaft. I removed the bell cranks from each end and the center brake light switch shaft. I trimmed the overall width down, made a mount for each end than clamped it in place. I used the original outside transmission vibration plates for the new ****** mounts. Used a hole saw to locate the mounting holes than traced the donut and cut it.,,,,,,worked out awesome. transmount1.JPG transmount2.JPG View attachment 2671198 View attachment 2671200
    Stogy and moose like this.
  9. general gow
    general gow
    MODERATOR
    Great work, Peter. Really cool details. I wonder if those cross shafts are wide enough for me to use one as the trans mount in the 34...I have a few in the stash.
  10. moose
    moose
    Pete- good to see this in person yesterday. You're doing it all right, and your brother is going to waste it;)
    Mark make sure to save some brake parts for me!
    general gow likes this.
  11. Pete
    Pete
    Had an old Jeep YJ front bumper laying around so i took a few measurements and its the same dimensions as the model a frame. The bumper already had factory holes for marker lights so I used one of them as the pedal mount pushrod hole. Had to also make a little belly on the bottom cuz the pedal mount hung a bit lower.
    Plans are to cut another chunk for the other side and make a bridge over the trans and connect the two....the bridge will bolt on so i can gain access to the ****** tower in the future.
    Stogy likes this.
  12. Coming along good Pete.
  13. Pete
    Pete
    Im really hoping to take it for a spin in the next few weeks....
  14. onekoolkat1950
    onekoolkat1950
    Me too!
  15. general gow
    general gow
    MODERATOR
    Call me! I wanna be there!
  16. gonzo
    gonzo
    Saw it Sunday and it looks great. That Pete sure is a clever guy, thank god you pulled that banger out and off loaded it on some poor unsuspecting yocal! Four to plow, eight to gow!
    Stogy, general gow and volvobrynk like this.
  17. general gow
    general gow
    MODERATOR
    Look who thinks he's funny.
    @gonzo
  18. moose
    moose
    Hey, I resemble that remark!
    Stogy likes this.
  19. gonzo
    gonzo
    Don't worry Moose, your bad taste in hot rod motors is MORE than made up for by your good taste in beer, moonshine and syrup. :)
    What you mean "thinks" @general gow Me never "thinks".
    Stogy and general gow like this.
  20. Pete
    Pete
    It's a great motor for a lawnmower...
    gonzo likes this.
  21. Speedy Canuck
    Speedy Canuck
    You must have a hell of a lawnmower! Or a hell of a lawn.
    Stogy likes this.
  22. CaliDreamin'
    CaliDreamin'
    Cool build, keep up the good work….
  23. Pete
    Pete
    Dug out the seat..or new office chair. Old Military seat, should be just fine.
    Stogy and gonzo like this.
  24. general gow
    general gow
    MODERATOR
    ya dude. looks pissa.
    Stogy likes this.
  25. gonzo
    gonzo
    Plenty of room for a driver, a cold beverage and not much else.
  26. general gow
    general gow
    MODERATOR
    @gonzo, yup. I crawled inside mine briefly before I blew the body apart, and I'm not gonna be able to make good on all the 'shotgun at ROG' promises I've been making...
    Stogy likes this.
  27. gonzo
    gonzo
    That's what laps were made for @general gow
  28. patmanta
    patmanta
    from Woburn, MA
    I DON'T SEE WHY NOT.
    Git'chu one'a these & drop it in shotgun!
  29. Pete
    Pete
    A few small updates, nothing major. FInally got the clutch linkage, steering box and lots of other small **** done or at least figured out. The steering box had me all screwed up....It fit perfect underneath the frame but that left me nowhere to hand the bones. There was no room to leave them un-split or even slightly re-locate the original mount. I ended up machining the mount to match the angle of the column and slid it inside the frame but had to move the box back enough to clear the exhaust port...ill have to shorten the column now.
    I used a 25 T upper windshield and stantions, just like them better. I removed 11-1/2" inches from the posts and leaned them back a bit.
  30. steel rebel
    steel rebel
    That's why vertical steering was used on some.
