The "Suede" Look?
Discussion in 'The Hokey Ass Message Board' started by InjectorTim, Jun 1, 2005.
  1. InjectorTim
    InjectorTim
    So I can see the need to paint my buick sometime in the near future after I get it get running, I've seen some of these cars with flattend clear or no clear at all. I think its a cool look, almost has a pearl quality to it, it also wont take ten years of bodywork. So it seems like a middle of the road thing, nicer than primer, easier than paint. Do any of you guys run without clearcoats? It seems like putting a flatening agent in the clear is the way to go. any tips? tricks? advice? opinions?
    Here is an example from the paso post that i really dig
  2. 54BOMB
    54BOMB
    that looks really good, do you think they added pearl to the clear or is it in the base color?
  3. We're spraying the body of my wagon in just a basecoat. Of course it won't have the protection of something that's cleared...but it'll be much better than primer.
  4. Slide
    Slide
    You should really do a search on this. The subject has been brought up about a thousand times.... in the past year. There's a lot of good ideas/suggestions in some of those threads. :)
  5. Hellfish
    Hellfish
  6. InjectorTim
    InjectorTim
    well, I have never seen it done, but at the shop we have a can labled "Matting Agent 1:1 flat 2:1 semi-flat" I guess This gives you the look and the protection.
  7. InjectorTim
    InjectorTim
    well the link above told me that base with no clear is probably a bad idea, but what about the matting agent? can you use it in single satge and get the similar results? and in general, have any of you guys who have used the stuff have any tips? Tricks?
  8. InjectorTim
    InjectorTim
    and in the old post, bobbleed said that "base only" route worked fine for him, you just have to recognize the limitations and put a good sealer under the color. But I'm sure the bleedster isn't driven through rain and snow? I'm thinking in terms of daily driver.
  9. Merlin
    Merlin
    from Inman, SC
    It don't look too bad!
  10. 63 wildcat
    63 wildcat
    you have to be really carefull with just base it seems to want to rub off easy. i used clear with a flattening agent [​IMG]
  11. InjectorTim
    InjectorTim
    the car looks good wildcat, did you come across any problems?
  12. TimBob
    TimBob
    THAT car and color RULE (in case you weren't aware of that). Any bigger / outdoor shots?
    Did you find that the flat clear 'killed' the look of base at all? Is it a straight metallic or a pearl?
    Cheers,
    TR
  13. InjectorTim
    InjectorTim
    yes theese are all questions I want to know!
  14. 63 wildcat
    63 wildcat
    the only problem that i had was i tiny water bubble in the trunk because of the moisture(it was raining whe my brother shot it)the paint is 80% pearls
  15. 63 wildcat
    63 wildcat
    i have more picturesbut i dont know how to put them up :confused:
  16. hey mate,
    a friend of mine had his car shot with a metallic basecoat with no clear and its lasted excellently with no problems.
    danny
  17. TimBob
    TimBob
    Got 'em. Gorgeous car.
    Hope you guys don't mind the O/T lace paint :D ...
