Projects The Swamp Yankee Coupe
Discussion in 'Traditional Hot Rods' started by JRN1967, Jan 10, 2021.
  1. v8flat44
    v8flat44
    Oh what a deal....i smell BANGER in the air......??? Sweet as a freshly glazed donut ...
  2. sloppy jalopies
    sloppy jalopies
    A true swampa ...
    most of the swampers i have hauled home had either been rightside up and had 4" rotted off the bottom, or they sat upside down and the roof rotted off... about the same job as you have "hanging"...
    your split level pic shows what must be done...
    when the splicing is done it looks like it is gonna be the "swamp queen" whatever engine does the work.
  3. JB401
    JB401
    Sweet sport coupe! I guess I missed that add for a $4500 dollar, local sport coupe! Ha. I'll be following along this time
  4. roddering
    roddering
    from Arizona
    Wow, great deals. You are a lucky one.
  5. mike bowling
    mike bowling
    There’s a crew that shows up at the New England Dragway and a couple of Model A swaps I go to.
    They call themselves the “ Swamp Yankees” and drive some pretty cool cars.
  6. JRN1967
    JRN1967
    from Monson MA
    Thanks Smitty, I'll be adding a few more pics here soon. Stay tuned!
  7. JRN1967
    JRN1967
    from Monson MA
    Hi Mike, I haven't made it to the New England Dragway swap meets yet. Being from the CT border I generally head to the Stafford or Bristol swap/shows. The Swamp Yankee's must be a cool bunch.
  8. JRN1967
    JRN1967
    from Monson MA
    Just before I started the Coupe Top Conversion - I posted it one last time on the Ford Barn.
  9. JRN1967
    JRN1967
    from Monson MA
    With no bites on any of my adds, I felt no guilt moving forward on the conversion. Well, maybe I still harbor a tiny bit... But I wouldn't let it stop me.
    My first plan was to use the complete drivers side quarter. But the more I looked it over, the bottom half of the sport coupe was so much better.
  10. JRN1967
    JRN1967
    from Monson MA
    I toiled over exactly where I wanted to make the cut. Finally I decided to use the upper belt line, because on both sides of the car, those pieces were less dented and only had surface rust that could easily be cleaned.
    Outback, brEad, Nailhead A-V8 and 5 others like this.
  11. JRN1967
    JRN1967
    from Monson MA
    I went ahead and cut the sport coupe first, then cut the coupe top oversized so I could grind and file my way to nice even fit. I must of taken that piece on and off about a hundred times to get that seam the way I wanted it.
  12. JRN1967
    JRN1967
    from Monson MA
    Little by little I just kept working at the fit. Like I say to everyone that comes inside my garage. Sorry about the mess, but I do a lot of work in here,,, when I'm off work...
  13. JRN1967
    JRN1967
    from Monson MA
    The lower quarter panel attached to the door pillar and rear roof section are a big help keeping things lined up. Using them as a guide it was just a matter of making the belt line match my 30 coupe that was parked just outside the door.
    Dirty Dug, jaracer, brEad and 18 others like this.
  14. sloppy jalopies
    sloppy jalopies
    Holy cow,,, if the lower quarters i got from you clean up as well as the roof quarter pictured i may have to buy you a Montreal steak when this c19 has p***ed... ... go swamp yank go !
    For any rodders doing a sheetmetal splice try this ;
    measure and mark well...
    trimm both 1/2" or more too big...
    cut to fit the B and C pillars...leave the skin long...
    set up the panels with magnets....
    when right use klecos or tack weld the overlap inside and out...
    then slap a metal cutting blade in a heavy duty sabre saw...
    use a wizzer to cut a starting slot for the saw in the center of the overlap...
    this cuts both pieces at the same time...
    remove the klecos or tack welds ...
    sand a little bevel on both and weld that baby back together...
  15. JRN1967
    JRN1967
    from Monson MA
    Appreciate all the tips-advice I can get... I know I took several pics doing the p***enger side, but I can't seem to find them. Here is the right side after I finished.
  16. JRN1967
    JRN1967
    from Monson MA
    That's it for the body in 2020... My next goal is to complete the running gear by August 2021.
  17. sloppy jalopies
    sloppy jalopies
    i like it... my vote is with the V8... go man go !
  18. adam401
    adam401
    Looks great. Now for a haircut........
    wheeldog57 likes this.
  19. sloppy jalopies
    sloppy jalopies
    or channel the living pits out of it...
    Moondog13 and adam401 like this.
  20. adam401
    adam401
    Also a fine regionally appropriate option.
  21. sloppy jalopies
    sloppy jalopies
    cool cars, square rollbars reads west coast chop, east coast channel... i can dig that...
  22. wheeldog57
    wheeldog57
    Neat ride, kid! Wicked pissah!! I'm pretty sure I drove by your place this summer. Hard to miss those hot rods in the driveway
  23. JRN1967
    JRN1967
    from Monson MA
    Thanks Wheeldog - If you're ever in the neighborhood go ahead and pop in... BTW I added your Another New England Build thread to my fav's many moons ago. Ummm, Those doors look mighty familiar... Just sayin..
  24. JRN1967
    JRN1967
    from Monson MA
    Once again I want to say thanks to all for the likes and kind words... I'll be drawing from your experience and ideas throughout this build.
  25. JRN1967
    JRN1967
    from Monson MA
    As I said earlier, I accomplished the top conversion goal for 2020 and decided my next objective would be to complete the running gear by the end of the summer of 2021. I'm imagining a future video of some sort, minus the straw hat..
    I already have a slightly hopped up 4 banger in my 30 coupe, and I really enjoy driving it... 3,000 miles last summer.. So I decided on an AV8 with a 39 type trans attached to the original banjo rear and torque tube. I put out a wanted add and started the next leg of this journey.
    My wanted add got a lot of attention and I was about to strike a deal on a 59ab with 40fords ( a very helpful person)... But dono50 replied to my add and said he had an 8ba that he rebuilt himself. Bob only lives about an hour away so I couldn't p*** it up.
    Outback, brEad, chryslerfan55 and 8 others like this.
  26. sloppy jalopies
    sloppy jalopies
    Spit-balling but you can run the early 59AB heads on the 8BA blocks ... i think they look better...
    there is a water p***age near the dist. tiedown... it is about .3??" diameter...
    had the boys in the tool room turn a br*** plug down for me... froze it and installed it cold... never leaked...
    many 59 ab heads were produced, but the 8BA heads were competing with the new overhead valve engines... not so many choices ...
    chryslerfan55, 48fordnut and loudbang like this.
  27. wheeldog57
    wheeldog57
    In a round about way, thanks for the doors. Cool man, see you around
  28. JRN1967
    JRN1967
    from Monson MA
    I needed space between the rails so I placed an add for the engine.. In just a couple days I sold it to a man from Upstate. He wanted it right away, so I wasted no time... I'll miss the little engine, I enjoyed bringing it back to life.
  29. 210superair
    210superair
    from Michigan
    That flat8 is going to look incredible in there tho.... Car is looking really fantastic, keep movin
    Big mike 1968 and loudbang like this.
  30. JRN1967
    JRN1967
    from Monson MA
    dono50 said he would guarantee the 8ba would run and not over heat. He did not disappoint!
    This was taken after it had run for about twenty minutes, I let go for over thirty and it never went above 180.
    Outback, Big mike 1968, brEad and 4 others like this.
