the things you find ........
Discussion in 'The Hokey Ass Message Board' started by CraigKrage, Sep 19, 2009.
  1. CraigKrage
    CraigKrage
    from central IL
    So we pulled the 350 out of the 49 truck today. Wasnt too bad of a task. The trucks low stance caused a little bit of back and forth with jacks but we got it popped out.
    I removed the exhaust manifolds to help with the extraction when we noticed a bright color coming from inside the head.
    I think she'd been runnin a lil lean. :eek: :D
  2. joemarsicano
    joemarsicano
    from Palmyra PA
  3. CraigKrage
    CraigKrage
    from central IL
    I forgot to mention why I pulled the motor.
    The rest of the bump stick is still inside. :D
  4. Rich Rogers
    Rich Rogers
    Ouch, no wonder it broke. E-Gads it's one of those Frams:rolleyes::D
  5. g-lover51
    g-lover51
    from Dallas Ga
  6. chopo
    chopo
    x2!
  7. Jay Tyrrell
    Jay Tyrrell
    That cam looks like it can be reused! lolololol I love that valve!
  8. CraigKrage
    CraigKrage
    from central IL
    It was the whole driverside bank. LoL :eek::D
  9. cool57
    cool57
    Valves are clean:D Is that the motorcycle mad man I met at Showmes?
  10. CraigKrage
    CraigKrage
    from central IL
    that's Gay Ray (he's not Gay it just ryhmes)
  11. roughidle
    roughidle
    from iowa
    Just weld it back together!
  12. zzford
    zzford
    Don't weld it !!! The heat will warp it and then it won't be any good !
  13. dabirdguy
    dabirdguy
    JB Weld uses no heat.
  14. MarkzRodz
    MarkzRodz
    I think it's fit the S-10 2.5 now.
  15. halfcockedcustoms
    halfcockedcustoms
    really? :D
  16. FlynBrian
    FlynBrian
    It would make a good back scratcher!
  17. czuch
    czuch
    from vail az
  18. CGkidd
    CGkidd
  19. BigDanF4i
    BigDanF4i
  20. CraigKrage
    CraigKrage
    from central IL
    More like a 1/4 cam :D you guys are cracking me up.
  21. 55sd
    55sd
    That's friggin' hiliarious!!!!!
  22. CGkidd
    CGkidd
    Naw 3/4 is right. 3/4 stayed in the block.
  23. B.A.KING
    B.A.KING
    just drill it, tap it 3/8-16 stud, screw it back togethe,r--- wa-lah.pretty simple the way i see it:rolleyes:
  24. lippy
    lippy
    from Ks
    Adjustable lobe centers!! Ingenious!! :D
  25. rusty76
    rusty76
    from Midway NC
    Stick a pin in it and go....
  26. Dr.Kerry
    Dr.Kerry
    I had a cam break on me in a small block chev once. It broke into 4 pieces and the two loose chunks fell into the crank in rods. Needless to say it wasn't a rebuilder anymore. It chucked a rod through the block into the starter and broke the starter off the block.
    I was cruising at 55 and hit a water puddle at the time it blew. Never figured out why it happened, it just did.....
  27. lippy
    lippy
    from Ks
    Hard water?:p
  28. silversink
    silversink
    water pressure does amazing things:rolleyes:
