Projects The Tindall Coupe Build
Discussion in 'The Hokey Ass Message Board' started by Tindall, Apr 6, 2008.
  1. Tindall
    Tindall
    Here are the two previous threads following the coupes progress.
    http://www.jalopyjournal.com/forum/showthread.php?t=228673
    http://www.jalopyjournal.com/forum/showthread.php?t=237870
    Decided to tackle the rear subrails today. I needed new sub rails because i used a 32 ch***is.
    First i started with 1x2 box tubing around 36'' long
    I made cuts spaced 1" apart.
    The more cuts you make, the smaller the gap of each= easier to weld
    clamped it in place [​IMG]
    Then made cuts 1/2 inch apart on the opposite side
    finished product(except for welding)
  2. ol'skool29
    ol'skool29
    great job, i'm really digging this build so far, looking forward to the next update!
  3. Roothawg
    Roothawg
    I like the rear crossmember setup. Who's is that? Any more pics of the ladder bar setup?
  4. Tindall
    Tindall
    coil over? it is a so-cal ch***is with a transverse spring
    i think you are looking at the shock mounts...
  5. Roothawg
    Roothawg
    Yeah I saw that in another picture.....you must have been reading it when I typed it.
    So everything came from So-Cal,huh?
  6. Tindall
    Tindall
    yea its my first project so i didnt want to get in too deep. But now i see next time i can do alot of the stuff myself.
  7. Joe Daddy
    Joe Daddy
    So that piece there is that gonna go welded to the body? And im ***umeing you'll need to make a nother piece for the other side.
  8. Tindall
    Tindall
    yes that is the new "subrail" that is part of the body.
  9. oldandkrusty
    oldandkrusty
    You made all those cuts with a freaking hacksaw!?!?!? Holy ****, you sure don't need to go to any "fitness" gym, do you? Great idea, but I think I'd find a friend with a band saw if I were to attempt that project. However, I love necessity being the mother of all invention.
  10. Tindall
    Tindall
    hahah my arm was very tired after all of those cuts, i really want to find a band saw!!
    Got the motor back from being pressure tested and it checked out. I threw it on some 2x4 to get a rough idea of height, i think this is where it will end up. Now i have to cut the firewall to make it fit.
  11. Nice W motor!
  12. stretch 1320
    stretch 1320
    Lookin damn good from here!
  13. MR. FORD
    MR. FORD
    from Austin, TX
    Looking good man. I did the same thing to build my subrails. Learned it from Rolf!
  14. dsiddons
    dsiddons
    from Indiana
    Nice work. Love the vintage big block...
  15. sdfs10
    sdfs10
    Lookin good!!!:D
  16. lookin good man! nice kicks!!
  17. Tindall
    Tindall
    got my spring today and started mounting my front suspension:
  18. ST. 515
    ST. 515
    from TEXAS
    Looks great! Keep posting pics, looking forward to more updates.
  19. captainjunk#2
    captainjunk#2
    awesome i like the 409 engine very cool
  20. Tindall
    Tindall
    I cut the firewall and pushed the engine back a little. It might end up further back once i get my water pump.
  21. Leebo!
    Leebo!
    from Yale OK
    That looks like sme clean work!! Are you going to secure the subrails to the frame while welding them? I might be worried about the distortion to those of you didnt. I made a subfloor the same way by cutting small sq tubing on my pickup, and after welding it loose, i noticed somewhat of a chnage in shape when i was done.
    Would be a ***** to re-do yours if so. Just some food for thought!
  22. Tindall
    Tindall
    yea when i welded them, they moved a bit, but i straightened them out after
  23. Man, I love that engine you are using
  24. Tindall
    Tindall
    Got a little bit done today, i got some 600 16's bolted on the front. It is almost a roller, i still need steering, but it is a big step forward. I also got the motor where it is going to be, so i can make up some mounts over the memorial day weekend. Dont worry, the red wheels are not staying. They will eventually get solid steel wheels like the back.
  25. fatcaddi
    fatcaddi
    thats awesome dude, can i have it? haha
  26. el Scotto
    el Scotto
    from Tracy, CA
    That's a helluva car for a 16 year old!! When I was 16 I was working at a donut shop so I could afford any car....
  27. Topless Ford
    Topless Ford
    Super cool build......every build update from this day forward should include toes in the shot....proof and a hamb tradition!!!!:D
  28. Cshabang
    Cshabang
    *****in build...
  29. InjectorTim
    InjectorTim
    Thats gonna be a *****in hot rod.
  30. Tindall
    Tindall
