Projects The Tindall Coupe Build
Discussion in 'The Hokey Ass Message Board' started by Tindall, Apr 6, 2008.
  1. ST. 515
    ST. 515
    from TEXAS
    Keep up the great work!!! I like everything I've seen on this build.
    Saint
  2. Tindall
    Tindall
    I had a few options for clutch linkage on my hot rod. I like the simplicity of mechanical linkage, and it was pretty cheap.
    I started out with a DOM tube with a 7/8 id and a wall of 1/8. Then i made two Arms out of 1/4 flat stock. I used 2 GM Clutch Pivot balls for each end.
    One pivot will bolt through a 3/8 plate, attached to the boxed frame.
    On the other end, i pick up off of three bolt on the blow proof bell housing. [​IMG]
    This is what it looks like outside of the frame.
    And Inside
    I used a corvette clutch fork, and a clevis for the fork side. The threaded rod to the clutch for is only for mockup, it will get a real rod later
    And on the pedal side, i used two Heim Joints. This is only a mock up for now, for the real deal, it will get a 7/16 tube and larger heim joints.
  3. Do you think it's a good idea to mount it to both the frame and engine? There will be some movement of the motor/trans in relation to the frame.
  4. Tindall
    Tindall
    There will be some movement, but all gm cars in the late 60's were set up the same. The motor mounts shouldn't be moving that much
  5. Looks good then.
  6. wandi harry
    wandi harry
    Fairlly new to the HAMB and have just found your thread .Bloody fantastic !
    Ive got an A coupe which is what you would call floppy(no floor rails) and l have been trying to get my head around ways to fix it . great pics,must now check out the rest of your thread
  7. Tindall
    Tindall
    i rolled the car out today to finish up some welding on the firewall
    i made the final piece of the firewall and welded it in
  8. Tindall
    Tindall
    nope, that 409 is a pretty long engine, it a 4'' step back.
  9. B-Ray
    B-Ray
  10. Donnj
    Donnj
    from North NJ
    any updates......? looks great mike
  11. Cool rod old time look, glad to see young guy like you doing your on fab. Keep us all posted on progress. Hank
  12. gmchevolds
    gmchevolds
    cool build. i dig the 409 and especially the pipes!
  13. Cross Rodder
    Cross Rodder
    Nice build - love the 409!
  14. patman
    patman
    Bump...
    Any updates?
  15. ratster
    ratster
    good build kid
  16. breeder
    breeder
    very cool! just now found this!!!! makes me wanna work on mine!!!!!
  17. KreaturesCCaustin
    KreaturesCCaustin
    from Austin, TX
    Looks damned good! I've seen guys who claim 30 years of experience that can't match what you've done. Oh, as a side note, I don't know if it will be an issue with your set up, but a buddy had his firewall recessed like that for his A and built in an access panel on the top, under the dash so he could get to his distributor without pulling the whole motor. Just a thought. Keep up the great work!
  18. Paul Y
    Paul Y
    The Clutch Linkage will work fine. The factory set up for the tri five chevies is pretty much the same with the ball on the chassis and engine block.
    Mine works fine with a BB and a 5 speed after nearly 30 years. One thing you might consider. On my set up I put a flat spring at each end of the tube pushing against where the ball mounts.
    I found without this the tube would 'walk' towards one end and cause an annoying feel through the pedal when depressed, the springs keep it centralised.
    Might also want to fit a Zerk so that you can fill it with grease.
    Really nice build and makes me feel like a complete amatuer at the age of 45, your parents should be very proud.
    P.
  19. Very nice build, great work, well thought out - great to see someone at such a young age do such nice, nice work.
    Keep the pics coming!
  20. Candy-Man
    Candy-Man
    Love those 409's... I have been having a blast with mine for last 9 years..... Very nice build !
  21. Itchijohnson
    Itchijohnson
    from Colorado
    Very nice work.. I have a 31 5 window sitting on jack stands waiting for me to get off my ass and get to work. Love the W motor. What transmission are you putting behind the 409? Keep the picks coming in.
  22. Tindall
    Tindall
    I have a beefed up t5 to go behind
    Update:
    I havent worked on this car for a while, i just got my license, and have been working to get my 68' chevelle on the road, it is now so i can focus back on the hot rod.
    I got the car back in the shop and tore into the back end, i ripped out the rear sub rail and started putting it back together. More updates soon.
  23. Tindall
    Tindall
    here is the new panels fitted up
  24. SlowandLow63
    SlowandLow63
    from Central NJ
    Lookin good! Let's see, BFH, paint sticks, couple of clamps...I;d say you got the right tools for the job!
  25. Pinewood
    Pinewood
    Who did you get your rear subrail from? Were you happy with the quality or did you have to rework allot of it? I need one for my coupe.
  26. Tindall
    Tindall
    the rear subrail is from brookville, along with the other new pieces. I was very surprised it all fit great... something that can not be said for many reproduction parts, but if you were replacing the rail, into your original subframe- i cannnot say it will fit as good being as there are more vairibles
  27. Hot Rod Bob
    Hot Rod Bob
    from T-ville Ky
    Lookin good Matt, keep us posted an keep the pic's comin!!!
  28. cafekid
    cafekid
    looking good man
  29. Tindall
    Tindall
    i got a little update...
    i finish welded the firewall and threw some paint on it.
    Then i finished up the rear sub rails. im still waiting on a gastank so i can continue laying out the supports once i get that.
    My dad also primed up some of the rear suspension...
  30. VanHorton
    VanHorton
    Its looking great dude, definatly getting there!
