Projects The Tindall Coupe Build
Discussion in 'The Hokey Ass Message Board' started by Tindall, Apr 6, 2008.
  1. qzjrd5
    qzjrd5
    from Troy, MI
    Looks great man!!
    Mike
  2. 41 Dave
    41 Dave
    Matt, I am also building a Model "A". I'm not a fabricator, but I sure can appreciate the work you are geyying done on your "A". Keep at it you are going to have one mean Hot Rod !
    41 Dave
  3. Tindall
    Tindall
    i got a few updates:
    I ordered a tank from tanks inc. and got it mounted up.
    I also got a seat from a 1997 dodge minivan mocked up
    i ordered a 28'' column from lime works along with a 15" wheel. I made my own column drop...
    I started with 1/8 x 1" flat stock and bent it in the shape i wanted. Then cut a flat piece to fill the top.
    here is the clamping part...
    It will be jam nutted on both sides...
  4. chaddilac
    chaddilac
    Wow... looks great!
  5. SlowandLow63
    SlowandLow63
    from Central NJ
    Dude, so far 100% cool. But please do something with that seat. Tell me you have plans to make it not look soccer mommish.
  6. Tindall
    Tindall
    oh yea its gonna get a black cover similar to this... i might lose the headrests too im not sure yet...
  7. ol'skool29
    ol'skool29
    coming along great, i'd opt for no headrests. that seat cover looks great, and would look perfect in the coupe. thanks for the inspiration this build has given me!
  8. SlowandLow63
    SlowandLow63
    from Central NJ
    Lose the headrests... :D
  9. poorboy
    poorboy
    a vote for no headrests here too! your coupe is looking great by the way!
  10. ThirdGen
    ThirdGen
    from Wales, ME
    thats looking awesome! nice build. and thats a great looking column support! nice work
  11. Tindall
    Tindall
    we made some patches for the wheel well. We put the bead in in with a hydraulic press and some water pipe. They came out pretty good for the first time.
    i also got a drive shaft made and fabed up some brackets to mount a drive shaft loop...
  12. rob lee
    rob lee
    from omaha,ne
    Did you have that seat cover made or an aftermarket? Just thinking ,using the same seat .
  13. Tindall
    Tindall
    that is a picture i stole from www.cl***icroad.com
  14. -Brent-
    -Brent-
    Tindall, that rear lower panel below the deck lid, that's a Brookville piece? I just bought one from Mac's and I'm hoping mine fits as well as that one.
  15. woody2
    woody2
    Awesome job there young man. You proportions are spot on. I love everything about this car. It just looks perfect, Keep up the fantastic work.
  16. Chopped50Ford
    Chopped50Ford
    Alliance Vendor
    Great work looking forward to seeing it finished!
  17. Mad~Max
    Mad~Max
    You want to move those arms to the frame. That tube doesn't have the strength for even a mild engine. You are going to pull it out and pole vault into space at Mach 3...
  18. Tindall
    Tindall
    yes it is from brookville...
  19. Sparkswillfly
    Sparkswillfly
    from Colorado
    Say what ?????:confused:
    Look's fail safe to me.
  20. RAZIN CAIN
    RAZIN CAIN
    Nice job i like everything that your doing,an this should show us all that if we can just stop an think that all of this can be done at home.Sometimes you don't have to have tons of equipment.Using the water pipe an a press,nice work!!
  21. Tindall
    Tindall
    i started to lay some floors more to come soon
    The tunnel is actually a model a engine pan...
  22. scootermcrad
    scootermcrad
    Looks great man! Keep going!!
  23. ol'skool29
    ol'skool29
    coming along great!
  24. I SMELL SMOKE
    I SMELL SMOKE
    its looking good matt!! did you make the tunnel?
  25. 57tony31
    57tony31
    from Woods
    Nice work their looking killer keep the posts coming.
  26. 32 Barn Car
    32 Barn Car
    from Oregon
    I must be lucky . Looks like I got the same setup in my 5W . 5000 miles with a built solid lifter 327 , somewhat hard driving and no pole vault into space yet ?.........Z.
  27. Hot Turkey
    Hot Turkey
  28. Tindall
    Tindall
    the tunnel is the original splash pan from a model a motor
  29. Tindall
    Tindall
    i finished the rear floors...
    finished off making the last piece of the tunnel...
    cut a hole for the master cylinder access....
  30. matt--8
    matt--8
