The Useless Tools Thread
Discussion in 'The Hokey Ass Message Board' started by Weasel, Jul 23, 2012.
  1. wbrw32
    wbrw32
    Most useless old tools can be cured with those little blue pills...LOL
  2. wbrw32
    wbrw32
    My Harbor Freight sand blaster works great...just be sure to use dry sand and have a good water trap in your air source
  3. Weasel,
    Yesturday Jdavid51 came by to pick up an engine. When I put the cylinder on my cherry picker I somhow managed to miss the hole in the cylinder and it let us know when we had that big ***ed 390 up about 5 feet from the concrete.
    Waslaaaaammmmm. Man did I feel like a usless tool at that very moment.
    Jdavid didn't get shook in the least, he just said it looked like he needed a different oil pan. Damned nice fella.
    If someone has an extra 390 pan laying around it would be a big plus if you sent it to him. ;) Probably a pickup as well.
  4. RagtopBuick66
    RagtopBuick66
    I checked out the link, and man were you right! I never dreamed... But what was even more interesting, did you look at the paint? There are some colors I don't think Krylon has even developed yet!
  5. You been readin' my mail !?!
  6. every oneman brake bleeder so far i worked with
  7. Dreddybear
    Dreddybear
    I've used some of it before on some bike frames, it's actually very high quality stuff..
  8. stainlesssteelrat
    stainlesssteelrat
    from ms
    i work irigation , and one day at harbor fright.. i saw what looked like my dream tool,
    it was a PVC cutter , lineman's plier,micro spray tube punch , phillips/flathead combo
    tool... and not ONE MOTHER ****ING THING ON IT WORKED AT ALL!!!!!!
  9. Mike51Merc
    Mike51Merc
    Cochran Speednut?
  10. RagtopBuick66
    RagtopBuick66
    And it's rather inexpensive to boot!
  11. RagtopBuick66
    RagtopBuick66
    I've got one of those, but I stopped trying to use it to bleed brakes after the first try. BUT, if you remove the little plastic trap cup on the bottom and zip tie a gallon Ziploc bag to it (or just an extension hose to a 5 gallon bucket), you can use it to remove excess/overfilled oil from a crankcase, drain a radiator, or basically pull fluid from just about anywhere you want before removing it for rebuild/replacement/etc. I use it to prime the filter for my 125 gal. aquarium after cleaning, too. Makes things much easier since it sits up on a ledge 12 feet above my foyer. So it hasn't been totally useless. Just for bleeding brakes.
  12. mustangsix
    mustangsix
    I spent good money years ago to buy the one and only special tool that removes front strut inserts from a 92 Pontiac Gran *****......worst.car.ever....
  13. ,, wrapping the socket and bit with a short strip of electrical tape works well too - not so permanent.
  14. dad-bud
    dad-bud
    1.Cheap exploding hacksaw blades - they last about two strokes and then take an eye out.
  15. dad-bud
    dad-bud
    2. Most anything made in China. The steel they use is either rubber or brick. Cheap normally equals ****.
  16. Conniptor
    Conniptor
    from New Jersey
    These are like Harbor Freight, but even better!
  17. Conniptor
    Conniptor
    from New Jersey
    I have some of these...
  18. AG F/C
    AG F/C
    **** man I have that exact one and love it! I do a lot of small wiring and can't afford to nick the copper. Super time saver.There might be better designs out there but still use them a bunch.
  19. evs1
    evs1
    I have used a pair of Klein 1010 strippers, actually several over the years and am very happy with them. I also use a Klein crimper, a true crimper, not the kind that just crushes the terminal, I have had since about 1984. This is in commercial use on a daily basis wiring cars and truck.
    They are tools that are not lent or borrowed unless someone is working with me on a project, and the first ones accounted for at the end of the day.
  20. MEDDLER1
    MEDDLER1
    Thanks for posting this link! I never knew this stuff existed like this! :eek:
  21. RagtopBuick66
    RagtopBuick66
    It'll be five years in October that I've been married. I just remembered another tool that is apparently useless... Or at least "without use", anyway. Unless I gotta pee. :(
  22. AlbuqF-1
    AlbuqF-1
    from NM
    On old bicycles (the kind made in USA) the left-handed nuts were those sizes, I guess to make you think before you started cranking on them the wrong way...
  23. fortynut
    fortynut
    Whoever it was that said 'Shrinking Hammers are useless' never used one to tenderize beef. They're the ***s for that! Just make sure you put your steak inside a zip lock bag and pretend you're sending a message to people you don't necessarily agree with. Bam! Thud! Whack! Works like a charm.
  24. seb fontana
    seb fontana
    from ct
    Times five and you will use it way more, at least pee wise...
  25. ClayMart
    ClayMart
    I've NEVER seen ANYONE ever use one of these "headlights"! :eek:
    Which is weird 'cuz they're just SO DAMN STYLISH too! :rolleyes:
  26. Bad Eye Bill
    Bad Eye Bill
    from NB Canada
    Yeah, I thought of 2 or 3. :D
  27. billsill45
    billsill45
    from SoCal
    Who is the manufacturer of this? I could use one or two.
  28. mickeyc
    mickeyc
    Hey! that 19/32 wrench fit the trans mounts on late 70's to mid 80's
    chevy pickups. The only time I ever encountered a bolt of this wrench size.
  29. Bad Eye Bill
    Bad Eye Bill
    from NB Canada
    That was 1 of the 2 or 3.
  30. evs1
    evs1
    How about a solar powered flashlight? I got one of those once from an aunt who I don't think liked me very much.
