The Ute...
Discussion in 'The Hokey Ass Message Board' started by Ryan, Mar 7, 2012.
  1. That black channelled 34 Ford Coupe is owned by Lynn Arrowsmith, he built it in the early 60's and it still runs the 318 Poly V8 that he installed when built, originally it was a turquoise blue, unchopped.....when painted black in the 1980's he chopped the top....but kept the bits taken out........and the original manufacturer of this Ford Coupe?.............the Ford Motor Co. of Australia, Geelong Victoria.
  2. roadkillontheweb
    roadkillontheweb
    The rib just below the rain gutter on the roof is still there. It is an extension of the body line from the top of the door and would have taken a lot more work than a backyard customizer would have done. On the UTE it fades into the roof behind the door.
    I suspect by PV (Panel van) side panels you mean the little vents on the side? These were used on the 46 Dodge panel shown below and would be needed on any panel to help vent the hot air.
    the rear quarters in all photos are 1954 Plymouth and the rear quarter work above the fender to the seam matches my UTE. I did not argue the fact it had Holden tail lights when it was black but the rear quarters are still Plymouth and the Holden light somewhat fit the same area when turned upside down.
    I am arguing that the work was done by a custom shop not someones back yard the question is, "was it done by the same shop that did the conversions on the UTEs?" All the Desoto, Dodge and Plymouth UTEs of this era started life as 4 door sedans and were converted by the factory either in house or in a outside custom shop. I suspect the same shop did the work to make this panel. My question is if it was a factory order or a customer order? I have a lot of factory to dealer correspondence from this era. and in none of the notices do they mention a panel but they often mention the UTE.
  3. roadkillontheweb
    roadkillontheweb
  4. PaulN
    PaulN
    i love the 33 34 roadster ute
  5. ehdubya
    ehdubya
    Roadkill, the rib you refer to looks like a rat's **** to me, particulary the left side in the second shot you posted ...but I was referring to the five ribs running across the top of the roof, the panel is humped between each suggesting they're covering joints and they've vanished when it's turned yellow. If you still think this is the work of a professional perhaps you'd be interested in investing in an Alice Springs beachfront timeshare apartment :D
  6. ehdubya
    ehdubya
    This poncho existed 5 years before it was invented, how did it happen? :D
  7. Dago 88
    Dago 88
    Sorry Andy, That coupe was built by Darrol Finger. This is Lyn arrosmith's coupe.
  8. Sorry not a coupe ute. More or less a C-cab. see the roadster doors? Roadster utes have been around since the mid 20s. The coupe ute which was an all weather vehicle and is credited with being designed by Lew Brandt.
  9. ehdubya
    ehdubya
    ...credited by who? [​IMG]
    sorry C-cabs don't have doors and you know roadsters don't have tin tops, more or less a coupe :D
  10. I said more or less a c-cab. Credited by who? I pulled the name Lew Brandt out of thin air to fool everyone to the fact that I in fact designed it even though I wasn't born for another 48 years. Look up the history of the Ute. historians credit Lew Brandt as the designer of the first Coupe Ute.
    Why the picture of a Sulphur Crest ****atoo? Did ya mean to post a pic of a Galah?
  11. roadkillontheweb
    roadkillontheweb
    The lines you are talking about are still there when yellow just harder to see.
    My contention is that the rib I am referring to would not have been continued along the roofline by a backyard shop and would have been left flat. The shop that converted the UTEs for the factory left the rear door opening structure in place and just welded/leaded in a piece of steel in the opening rather than reform this area behind the cab and can be seen if you remove the inner bed panels. How they would have extended the roof line without being able to use a stamping like the 46-48 Plymouth sedan stamping used to make the UTE rear cab roof is a good question. The UTE was not a high production model that would have allowed for special tooling to stamp out body panels and the panel van would have been even fewer, I would like to examine the panel in person, hell I would like to own it because I like the way it looks! But I don't see that happening.
    PS
    I know where Alice springs is located without looking at a map.
  12. ehdubya
    ehdubya
    Jimmy I'm familiar with the Lew Brandt Story as it's so widely parroted as gospel, hence the ****y but a Galah is apt ;). It's hard to imagine that it took at least 25 years for someone to put a closed cab on a station utility with the hundreds of coachbuilders about at the time and the government going to lengths to foster the local motor industry.
    If you search the papers you'll find many stories like the famed 'church on sunday, pigs on monday' Ford one and descriptions of p***enger car comfort and truck utility.
    Take a look at the body styles described in the 1933 Ford ad below and you'll see there's something wrong with the Lew Brandt Story timeline but these 31 Chevs should really rock your faith in 'historians' :D
    I seem to remember Lew couldn't find a 34 ute to restore and ended up building one from a coupe which is why the bed is shorter.
  13. ehdubya
    ehdubya
    Roadkill with almost 40 years in auto body I think you should count your blessings ;)
  14. Scumdog
    Scumdog
    Had a couple of 56 Mainline utes over the years, cool cars, one had a split-back drivers seat and a rear seat, could hold 5 people.
  15. Scumdog
    Scumdog
    Seen one like it Stateside, made from a cut down 'wagon.
  16. 48FordFanatic
    48FordFanatic
    from Maine
    Some are nice looking , others are ugly as sin!
  17. Nads
    Nads
    from Hypocrisy
    When did Australians go to Dollars? I see the Ford advertised in Pounds.
  18. Australia introduced decimal currency in 1966.
  19. 2021customs.com
    2021customs.com
    from Iona PA
    one from the 21st
  20. mgtstumpy
    mgtstumpy
  21. mgtstumpy
    mgtstumpy
  22. b-bob
    b-bob
    This little red Anglia came from Oz in a small box. After all the wood had been removed there wasn't much left. The body was just a flat stack of metal panels and the firewall, along with the windshield frame and the curved quarter panels that wrapped around the back of the body behind the seat.
    The rear fenders are widened Prefect sedans and the box was custom made. It was powered by a Older Datsun pickup 4-banger.
    exterminator likes this.
  23. raymay
    raymay
    That Anglia looks great. I am ***uming it was a roadster pickup style conversion built.
    Whoever did the work on this one, Nice job .
  24. X38
    X38
    To be pedantic b-bob, that's not actually a ute. The body and box need to be a single unit.
    Actually, I take that back, it's not being pedantic, it's just a fact.;)
  25. HOTFR8
    HOTFR8
    X38 is correct a true Utility has the back as part of the Cab after all the original name was a 'Coupe Utility' when Lou Bandt designed it. As an example the existing model and last of the Falcon Utes is more of a pickup as the bed back is not built as part of the cabin.
    That Anglia is a Pickup.
    This is an Anglia Ute.
  26. b-bob
    b-bob
    You would know a lot more about them than I do. My late friend and owner always called it a ute, this one originally had a wooden box.
  27. ambida
    ambida
    This is a censored site as my Utes were removed. Wow!
  28. JohnnyGretsch
    JohnnyGretsch
    My old man has at least one fullsize Ford ute for every year from '54-'59. He's decided he doesn't like the Aussie commercials and is currently in SD picking up his '56 Courier.
  29. ratrodbarney
    ratrodbarney
    P1010082.JPG I picked this up a year ago. It was built in Queensland , Australia 2000.
    exterminator, Cooon and Jimmy B like this.
