The weekend is over - What did you accomplish?
Discussion in 'The Hokey Ass Message Board' started by SanDiegoJoe, May 4, 2008.
  1. 1950ChevySuburban
    1950ChevySuburban
    from Tucson AZ
    I hung gutters on the house, and stripped/painted the entry doors. Went to a car show Sat. evening, basically a honey-do weekend.
    Oh, and I got the dash back in my '71 Chevy pickup.
  2. Got the 292 back into the Biscayne in under 2 hours flat, did a bunch of yard work, played with my older daughter, grilled some bitchin' brats and burgers.
  3. 30roadster
    30roadster
    About 3 months ago I brought home a huge 6 foot circular piece of scrap steel that is 1 inch thick. I thought it would make a great fab table. This weekend I welded on the legs, braces, and wheels. The tricky part was turning the table over. I used an I-beam hoist and my engine hoist. I had visions of the table coming loose and dancing around my shop killing me or rolling over all my cars. I welded on two short 2x3 square tubes on the top and bottom for something to hook to...apparently my welding is good.
    When i finally got the table over and down on the ground I realized I must have been fairly nervous doing it.... my mouth was dry as dirt! :D
  4. Todd Bugs
    Todd Bugs
    I got a sunburn, hangover and dirt in places I didn't know were accessable to dirt at el mirage, had a great time as well...
  5. The Hop Walla
    The Hop Walla
    from Dallas
    Got two layers of Peel and Seal down on my floorboards and inside the doors.
    That stuff is awesome. Really toned down the resonation inside the cab of my F100.
    Since that stuff is now down I was also able to install my new Moon gas pedal.
  6. slammed
    slammed
    Replaced the intake and valve cover gasket's, oil, filter, rad. flushed, on the sbc in the Impala. Man, I thought it was a dead palyer last Thursday. She run's like a champ again. Still aiming for Wayland on the 31st!
  7. sadayo
    sadayo
    ...so this is what you can do with your time when you don't work weekends... I've been wondering. :)
  8. EW_
    EW_
    from DFW
    I'm thinking that you might be joking about the brake tool but if you're not, this is what I use: http://www.sears.com/shc/s/p_10153_12605_00945494000P
  9. displaced_kiwi
    displaced_kiwi
    from Olathe KS
    Sorted out an e-brake in the '47. I used an under the dash pull out type brake handle from a 60-ish ford pickup and lokar cables on the 9". I tried connecting them to each other and couldnt pull the handbrake on, so I had to makeup a pivoting arm to get some leverage. I made an L bracket that I bolted to the bottom of the chassis and then mounted a foot brake pivot and arm (cut off the pedal) from a 70's chev to it (so it sits sideways under the floor, the pivot is beside the chassis. The lokar cable connects close to the pivot and the hand brake cable is hooked up to the very end). Seems to work ok on jack stands.
    Cant test drive it as I still have some carb issues to sort out :mad:
  10. 53sled
    53sled
    from KCMO
    I insulated, re-carpeted my interior and got a gas gauge that works.
    Rust Revival bound!
  11. Kustomkarma
    Kustomkarma
    Ran errands, stuccoed a door frame on the house, reinstalled the driver's side and removed all of the passenger's side front suspension on the Merc. Also ordered all of my disc brake conversion parts.
  12. NYCDrums
    NYCDrums
  13. oldpl8s
    oldpl8s
    Thanks for the info. I didn't know these existed.
  14. This was a long weekend for us northerners, and the final insult to me was that I had to replace the brushes on the motor of my wife's vacuum cleaner. I learned long ago ( married 40 years ), that if I want to eat, wear clean clothes, and sleep with both eyes closed, that I have to take care of those jobs immediately.
    Bob
  15. Parts48
    Parts48
    from Tucson, Az
    1. Hot Rod Veterans
    Insulated my WEST facing garage door...103 today..waiting for those 115 days ahead. Looked at portable AC units.. Sure would make my life easier..
  16. Kirk Hanning
    Kirk Hanning
    Need I say more?
  17. Aman
    Aman
    from Texas
    Cool Kirk! I tried my hand at some body work on the A. Fenders, aprons...hammer and dolly, welding, grinding, sanding...and a little filler. My hands are talking to me today and I have a whole new respect for body guys. I'm glad I don't do it for a living or I'd starve to death. It's time to split work so I'm going to the house for more torture, I mean work.:D;)
  18. RatBone
    RatBone
    damn good idea! I hauled home a huge metal lid of something about an inch thick and 3 foot diameter. Now I know what to do with it!
