the What did you get done this weekend? thread
Discussion in 'The Hokey Ass Message Board' started by Paul, Sep 16, 2007.
  1. Paul
    Paul
    Editor
    I continued bolting together the 303
    all nice and new inside :D
    don't have a deffinate plan for it yet,
    still might go in the T to replace the Stude motor, even though the little Stude is running like a Champ
    ...or maybe it'll be part of a whole new build,
    like an early fifties style car built using this body I picked up earlier this week.. :D
  2. FoMoCoPower
    FoMoCoPower
    I got a Y-Block together and running this weekend.
  3. gahi
    gahi
    from Moab, UT
    Worked on the BSA
  4. 31aBoy
    31aBoy
    Managed to successfully remove all 6 pins on my Model A door hinges. Only messed up one hinge that will need to be replaced.
    (anyone got a lower p***enger side door hinge they wanna get rid of?)
  5. Started KNOCKING the filler off my T roadster body. An inch thick in some places! Cut away the bun panels (which were welded to the rear quarters) so I can patch them tonight. Need to make a whole new subframe though.
  6. wyoming
    wyoming
    from My house
    got the 450hp 396 ready to fire in my buddys c10
  7. swade41
    swade41
    from Buffalo,NY
    I stared at my springless T and pretty much finished up the stop light for the back. I did go to the local races today though, which was cooler than staring at the rear of my car waiting on the spring.
    a short video of the races http://www.youtube.com/watch?v=WYK7Mq_uI08
    and a shot of my car
  8. panhead_pete
    panhead_pete
    Started working on the rolling ch***is for the coupe body and little hemi I bought off Hyfire. Drank a 6 pack of turkey cans, dreamed a lot about how it will look. Woke up with a hangover. :)
  9. Revhead
    Revhead
    from Dallas, TX
    Pulled the manifold on my friends 440 in his '55 f-100 to fix leaks. Did alot of other little things to it.
    Ran new tail and stop light wires in my panel truck and got the lights all up to par...
    Next week I get my motor for it... should be fun
  10. 49ratfink
    49ratfink
    ooooooh.. 303 ... saw some HOLMES finned valve covers for one of those last weekend. $200.00.
    this weekend was BILLETPROOF.. so that was saturday. today I took parts off a 51 chevy for ebay. haven't worked on my own car in 6 months
    oh yeah.. stayed up late editing 115 BILLETPROOF pics so I could post them here so you guys can see what you missed,,,
  11. Tony
    Tony
    Got the mill in the 52 Chevy truck i picked up a few week's back all together and running again..New World product's heads, new solid cam, new intake and carb..etc..
    Finished up at 9 tonight breaking in the cam and setting the timing. Sounds REAL STRONG..
    Tomorrow i take it for a ride and see how strong it is..:D:D
    Tony
  12. Toast
    Toast
    from Jenks, OK
    I built some more of my fence, mowed my gr***, looked at my P/U once! I sent my 63 T-Bird th the paint shop! Does that count?
  13. BigDanF4i
    BigDanF4i
    drove 6 hours into new york to pick up a 29 chevy coupe I bought on ebay from lockwoodcustoms. while I was there picked up a 37 chevy pickup cab too. great guy. lots of time in the van, found out the governor on it is set at 82 mph
  14. My brother in law brought the sister's minivan over for a front brake job. I couldn't get the two damned little screws Honda uses to hold the rotors on during ***embly off. Some yutz mangled them during the last brake job and I didn't have the tools to get them out and the bro-in-law didn't have the time to mess around with it so he went to some chain auto repair place to get it done today.
    After that fiasco I started to doodle out some plans for a one man streamliner. It has to be narrow enough to get the body out of the ba*****t door since that's where I'll be trying to ***emble the bulk of the thing. The garage is small and packed full of Packard so the ba*****t is my new laboratory!
  15. 1/2done
    1/2done
    from Ohio
    The front end sheet metal on my 41 tilts now and I caught a cold that is kicking my ***.
  16. skyrodder
    skyrodder
    started to pull out my 235 to make room for a 350, and also took out the rivited lexan to install it with rubber instead..
  17. Kerry
    Kerry
    Put new u-joints in a different driveshaft I had made when I built the hot rod. Dropped it off to get it balanced. Pulled my 28 splined axles and the third member out of the coupe. Got the old bearings off of the 31 splined axles, cleaned the axles up and put new bearings on. Still waiting on my Ebay 31 spline traction lock.
  18. spudz
    spudz
    went to the auto fair
  19. skajaquada
    skajaquada
    from SLC Utard
    stripped my 455 down to this, honed the cylinders and washed the block. now i just need to wait for my rockers, timing set and head gaskets to get here and it's ***embly time!! :D
  20. HotRodRick49
    HotRodRick49
  21. sko_ford
    sko_ford
    i refined my resumae and am working on a cover letter to become a parts store manager
  22. mr_autotude
    mr_autotude
    went to Billetproof this weekend and showed the 50 buick for the first time, you"ll see the pics steel phoenix posted
  23. got my 49 fleetline stored so, and have started saving up money to finally start the project next summer, still undecided if i want to slam it and make it an ***dragger, jack it up and make it a g***er, or go somewhere in between and make a street/strip rod. :eek:
  24. Stroked
    Stroked
    from DFW, TX
    We moved not too long ago and I just recently sold another car so that I would have the funds to finish my coupe.
    So, this weekend I cleaned the garage, hung some fluorescent lights, pulled the body off the ch***is and started buying a lot of parts.
    I also started my "TIG welder fund" which should be full around Christmas time. :cool:
    - Matt
  25. ckdesigns
    ckdesigns
    from Ogden,Utah
    Added onto the deck............on my half pipe.
  26. Frank
    Frank
    28 rpu. 302/4spd/9".
    Finished my custom clutch linkage. Ford's pull the clutch fork forward while Chevy pushes. I just used part of a stock Mustang cable, mounted an A/C idler puller on a bracket mounted to the frame ahead of the fork so now when I push the pedal, it pulls the cable, which rides the pulley back around and pulls the fork forward.
    I am planning to mount my MC under the seat so that I can have my access window out of sight. This means my MC is actually mounted about 28 inches away from the pedal. I made a push rod out of 3/8" steel rod and made a threaded adjustment near the MC end to fine tune it. I am in the middle of making the MC mounting bracket. I will add safety hoops and stops to the pedal to make sure there is no way the push rod could come out of the MC or fall out of the car.
    Made some custom pedals. Two horseshoes. One for brake and one for clutch. Turned up of course so my luck don't run out. :)
    For the gas, I found this casting of a nifty star on a round disk that was intended for a drawer pull. Its 3" in diameter and made for an awesome looking go pedal.
    Once I get all this pedal stuff done, I can put in the floor boards and seats and figure out my steering column drop.
    The truck is beginning to take on a "texana" kind of theme. Its rusty with old barn wood plank floors. I am thinking of doing a cowhide seat (no fur). I might incorporate some leather, br***, and nickel trim in the cab. Stars for dash knobs if I have any. Thinking of tin door and kick panels with some sort of embossing of maybe longhorns, stars, or something along those lines.
    Or I might just change my mind all over again.
  27. GRAPRO
    GRAPRO
    Worked on a pulley setup and manifold for my 4-71[​IMG]
  28. Spent the two days trying to finish up the seven inch top chop on an advance design truck cab. Started sawing off the top last week end. I used two donor cabs, for the extra metal to close the seams and to put a full piece of metal in the center area. Not an easy task. The H.A.M.B. tech articles sure helped alot! Thanks to all that contributed to the various tech information that I have read. No flaws of design doing the chop, due to good information learned from the H.A.M.B..
  29. I spent the last two days trying to finish up the 100amp service updgrade to the garage. Well tonight I have power back in the garage to the new sub panel. I am totally excited about it too.
    CBB
  30. FiddyFour
    FiddyFour
    am i missing something here? or is there something missing on this engine?
    got any other pics?
