The width of a 46 Ford coupe for 9 inch rear
Discussion in 'The Hokey Ass Message Board' started by Waterboychuck, Dec 15, 2012.
  1. Waterboychuck
    Waterboychuck
    I bought a 46 Ford coupe and I want to install a 9 inch Ford rear end. What I'm looking for is what width rear end do I put in. The rear end that's in the car is out of a Falcon, which is too narrow.
    Any suggestions?
    Thanks
  2. John Lafayette
    John Lafayette
    My '48 ford had a rear out of a '59 Ford wagon. The car is gone so I don't know the specs. , but it was a perfect fit.
  3. Jimv
    Jimv
  4. zibo
    zibo
    from dago ca
    I just put an 8" in a 40 coupe,
    and a 9" in another 40 coupe.
    Both were from 68 mustangs.
    They fit perfect with junkyard rims.
    The '46 is a bit wider but should be a good fit.
    TP
  5. okiedokie
    okiedokie
    from Ok
    72 Mustang in my 46, believe it is 60".
  6. thatredcaroutside
    thatredcaroutside
    from Decatur,AL
  7. Early bronco is the right width and still has the 5 on 5.5 bolt pattern.
  8. I used a Granada rear, 8", it's 58-59 inches wide. Running a 7" wide rim, everything clears great.
  9. Waterboychuck
    Waterboychuck
    Thanks for all links to the charts. That will help a great deal.
  10. scrap metal 48
    scrap metal 48
    I'm a firm believer of placing the tires and wheels you're going to use in the wheel wells exactly where you want them and then sticking a tape measure through one side to the other and make the rear exactly the width you need, or at least you will have an idea what rear end you need...
  11. flatout51
    flatout51
    Use a 1957-1964 f100 rear. It is exact same width as stock and has 5 on 5.5... 61" if i remember... I just.put one in my 46 coupe.
  12. X2.
    By picking a rearend before choosing wheels & tires, you're unnecessarily constraining your wheel & tire options.
  13. Pewsplace
    Pewsplace
    I use a 59 1/2" with a 8" wheel and 255x70 bfg.
  14. flatout51
    flatout51
    If you are using stock wheels and tires the truck is perfect... Those wide wheels just look dumb on fat fendered Fords... Run 16x4s with 6.00 16s.... Just my opinion.....
  15. fordor41
    fordor41
    '70 Ford Torino 9" under my '41 Ford. Same as a '46-48. 235/75R15's on rims with 3.5" offset. Tires clear fender lip by about 1".
  16. sdroadster
    sdroadster
    I just went to the local Pick A Part and found a 1967 Ford F150 rear end. It is a 9" that measures 61.25 inches drum to drum. A stock 42-48 rear end measures 62.5 so the new 9" is 1.75 narrower. The brakes on older rear ends are narrow and look inefficiant. I pulled the backing plates, brakes, and and drums off a 71 Econoline van and switched them out in the junk yard. The new drums and brakes are much wider with self adjusting brakes. Found two differentials a 2.75 and a 3.25. I'll put the 2.75 in when we go to Bonneville next year.
  17. millersgarage
    millersgarage
    I've got an early Bronco rear in my'47
  18. Chopped 46 Ford
    Chopped 46 Ford
    I've got an 8.8 rear out of a 95 mustang. Fits great! Had custom rims built for it, to fill the fender well just right.
  19. Gman0046
    Gman0046
    Use a 10 bolt Chevy rear and a Chassis Engineering spring kit. Fits perfectly and is the easiest way to go.
  20. BigChief
    BigChief
    Got a '68 Mustang/Cougar 8" in my '48 Tudor Sedan. Fits like it belongs there.
