The "Work" C10 that became a Shutdown Project
Discussion in 'Off Topic Hot Rods & Customs' started by Taboo56Chevy, May 6, 2024.
  1. Toms Dogs
    Toms Dogs
    from NJ
  2. Taboo56Chevy
    Taboo56Chevy
    Then it was time to wrap up the truck. Got the bed side trim on, got the bumper on and just wrapped up version 1 of the new truck.
    117201654_4903004199713295_3191812889994959356_n.jpg 117308975_4903004179713297_6186090758584088692_n.jpg 118016105_4972126032801111_7313982397392595629_n.jpg 118282636_5008171482529899_8525655457853130182_n.jpg 118320037_5008171252529922_8785456901601404032_n.jpg
  3. Taboo56Chevy
    Taboo56Chevy
    Now the truck was pretty much done so did a reshoot in the same spot for before and after the redo. Alot of buddies dont think its same the truck seeing the before and after.
    118308471_5008337512513296_5270754642964848938_n.jpg 118326285_5008337699179944_833850756351637915_n.jpg 118348265_5008337829179931_1737615661765420141_n.jpg 118458781_5008337815846599_8952480040838789964_n.jpg 118587465_5008337655846615_4414095912835345776_n.jpg 118651339_5008337409179973_8096403892758757099_n.jpg
  4. Taboo56Chevy
    Taboo56Chevy
    Well the first change since the redo came quick. Swapped the white letters out for Redlines with new trim rings & original center caps and then did a little photoshoot with my 68 Camaro. Ive had the Camaro since I was 8 and it was the first car I really wrenched and learned skills on with my grandfather. Pretty much made the truck a nice tow rig to match the Camaro since they were both 68's.
    120141725_5152108664802846_3589511107474491_n.jpg 120424605_5189625547717824_2895156006729320479_n.jpg 120745084_5189625711051141_1849374744638918156_n.jpg DSC_1208_edited.jpg
  5. Taboo56Chevy
    Taboo56Chevy
    Drove the truck for a little bit and figured out the next wave of updates. Mainly swapping the rear end for better highway gears and then adding power disc brakes and to lower it a little more. So in went a dropped spindle and discs (kept it 6 lug) and then put together an original power brake booster and master cylinder setup to keep the original look. I found a fresh rebuilt rear end cheap near me so just swapped those out. During that time I had also had the tailgate letters done in white by a local graphics shop.
    157823080_5883851164961922_4815632193392786885_n.jpg 158386875_5891345820879123_9055613831393086128_n.jpg 158560918_5883851278295244_2676145050589190398_n.jpg 158681491_5883851144961924_3827506369745042615_n.jpg 163346813_5943917422288629_4191634984665078022_n.jpg 163565052_5948164438530594_4308866776353203886_n.jpg 163642250_5948164211863950_2629942194066806479_n.jpg 163642926_5948164108530627_644848309475289851_n.jpg 164337247_5948164308530607_963094117048144164_n.jpg
  6. Taboo56Chevy
    Taboo56Chevy
    Finished results of the new brakes and lowering.
    168961818_6006636006016770_7858955050122941663_n.jpg 175359243_6090120984334938_6818767537278568227_n.jpg 175386948_6090121414334895_8689198385347651348_n.jpg 175628052_6090121161001587_1646644818460078822_n.jpg
    bchctybob, 51pontiac, swade41 and 3 others like this.
  7. Taboo56Chevy
    Taboo56Chevy
    Drove the truck like this for about a year, but then it was time to do more again. Swapped the metal door panels for the deluxe padded ones for a 68 as I found my truck was supposed to have them originally with its trim level. Also decided to yank out the cluster and add a factory tach to it and a clock to fill all the blank holes in the cluster.
    279011421_8076884508991899_5763010380059958688_n.jpg 278632525_8076885652325118_5934163299772818911_n.jpg 280347420_8178983345448681_865895077153500249_n.jpg 280784334_8178983348782014_7008890794907984580_n.jpg 280177954_8178983352115347_2423298292264010459_n.jpg
  8. SS327
    SS327
    Marina blue poly, my favorite color!
    bchctybob likes this.
  9. Taboo56Chevy
    Taboo56Chevy
    Drove the truck like that until last summer. I got the idea I wanted factory bucket seats in the truck so spent the swap meet season tracking down all the pieces. Found that original 69-72 buckets and consoles are way overpriced, but found that early truck high back buckets were just low back frames with a simple hoop stuck on. Those seats are cheap so made my own low backs, seat brackets and had to take 2 consoles to make 1 good one. Ordered foam and covers from a shop and then my grandpa and I did out best pulling the covers on ourselves. The swap came out pretty nice.
    277786162_8015740321772985_8958744452420428914_n.jpg 277577497_8015740348439649_235123652300356461_n.jpg 277672205_8015740501772967_3021461985494756651_n.jpg 314748049_9032308316782842_2808399163715062463_n.jpg 326972819_742549080373408_3120978280337399620_n.jpg
    bchctybob, swade41, Squablow and 2 others like this.
  10. Taboo56Chevy
    Taboo56Chevy
  11. Taboo56Chevy
    Taboo56Chevy
  12. Taboo56Chevy
    Taboo56Chevy
  13. Taboo56Chevy
    Taboo56Chevy
    Then after a few months with the buckets I had gotten tired of the low hp 350 by now so it was time to build a new motor. A buddy down the street had a 68 327 he was yanking out of his car for a LS swap and offered it to me at a price I couldnt p***. Motor had a flat cam and a loose rocker, but he failed to notice that the heads were 69 186 Z/28 2.o2's. These heads were off a hot motor at some point as they have been ported and polished like crazy, had stainless valves already installed and then screw in studs and guide plates. Block was 40 over and look like new so I think the cam went flat during break in or right after. I had the block hot tanked then we just did a rebuild at home. Stuck a L79 cam shaft in I had on the shelf then took the intake off the 350 once it was pulled and stuck it on the 327. While pulling the motor, I decided to give the muncie back to my grandpa and I bought a Tremec TKX 5 speed to stick in as this truck has become my long distance rig. Swap was pretty simple, few little things I didnt prepare for, but the shifter only moved like a 1/4" more towards the center line of the truck so just had to trim my hole slightly but the boot still worked fine.
    IMG_2780.jpg 387084608_24763464576573963_7358919115162554307_n.jpg 387090782_24763464449907309_1070397796239557862_n.jpg 387136456_24763469006573520_9039177346162359921_n.jpg 387179698_24763466449907109_7642004658898988190_n.jpg 387180907_24763467049907049_6176884056392733547_n.jpg 387860784_24763466059907148_8896083255004980624_n.jpg 387867217_24763466416573779_3905780324968484273_n.jpg 391556267_24763468433240244_3956441477849112600_n.jpg 391563622_24763467749906979_5491078373141811805_n.jpg 391563995_24763467226573698_6558115820213241752_n.jpg 391565945_24763467413240346_667983471539661015_n.jpg 391718682_24763466566573764_873479787279586180_n.jpg 391750422_24763465933240494_8525739635203575262_n.jpg
    bchctybob, porkshop and swade41 like this.
  14. Taboo56Chevy
    Taboo56Chevy
  15. Taboo56Chevy
    Taboo56Chevy
    That brings us up to date of where the truck currently sits. The new 327 and 5 speed went in this winter and now just getting some miles on the setup and getting it broke in for the summer fun. Here are a few videos that have been made of the truck over the redo.
  16. Taboo56Chevy
    Taboo56Chevy
  17. Taboo56Chevy
    Taboo56Chevy
  18. Taboo56Chevy
    Taboo56Chevy
  19. Dan Hay
    Dan Hay
    Wow, it's perfect. That's exactly how I would have built it down to the last detail. The colors, redlines, ralleys, the drop, the sound. Perfection!
    bchctybob and klleetrucking like this.
  20. Taboo56Chevy
    Taboo56Chevy
    thank you, its been a fun project and a even more fun driver. My grandpa and I have been having a blast driving all over the PNW with it the last couple years.
    bchctybob, porkshop and Dan Hay like this.
  21. Rolleiflex
    Rolleiflex
    Great job! It turned out fantastic.
    I really like the shot in front of Portland Meadows.
    I went to see Van Halen there in 1993 driving my '71 454 step-side. Wish I'd never had sold it.
    bchctybob, Phillips and porkshop like this.
  22. Taboo56Chevy
    Taboo56Chevy
    yeah I had to get a pic there before they tore it down. Now there is a Amazon warehouse where it used to be. I think I remember that truck, seems like I saw some pictures someone in the family took at show somewhere had that truck in it.
    porkshop likes this.
  23. Rolleiflex
    Rolleiflex
    Would love to see those pictures if you come across them.
    How straight forward was it putting the Tremec in your truck?
    Had I kept mine I was really leaning towards Tremec 5-speed in mine to give it a better final drive ratio. With a 454, Turbo 350, and 4:11 gears in the rear it was wound pretty tight at 55mph.
    I had my factory lower control arms modified by SoLow in Troutdale. That was before you could buy off the shelf lowering kits for these trucks.
  24. Taboo56Chevy
    Taboo56Chevy
    Some of the fun from this summer with the truck.
    347236368_640503887492788_7203411659092402320_n.jpg 348608810_6599667473417405_1454252804736753142_n.jpg 462093204_8688862511133844_6152606319157341780_n.jpg 462122499_8688868537799908_1918527089866698251_n.jpg 462218478_122109040256544080_443853938459621610_n.jpg
    These are pics Ive found that others took while at events.
  25. swade41
    swade41
    from Buffalo,NY
    You did a nice job on that truck.
    I had a 69 short step as a daily driver for several years, it's low at***ude and 4.56 gears didn't do to well in the snow though.
    My uncle had a 67 long bed with a power pack 283, powerglide and 4.11 gears, I used to be his chauffeur when he got to pissed up to drive.
    bchctybob and porkshop like this.
  26. pprather
    pprather
    Thanks for the build posts. Nice truck.
    klleetrucking likes this.
  27. Greg Rogers
    Greg Rogers
  28. Tickety Boo
    Tickety Boo
    from Wisconsin
    Beautiful truck, Awesome Job :cool:
  29. phoneman
    phoneman
    from Missouri
    Great job. I really like your truck. How are the reproduction bed parts. What brand are they?
  30. Taboo56Chevy
    Taboo56Chevy
    They were all right. The bedsides, floor and wheel tubs and front panel were Counter Part, the tail gate is a Goodmark. The worst panel was the p***enger side bed side. They have their jig off when they put the inner and outer skin together so they are not correctly aligned. So took a little rework to get fitted than other areas. All my tail light buckets and tail gate hardware is original stuff and worked with the aftermarket metal. Needed some minor tweeking, but not much.
