Art & Inspiration There! I fixed the damn thing.
Discussion in 'The Hokey Ass Message Board' started by '34 Ratrod, Jan 31, 2024.
  1. For those of you who weren't born with the knowledge and ability to bend fuel line I leave you with this tongue-in-cheek attempt so you know you aren't alone.:p:rolleyes:
    Larry
    X-cpe, Deuces, Okie Pete and 14 others like this.
  2. Just.dale
    Just.dale
    Looks legit!!
    chiro, Deuces, VANDENPLAS and 3 others like this.
  3. vtx1800
    vtx1800
    I feel your pain...everytime I do lines, they are never as perfect as the ones we see here:(
    Deuces, Okie Pete, VANDENPLAS and 2 others like this.
  4. squirrel
    sometimes rubber hose is the answer
    chiro, Deuces, WC145 and 13 others like this.
  5. hotrodA
    hotrodA
  6. nochop
    nochop
    from norcal
    Yup…a lot of “proto types” got tossed under the bench on this. You local hydraulic shop can be your best friend 67590577332__13E1477D-1EA9-4DEA-8692-E027E247EEAE.jpeg IMG_4878.jpeg
  7. Tubing 101 " Measure twice, cut once, - no, measure 8 times, make 4 times, throw away 3 times"
    chiro, Deuces, Fortunateson and 17 others like this.
  8. Sharpone
    Sharpone
    Deuces, Okie Pete, 325w and 6 others like this.
  9. X-cpe
    X-cpe
    Making up a set of these helps a bunch. Lay one along side of the tube you are bending and use the black line to mark where to place the tube at 0 in the bender.
    48fordnut, Deuces, Okie Pete and 32 others like this.
  10. nochop
    nochop
    from norcal
    Great idea! I usually make those out of my “prototypes”
    X-cpe, Deuces, Okie Pete and 5 others like this.
  11. nochop
    nochop
    from norcal
    Deuces, VANDENPLAS and Sharpone like this.
  12. ct1932ford
    ct1932ford
    :eek:
  13. Texas John
    Texas John
    When I am doing tubing lines, I do the first version in steel and then transfer to stainless steel lines. i mark the steel lines at 1" intervals over the full length of the line, make the bends (CORRECTLY), then transfer the bends to the stainless lines (also marked at 1" intervals). I make the mistakes on the cheap steel lines and make the stainless lines to duplicate the corrected steel lines. It tells me where to make the bends and in which direction. BTW, the permanent marker comes off with rubbing alcohol. 2020_08_29-FuelRtnLineFinal-IMG_2636.jpg 2020_08_29-FuelRtnLineFinal-IMG_2645.jpg 2020_08_29-FuelRtnLineModel-IMG_2639.jpg 2020_09_01-FuelLineClamps-IMG_2654.jpg
    hfh, Deuces, Okie Pete and 17 others like this.
  14. Sharpone
    Sharpone
    Nice, good idea with the steel lines.
    Dan
    Deuces and VANDENPLAS like this.
  15. choptop40
    choptop40
    next brake install with Nicopp lines...heard good things....anyone chime in ?
    VANDENPLAS, Jeff Norwell and Sharpone like this.
  16. nochop
    nochop
    from norcal
    I’m not a fan of the color, reminds me of plumbing work
    VANDENPLAS likes this.
  17. I spent a great deal of my working life around hydraulic system manufacturing and I admire and respect the talent and layout skills it takes to run tubing in an aesthetic and serviceable manner.
  18. Mr48chev
    That is what happens when you go to put copper house plumbing on a dual carb setup and they reject it not wanting to wear house or building stuff.
  19. mohr hp
    mohr hp
    from Georgia
    I use cheap aluminum fuel line to make a prototype. Re-bendable. I also use it for rollcage tubing prototyping.
  20. Budget36
    Budget36
    @‘34 ratrod , the only thing missing are vice-grip marks on the connection nuts;)
    Deuces, lostone, VANDENPLAS and 6 others like this.
  21. alanp561
    alanp561
    :mad:You guys could have posted all these ideas a long time ago and saved me a lot of time and money. ;)
    Deuces, VANDENPLAS, nochop and 4 others like this.
  22. Sharpone
    Sharpone
    Easy to work with , better than steel but not as nice or good as as SS
    Dan
  23. Happydaze
    Happydaze
    Worst feeling in the world.... having successfully performed a number of difficult bends on a long, stainless tube, you get the final bend 180 out! I usually rescue the piece by finding an excuse for inserting a component somewhere in the line to salvage as much as possible, or insert a joint. I'm cheap, but I like stainless, and can't afford multiple remakes!
    Chris
  24. Jeff Norwell
    Jeff Norwell
    MODERATOR
    Many Attempts... many failures.....
    X-cpe, Deuces, Okie Pete and 7 others like this.
  25. 05snopro440
    05snopro440
    Looks great.
    What kind of bender did you use, or are you saying the hydraulic shop bent it? Is each end flared or are those compression fittings?
  26. 05snopro440
    05snopro440
    What kind of tools does everyone use? I.E. what bender and flare tool do you find works well? Do you use a tubing straightener or?
  27. MMM1693
    MMM1693
    I **** at hard line plumbing, like squirrel said rubber hose and Aero Quip are my freinds.
  28. Ziggster
    Ziggster
    I would have added a few curly coils… well just because…
    Deuces, Okie Pete, VANDENPLAS and 4 others like this.
  29. wheeltramp brian
    wheeltramp brian
    My experience with the nicopp lines are that it is easy to bend , but after a while starts turning green and discolouring . I've got a customer whose truck I did a complete job on that lives a mile from the beach. And it's all turning green and looks terrible. I wouldn't use it again.
    Deuces, VANDENPLAS, nochop and 2 others like this.
  30. MMM1693
    MMM1693
    No Chop...Nice work!
