Art & Inspiration There! I fixed the damn thing.
Discussion in 'The Hokey Ass Message Board' started by '34 Ratrod, Jan 31, 2024.
  1. Deuces, Ziggster and Sharpone like this.
  2. 67drake
    67drake
    from Muscoda WI
    I’ve got special hangers on my shop pegboard for all my failed attempts!! Mangled fuel and brake lines I think I can reuse on another project “someday”. :rolleyes:
    Deuces, Ziggster, Sharpone and 2 others like this.
  3. 67drake
    67drake
    from Muscoda WI
    I use these-
    https://www.amazon.com/BTSHUB-Degre...8&psc=1&mcid=2e7c50e7b3a532baa4de3ac71c8b7059
    I have a couple of the cheaper benders around, a few different styles, but these seem to do the best. But they don’t work any better than the fool using them! :)
    Deuces, Sharpone, 05snopro440 and 2 others like this.
  4. 1971BB427
    1971BB427
    from Oregon
    I like making up hard lines, and getting them looking good. But it seems like occasionally I get one that's absolutely perfect for me, and then realize I forgot to slip the tubing nut over the line.
  5. nochop
    nochop
    from norcal
    No I picked up the fittings from them. Bender is a standard off the shelf one. Fittings are standard jic, and they require a flair. A hydraulic shop has them all
    Sharpone and 05snopro440 like this.
  6. nochop
    nochop
    from norcal
    Alan, your not paying attention:rolleyes:
    '34 Ratrod, alanp561 and Sharpone like this.
  7. Lone Star Mopar
    Lone Star Mopar
    Looks good from my house..
  8. Glenn Thoreson
    Glenn Thoreson
    from SW Wyoming
    Lacking a tube bender, try filling the tube with fine sand and bend it around an appropriately sized piece of pipe or rod. I just use 60 grit sand that I use in the sand blaster. Try it, it works nicely. After bending, don't forget to clean out the inside. Blow it out with air, then run soap and water through it and blow it out again.
  9. nochop
    nochop
    from norcal
  10. nochop
    nochop
    from norcal
    That’s what I thought too, but I couldn’t get the look I was aiming for IMG_4858.jpeg
    Deuces, 05snopro440, Sharpone and 3 others like this.
  11. Sharpone
    Sharpone
    Yep much better with hard lines.
    Dan
  12. Texas John
    Texas John
    Been there - Done That!
    nochop and Sharpone like this.
  13. Texas John
    Texas John
    I used the tubing bender by ECI Engineering. A little pricey, but if you are doing a lot of bends and need to copy a line, it is worth it in my opinion.
    Sharpone likes this.
  14. winduptoy
    winduptoy
    Oh, you mean the Oklahoma knurling tool.....
    Okie Pete, lostone, X-cpe and 5 others like this.
  15. David Gersic
    David Gersic
    from DeKalb, IL
    Easy to work with. I won’t use anything else now.
  16. Fortunateson
    Fortunateson
    Yep, CuNiFer is the way to go!
