Thermostat Air Lock?
Discussion in 'The Hokey Ass Message Board' started by blowby, Jan 29, 2014.
  1. blowby
    blowby
    from Nicasio Ca
    With a dry cooling system, thermostat installed and filling the system only through the radiator , is it possible to create an air lock in the heads and not have coolant reach the thermostat to open it?
  2. tjet
    tjet
    Yeah. That's the reason for the small 1/8" hole in the thermo. If there isn't one, you should drill it
  3. tfeverfred
    tfeverfred
    I fill the radiator. Start the car and add water. Cap is off radiator. When the thermostat opens and I can see the water flowing, I add water if needed and put the cap back on. No hole needed. If a hole was needed, wouldn't thermostats come with one?
  4. 49ratfink
    49ratfink
  5. unkledaddy
    unkledaddy
    Most of us are not running OEM cooling systems, but custom ones which tend
    to overheat. Drilling a hole in the thermostat of a custom cooling system
    will hopefully prevent an air pocket which is a major cause of overheating.
    "Drill baby, drill!"
  6. tfeverfred
    tfeverfred
    My system isn't OEM and my thermostats have never had a hole in them. I need a shroud, but flow and bubbles aren't an issue.
    Are the bubbles less stubborn in an OEM system?:D
  7. Model A Gomez
    Model A Gomez
    I've added thermostats to Model A's and drill a small hole in them since they are in the hose, most modern systems have a byp*** built in. You can have an air lock if any point is higher than the radiator, lots of modern cars have a bleeder valve in the cooling system for this problem.
  8. blue 49
    blue 49
    from Iowa
    Maybe I'm imagining things, but I remember thermostats having a "half hole" notch on the edge of the poppet.
    Blue
  9. Some do.
    It's a hole with a little thimble wobble stopper in the hole.
  10. caton462
    caton462
    I have seen a lot of thermostats over the years with hole, some with jiggle pins to help get the pocket out. I have been filling systems with a tool I made that creates a vacuum since the 80s. It's great for leak checking also before putting the coolant in. Build a vacuum, close the valve to the radiator fill, leave it for a while, see if vacuum held, then fill the system through the same hose. Usually don't have to do much top off. These things are sold pretty cheap over the counter these days.
  11. stimpy
    stimpy
    some do . some of the stant ones I use come with them , and if I use one without I drill the 1/16th hole in it , specailly if I do not have a byp*** circuit on the block back to the pump or run a heater
  12. mechanic58
    mechanic58
    Cheap thermostats usually don't have the little check valve deal and most also don't have the scallop in the valve seat to allow the air pocket to bleed out. I always drill a small hole in every thermostat I install just to ensure no air pocket can form.
    If you **** is already together and you suspect you might have an air pocket, you can loosen a heater hose connection close to the top of the engine and achieve the same result...or if one isn't available maybe you can find a plugged sensor hole and remove the plug - or the sensor to bleed the air pocket out.
  13. I've had that problem - drill an 1/8th inch hole if there is none. Very old vintage NOS ones either had a tiny hole or a slight 'notch' if it was the flipper valve style thermostat.
  14. If you are running a Chevy small block Vortec block that has no provision for an internal coolant by-p*** and no external by-p*** plumbed in(like a big block Chevy) The situation you describe is possible.
  15. blowby
    blowby
    from Nicasio Ca
    Thanks guys. I was helping a friend with a Ford 6, 1966. No hole in the thermostat, and I remembered last time we worked on it we filled the radiator, ran it for awhile and finally the thermostat popped open and it took a bunch more water. This time I drilled a small hole in the thermostat and it filled completely right off.
  16. I drilled the thermostat for a 2004 gm 3.8 and just a Tiny little hole like 1/16.
    Those can be a pain to bleed and burp without it. Now the thing keeps the throwing a coolant error code. Thermostat exceeding limits or some **** like that. Throws it when it takes too long to warm up and That is supposed to alert the tech to a thermostat that's stuck open.
  17. 325w
    325w
    In the factory back when they had vac***n system when adding fluid. I drill the 1/8 hole add coolant and use a Stant radiator pressure tool to check for leaks and push the coolant through the system. Kill two birds with one stone.
  18. mechanic58
    mechanic58
    The engineers at GM should be hung from a gallows for some of the ******** they do. That **** right there is completely unnecessary. lol
  19. Bigchuck
    Bigchuck
    from Austin, TX
    Doesn't that apply to most all automotive engineers over the last 50 yrs?
  20. tfeverfred
    tfeverfred
    Yea! How dare they make something that doesn't work, after it's been tampered with.:D
  21. Engine man
    Engine man
    from Wisconsin
    When I worked at a Ford dealership in 1979, many engines had the air lock problem. Ford filled the cooling system at the factory by using the vacuum system to remove air. The technical service bulletin to cure the problem recommended putting the thermostat in a pan of hot water to get it to open and put a piece of hard candy in it to hold it open before installing it. The candy would dissolve with coolant flow. It is a one time solution. Every time the system is drained the thermostat would have to be removed. I started drilling the 1/16" hole.
  22. tfeverfred
    tfeverfred
    Did it matter what kind of hard candy?
  23. Rocky
    Rocky
    Classified Editor
    It would seem parking the car on an incline with the front end pointing up would help get the air from the back of the engine to the front. I've had good luck with this procedure when filling the cooing system on my wife's old '92 lumina, even though it had the air bleed valve on the intake.
  24. loudbang
    I have this problem with my OT honda every time even though it has a poppet valve on the thermostat. What I do is fill it with what it will take then let it idle until operating temp. Then walk away for an hour or so with making sure the recovery coolant tank is full.
    The residual heat from the engine will eventually open the thermostat and if working properly the radiator will **** coolant from the overflow. After hour or so with the radiator NOT HOT open the radiator cap and usually it will take a quart or more to fill the radiator to full. Check the overflow is at it's normal level and good to go.
  25. 2OLD2FAST
    2OLD2FAST
    from illinois
    Going back over 1/2 century I was told: to avoid air-lock , fill the system SLOWLY , has worked well for the most part IMO...
    dave
  26. RDAH
    RDAH
    from NL, WI
    I've found that asking for a heavy duty thermostat at the parts counter will always have a hole drilled in it.
  27. mad mikey
    mad mikey
    Get the vacuum coolant filling system from AIRLIFT. Problems solved, and it works on any cooling system!
  28. crosswindjoe
    crosswindjoe
    Make sure the heater valve is open if you have one. Fill the block first, through the thermostat opening. Install the thermostat and top hose. Fill the radiator and install the cap. Raise the front of the car so that the top of the radiator is the highest point. Run the engine until the thermostat opens. Lower the car and carefully top off the system.
  29. tjet
    tjet
    I can see it now. It's 1979 somewhere in Detroit on a Friday afternoon. A bunch of Ford engineers in a meeting room with lots of cigarette smoke in the air. One of the engineer's mentions using candy to hold it open. After a brief silence, the engineering manager stands up and proclaims "Jones! your a genius!!.."
    Then they all run down to the bar for a Martini
  30. Hackerbilt
    Hackerbilt
    Modern stuff has to meet much tighter rules in emissions and gas mileage.
    They run hot to keep emissions down and adjust fuel rates depending on the engine temp. (No choke...computer ups the flow during cold starts etc)
    If the engine reads a lower temp than specified it effects performance so the code pops up.
    That something as simple as a 1/16 hole in the thermostat would set off alarm bells, just goes to show how tightly the engines are controlled now! :rolleyes:
