Thermostat housing
Discussion in 'The Hokey Ass Message Board' started by shootingmonkey, Mar 7, 2013.
  1. shootingmonkey
    shootingmonkey
    I have a 53 chevy 210 and have put a 327 in it with the original radiator. The radiator has the top opening on the p***engers side and all the SBC thermostat housings I am seeing all point to the drivers side.
    Does anyone know if GM made one old or new, that will point towards the p***engers side? I know that I can get the adjustable ones, but don't want to if I can help it.
  2. chopolds
    chopolds
    from howell, nj
    292 straight six, I believe will work.
  3. 325w
    325w
    Look at a catalogue at the parts store. They are some that go lots of different ways.
  4. 38Chevy454
    38Chevy454
    Or a straight up version. X2 just go to a real auto parts store and get the paper catalog (***uming they still have those) and in the back will be pictures and dimensions. Find the number of one that works.
  5. I'm pretty sure the 230/250 six cylinder housing will point you in the right direction. They mount on the engine to orient the hose to the driver's side, but when you bolt it on to a SBC manifold, it will point the hose to the right.
  6. rusty1
    rusty1
    an old cast 216-235 6 cyl. thermostat housing will bolt rite on, they go strate up but are 1 & 1/2 inch hose size, just use a rubber hose sleeve inside the hose conection.
  7. MikeRose
    MikeRose
    from Yuma, AZ
    Keep in mind that the 230/250 housing uses a smaller diameter radiator hose. At least mine does. I'm going to replace it with something off of a small block chevy.
  8. MikeRose
    MikeRose
    from Yuma, AZ
    Ha, beat me to it rusty1.
  9. bobss396
    bobss396
    This is correct, I used the 6-banger housings on any C10-C30 I converted to a V8. One peek at one at a parts house will tell you.
    Bob
  10. nochop
    nochop
    from norcal
    Mopar points up as well and will fit sbc
  11. Gator
    Gator
    from Statham Ga
    My '55 Chevy pickup has one that points straight ahead and at a 45* angle... I think all V8 equipped Tri-5 Chevy are the same.
    Other options as mentioned are to flip thru a Murray / Four Seasons catalog, or get one of those 'billet' street-roddy ones that you can rotate 360*
  12. X 2. I've done that v. successfully.
    BTW, IMHO, cast iron thermostat housings work well with aluminium intakes to stop leaking.
    Cosmo
  13. 29moonshine
    29moonshine
    80 's chevy step van points straight at a 45
  14. Halfdozen
    Halfdozen
    NAPA W2493 for 80- 81 Cad, cast iron, outlet straight up, 1 1/2" hose.
  15. aaggie
    aaggie
    I used one from a 292 six on my 400SBC in my '89 Mustang. It points to the p***enger side and is the same size as the V8. It is cast iron and I bought it at the local NAPA store.
  16. shootingmonkey
    shootingmonkey
    I found one that works. It came on 64 and 65 chevelles. The casting number is 3789162.
