I spent the better part of the last month replacing my water pump, thermostat, hoses and fluid including rebuilding the radiator. A few days after all this and enjoying a cooler running car, my thermostat housing cracked. It wasn't from overtightening, I made sure of that. Question is: I cannot locate a replacement neck anywhere. Does anyone know if another make/model will work? The neck is straight with no curve. Pic of the damage
Appreciate it; do these help? End to end and center hole to center hole. The bole head is a 9/16 and bolt opening on the neck is 3/8 diameter. The top water neck opening is 1.5" diameter and the base diameter is 2 11/16.
