Hot Rods Thickstun Low Rise?
Discussion in 'The Hokey Ass Message Board' started by Fred A, Nov 5, 2012.
  1. Fred A
    Fred A
    from Encino, CA
    Picked up an early flathead intake that I hadn't seen before, a Thickstun that was not the common PM-7 or the pre-war hi-rise. Only numbers looks like a serial E2233. Even though the studs are short, would not lbe surprised to find that risers were once available. This Baby's got to be old, looking so primative. It does however have heat. Any information? Thanks: Fred A
  2. Fred those early intakes normally got risers added for generator clearance.
    Can't tell you much more than that about your intake.
  3. Fast67VelleN2O
    Fast67VelleN2O
    I had one recently. They pop up from time to time.
      280 KB
  4. Chris
    Chris
    I had a low rise PM7 on my 1934 221... Performed awesome!
  5. Fred A
    Fred A
    from Encino, CA
    That low rise Thickstun on swenson's picture site is not a PM-7 but the same as the one I just picked up. Says it's pre-war. I only guess it to be old with its 45 degree rochochet ports. Still may use the early slingshot first. Thanks All: Fred A
  6. J. Fitzhugh
    J. Fitzhugh
    Is the Thickstun logo along the back intake runner? If so, this is the pre-war version, with the abrupt intake port runner angles.
    See TRJ #8 for the Thickstun story.
    Jay
  7. Rob Paul
    Rob Paul
    I used one for awhile. Great intakes. What do you want to do with it? If you use an early generator it will cleat the carbs.
    Rob
