Think Im going to be sick. brand new flathead siezed.
Discussion in 'The Hokey Ass Message Board' started by lowsquire, Nov 20, 2009.
  1. lowsquire
    lowsquire
    from Austin, TX
    if you could explain how you would do that on a flathead ,Ron, i will gladly do it when i put this engine back together..
  2. Ron In the SHOP
    Ron In the SHOP
    from california
    lowsquire,
    think a little bit.
    think of what makes the oil pump turn.
    .....put the oil pickup in a coffee can of oil.
  3. MN Falcon
    MN Falcon
    Again, thinking of the cyl wall wear, am I correct in that the cyl walls are oiled from a hole in the bearing end of the rod? That would explain the wear since you had no oil to the rods.
  4. Bruce Lancaster
    Bruce Lancaster
    I think he had the stock pump, so no relief valve there; The actual relief valve in valley never saw any oil.
  5. Bruce Lancaster
    Bruce Lancaster
    To clarify one thing that is hard to spot in the military full flow setup: The fitting that sends oil TO the filter has a sleeve on its lower end that p***es through the oil gallery and blocks it from access, doing the same job that rodders do with a plug stuck horizontally into the p***age. This means that no work is needed on block except for a simple hole drilled down from the port. The Canadian system used stock sized ports, making the lines rather small for the use...but I guess they worked, as that engine was the backbone of transport in the Desert war!
  6. swifty
    swifty
    Any more news on this one Ben? Have you found some bearings yet?
    swifty
  7. lowsquire
    lowsquire
    from Austin, TX
    Onto the conrod bearings locally swifty, really cheap! the mains I may have to import, as no-one local has any old stock ..
    The Crank looks to be fine, will be polished and checked over today, see how we go on the Bore, So all in all Im hoping to still have the car driving by christmas. making the door cards and interior panels for the trimmer today.
  8. hotcoupe
    hotcoupe
    sorry to hear about your problem, if you decide to use Ross pistons- "flatlander racing" has the best price that i have found. nice car by the way.
  9. solid
    solid
    Sounds like its coming back together. Gonna be cool.
  10. lorodz
    lorodz
    wow...just beautiful car ..great looking ...just read this whole thread ..sorry for ya loss of hard work..good luck with the re-build
  11. 1928arat
    1928arat
    from australia
    have you tried automotive surplus in melbourn for engine parts they have alot of old stock if not pm me and i will give you a contact for big ends i just bought a set NOS ford script,
  12. owen thomas
    owen thomas
    Piston compression ring end gap - 0.003" per inch of bore, minimum.
  13. Roothawg
    Roothawg
    As bad as this is for you, this is a very interesting thread.
  14. Django
    Django
    from Chicago
    That is really interesting about the military vs civilian motors. What a shame though. :(
    Your car is GORGEOUS!
  15. Hahahahaha... a joke only the Aussies will truly understand. At least he didn't say Foster's. ;)
    Ben - Sorry to hear about it. It probably happened the day after I visited, so apologies for any bad luck that may have rubbed off me. :(
  16. saltracer
    saltracer
    Have any pictures of the car?
  17. Chuck R
    Chuck R
  18. Mate,
    Developments????
    Danny
  19. 1930roadster
    1930roadster
    Why play games after all that effort and money, just pull it and see what went wrong and fix it. Play games and **** it up more. been there 27 yeas ago, and i made matters worse... Best of luck
  20. Frankie47
    Frankie47
    from omaha ne.
    Dang you didn't have the time to read the whole thread?
  21. sixdogs
    sixdogs
    from C
    Any updates on this?
  22. I think there's some new info on lowsquire's other post on his '32.
