Technical Thinking about Building intake for 264 Nailhead
Discussion in 'The Hokey Ass Message Board' started by Aprules2, Apr 10, 2022.
  1. Aprules2
    Aprules2
    Hey guys some of you may laugh at me for considering this but I really want to try. There is basically nothing out there for the 264 and 322 Nailhead. I have a 264 in my 55 Special with the Dynaflow trans. It has very weak bottom end torque even after swapping to a 4 barrel and recurving the distributor. Yes, I could swap to a 322, or 3-speed stick but finding the parts in NJ or nearby is nearly impossible, I don't want to redesign the whole suspension to swap in a Buick 455 or anything like that, so let's work with what we've got. I was thinking about the old Chryslers that long-runner runner cross ram manifolds. I have basic welding skills and 2 Holley 500cfm carbs, I was thinking why not try building one to fit on the Nail. Does anyone know how long they should be or how big of a plenum I need? Is there a formula?
  2. BJR
    BJR
    Do you have dual exhausts? If not do that first, it needs to Breath. I had a 54 Special convert with the same engine, put on duals and a 4bbl and was amazed what a difference it made, even with the Dynaflow.
  3. Sonofabob
    Sonofabob
    Edmunds has a intake for the 322, I run one on mine. Trouble is finding one.
  4. To go along with the good point that @BJR made, is your heat riser plate in the exhaust manifold stuck partially closed? The manifold (center in the attached pic) is for a 55 special, and has ample flow. A good diameter dual exhaust system works wonders for a Nail, provided the engine is in good condition. Have you done a compression test? Cam timing correct? Twin 500 CFM carbs would be heavy for a 264. Longer runners or spacer plates create a loss of power according to Russ Martin.
    Motorwrxs likes this.
  6. There are many 3 carburetor manifolds around for Buick 264", and 322" engines.
